Topic: Arduino Bootloader Programmer to RS232  (Read 1 time) previous topic - next topic
worldwideweb
May 25, 2016, 12:59 pm Last Edit: May 25, 2016, 01:08 pm by worldwideweb
K010001E Arduino bootloader Shield
You need to visit the site for more (proteus isis and ares file)Arduino Bootloader Programmer
 Dip28 socket on the Arduino bootloader is installed in the ATMega. On the jumper1 (J1) that is set at the 2-pin and 3-pin jumper attached, it serves as the bootloader. Also jumper 2, 3, and 4 active when the RS232 TTL output circuit is programmed Arduino Arduino other. USB is available in the damaged part of the Arduino programming. All pins of the CN5 connector on the Arduino circuit is located in a single row. CN5 connector is plugged directly into the 16x2 alphanumeric LCD.
