Topic: SPI woes - Ethernet shield vs. everything else (Read 5577 times) previous topic - next topic
johnlinford
May 24, 2016, 04:42 pm Last Edit: May 24, 2016, 04:48 pm by johnlinford
I would be very grateful if the forum could help me to a better insight into how SPI works and, in particular, why I am failing to get my set up to behave. This is the hardware stack that I am trying to get to work:
5" TFT display with SPI-connected flash chip
Display shield
Ethernet shield (1 or 2)
SD card on the Ethernet board
Arduino Due
The library stack is
#include <SPI.h>
#include <SdFat.h>
#include <Ethernet.h> (or #include <Ethernet2.h>)
#include <ICMPPing.h>
#include <UTFT.h>
#include <UTFT_GHL.h>
The Ethernet connection receives asynchronous UDP data for the intended application. The application then processes the data, saves stuff to the SD card and writes information to the display using fonts obtained from the flash chip. I am using the Ethernet library (or the Ethernet2 library for the v2 card) and SdFat. The flash chip uses the UTFT_GHL library. There are, therefore, three users of the SPI: Ethernet, SD card and flash chip.
It doesn't work!
To try to narrow down the problem I wrote a simple app that pings Google via the Ethernet card, reads/writes/deletes files on the SD card and writes stuff to the display in a continuous loop. I'm happy to post this code if it will help.
What happens?
Each of the SPI interfaces works fine on its own. If I run the Ethernet and SD card together, as soon as I do anything with the SD card the Ethernet interface dies so conclusively that it hangs the entire machine when the next ping is sent. The same thing happens if I run Ethernet with Flash font screen printing. The only combination that does work is SdFat R/W/D and UTFT_GHL reading the flash to get its fonts.
Anecdotally the Ethernet card doesn't play nicely with other things on the SPI and my experience seems to be adding to that sorry tale. It seems to me that this is something that it ought to be possible to fix once and for all but I am no expert when it comes to the innards of these drivers/libraries and am a relatively recent convert to programming in C. So I am appealing to those with greater knowledge and experience than me to help out with this one.
Any insight gratefully received!
Thanks in advance.
John.
ghlawrence2000
I hope you get to the bottom of this, as no doubt in the future I am likely to get 'my ethernet shield doesn't work with UTFT_GHL' .....  :smiley-confuse:
Regards,
Graham
UTFT_SdRaw now included in library manager!! ;) High speed image drawing from SD card to UTFT displays for Mega & DUE.
UTFT_GHL - a VASTLY upgraded version of UTFT_CTE. Coming soon to a TFT near you! 8) Shipping April 1 2016!
johnlinford
Update:
After a lot of Googling, I came to the perhaps mistaken conclusion that the SPI library for Due might be different to that for, e.g. Mega 2560. I decided to try my code on a 2560. Lo and behold, Ethernet and SdFat happily coexist.
Unfortunately I do not have a Mega-compatible shield for the display, so I can't easily test that interface. As the UTFT_GHL/SdFat combination works on the Due, I suspect it will on the Mega.
My application really needs the processing power of the Due, otherwise I'd be tempted to just go with the Mega and be done with it.
So, is there a different SPI library for the Due? And if so, where can I get it?
Thanks in advance
John.
ghlawrence2000
#3
May 28, 2016, 02:22 pm Last Edit: May 28, 2016, 02:22 pm by ghlawrence2000
Yes John, it does.
Regards,
Graham
johnlinford
Thanks Graham.
It seems that none of the forum experts can find a barge pole long enough to convince them that it's safe to engage on this issue. That's a shame - it seems that SPI is both poorly understood and poorly implemented in many cases.
Someone out there will know the answer and it would be great if they would come forward. Meanwhile I shall continue to look at other options.
John.
johnlinford
Final attempt to stir up some response :D  Here is the test code I am using...
Code: [Select]
#define SD_CS_PIN 4
#include <SPI.h>
#include <SdFat.h>
//#include <SD.h>
#include <UTFT.h>
bool SDInitialised=false;
SdFat SD;
File myFile;
bool EthernetInitialised=false;
IPAddress pingAddr(8,8,8,8); // ip address to ping
byte mac[] = {0x90, 0xA2, 0xDA, 0x0D, 0xB4, 0x9A}; // MAC address for ethernet shield
SOCKET pingSocket = 0;
char buffer [256];
ICMPPing ping(pingSocket, (uint16_t)random(0, 255));
bool TFTInitialised=false;
UTFT myGLCD(CPLD,25, 26, 27, 28);
UTFT_GHL CTE_LCD(&myGLCD);
int Count;
  //pinMode(4, OUTPUT);   //Makes no difference
  //pinMode(10, OUTPUT);  //Ethernet doesn't initialise if this is enabled
  //pinMode(52, OUTPUT);  //Makes no difference
  //pinMode(53, OUTPUT);  //Makes no difference
  Serial.println("Initialising display...");
  myGLCD.InitLCD();
  myGLCD.setBackColor(VGA_BLACK);
  CTE_LCD.SPI_Flash_init(FLASH_CS_PIN);
  myGLCD.clrScr();
  TFTInitialised=true;
  Serial.println("Initialising SD card...");
  if (SD.begin(SD_CS_PIN)) {
    Serial.println("SD card initialised OK");
    SDInitialised=true;
  else {
    Serial.println("SD card initialisation failed");
  Serial.println("Initialising Ethernet...");
  if (Ethernet.begin(mac)) {
    Serial.println("Ethernet initialised OK");
    EthernetInitialised=true;
  else {
    Serial.println("Ethernet initialisation failed");
  Count=0;
  Count++;
  //Send ping request
  //The ping is just a convenient way of testing whether the Ethernet interface is still working.
