Well, there's my lesson for the day. Overall, I would have thought bluetooth to be a more mature and reliable technology. I know there's range issues, but I had assumed with the module I had linked to, it would be as simple as a generic pairing and from then forward it would be functionally the same as a "regular" serial COM port.
I knew xbee could be set up this way, but I thought it to be the inferior (for no good reason, I just thought bluetooth was the obvious solution and others for the most part would be wannabe's). Score one for marketing, I guess. So, a proper xbee solution is two transceivers, and is the "right" way to do it.. even if costly. A pair is something like $50-60, yes?
I really want to add wireless to my Boarduino, as I blew up my Max232 cable jobbie, so I've got to use ISP, with Arduino as programmer, if I want to use it (until I replace the max232 with something). I'd been looking and hoping that a bluetooth-to-TTL link link might be as easy as that $14 board... should have known better