  Serial.println("Ping request");
  ICMPEchoReply echoReply = ping(pingAddr, 4);
  if (echoReply.status == SUCCESS) {
    sprintf(buffer,
            "Ping reply[%d] from: %d.%d.%d.%d: bytes=%d time=%ldms TTL=%d",
            echoReply.data.seq,
            echoReply.addr[0],
            echoReply.addr[1],
            echoReply.addr[2],
            echoReply.addr[3],
            REQ_DATASIZE,
            millis() - echoReply.data.time,
            echoReply.ttl);
  else {
    sprintf(buffer, "Ping request failed; %d", echoReply.status);
  Serial.println(buffer);
  //Write file
  Serial.println("Write to SD");
  myFile = SD.open("test.txt", FILE_WRITE);
  if (myFile) {
    myFile.print("Test data, loop count=");
    myFile.println(Count);
    myFile.close();
  //Display stuff
  Serial.println("Write to display");
  CTE_LCD.Put_Text("Test data, loop count=",10,200,BVS_34);
  CTE_LCD.Put_Text(String(Count)+"    ",400,200,BVS_34);
  //Read the file
  Serial.println("Read file from SD");
  myFile = SD.open("test.txt", FILE_READ);
  if (myFile) {
    while (myFile.available()) {
      Serial.write(myFile.read());
    myFile.close();
  //Delete the file
  Serial.println("Delete file on SD");
  SD.remove("test.txt");
And here is the serial port display
Code: [Select]
Ping request
Ping reply[0] from: 8.8.8.8: bytes=64 time=14ms TTL=128
Write to SD
Write to display
Read file from SD
Test data, loop count=1
Delete file on SD
Ping request
...at which point it dies. Either SD card activity or writing to the display kills the Ethernet.
Still hoping someone might be able to help...
Thanks
John.
ghlawrence2000
#6
May 31, 2016, 02:23 pm Last Edit: May 31, 2016, 02:24 pm by ghlawrence2000
Hi John,
mmm I am not sure if you have already tried and removed it, or if you only partially implemented my suggestion?
I see all of your pinMode definitions, now commented out, but I don't see your corresponding digitalWrite(pin, HIGH) commands?
eg :-
Code: [Select]
  digitalWrite(4, HIGH);
  digitalWrite(10, HIGH);
  digitalWrite(52, HIGH);
  digitalWrite(53, HIGH);
Regards,
Graham
johnlinford
Hi Graham,
Yes I did try setting all the pins high but the problem remains unchanged. The only pin that makes any difference is setting pin 10 to output. That just kills the Ethernet card immediately, at initialisation, regardless of whether I then set the pin to high...
Code: [Select]
...and it's dead.
John.
ghlawrence2000
Hi John,
Ok.
Specifically which Ethernet cards do you have, and which ethernet library are you using?
G
johnlinford
I have the standard "Ethernet R3" shield and I've also tried the "Ethernet Shield 2". Both behave in exactly the same way. The library is the one installed with the Arduino 1.6.8 IDE. Version 1.1.2 according to the library.properties file and that seems to be the current version on GitHub.
J.
ghlawrence2000
AHA.....
Maybe worth trying this one then, since it mentions now works at SPI 42Mhz, which is also oddly enough what the Font IC runs at....
G
johnlinford
#11
May 31, 2016, 04:41 pm Last Edit: May 31, 2016, 04:49 pm by johnlinford
Disappointing! Exactly the same results with the WIZ library. I have checked that the new library is definitely being compiled in (via a Serial.print within the library) and I've configured it per the instructions to use the R3 Ethernet shield. I have yet to try it on the Ethernet 2 shield but it's not looking promising.
I must be doing something stupid but I cannot for the life of me work out what it is.
J.
** Update: exactly the same results with the Ethernet 2 card. :(
ghlawrence2000
I am running out of ideas.....
Oh by the way, after my lengthy reply to your lengthy reply, STM32 stuff..... there will very soon be a DUE replacement with almost the exact hardware!! Now THAT will be nice.... do a search for Arduino Star OTTO.
G
johnlinford
Thanks for trying Graham. The Star OTTO (what an odd name) does indeed look interesting, as does the EtherDue (if I can ever get a reply from the supplier). No doubt each will bring all sorts of new things that don't quite work as expected...
pjrc
Is this 5 inch TFT using RA8875?
The RA8875 has a known problem where it can not tri-state its MISO pin.  A separate tri-state buffer is usually required if the RA8875 is used together with any other SPI chips.
Sometimes it can work, when another chip also drives MISO, but the result is an incorrect voltage for logic high and low, so whether it works depends on the MISO receiver circuitry in your Arduino.  I've heard reports of 2 RA8875 (but not 3) working on Mega, but failing on Teensy 3.2.  No idea about Due.
Star Otto looks like powerful hardware, but it's made by that "other" Arduino.  Maybe it'll turn out to be an awesome product, but given their dismal performance on the software side so far (mostly copying everything from Ardiuno.cc with only minor tweaks), might be best to take a wait-and-see approach.  The market is already filled with extremely powerful STM32-based boards that don't have good Arduino compatibility.
