Topic: 'movementstatus' does not name a type (Read 480 times) previous topic - next topic
ricky0178
May 30, 2016, 07:45 pm Last Edit: May 30, 2016, 07:59 pm by ricky0178
Code: [Select]
Arduino:1.6.9 (Windows 10), Scheda:"Arduino/Genuino Uno"
sketch_may30a:42: error: 'movementstatus' does not name a type
   movementstatus=digitalRead(movement);
sketch_may30a:43: error: expected unqualified-id before 'if'
   if(movementstatus==HIGH)
sketch_may30a:66: error: 'lcd' does not name a type
 lcd.setCursor(0, 0);   //Start position of the cursor on the LCD (0,0 = first //character in the first row).
sketch_may30a:67: error: 'lcd' does not name a type
 lcd.print("Temp.=");  // Write the text "www.funduino.de"
sketch_may30a:68: error: 'lcd' does not name a type
 lcd.setCursor(6, 0);  //Start position of the cursor on the LCD (0,0 = first //character in the second row).
sketch_may30a:69: error: 'lcd' does not name a type
 lcd.print(temperatureC);  // Write the text "good luck!!!".
sketch_may30a:70: error: 'lcd' does not name a type
 lcd.setCursor(10, 0);  //Start position of the cursor on the LCD (0,0 = first //character in the second row).
sketch_may30a:71: error: 'lcd' does not name a type
 lcd.print(" C");  // Write the text "good luck!!!".
sketch_may30a:72: error: 'lcd' does not name a type
 lcd.setCursor(0, 1);   //Start position of the cursor on the LCD (0,0 = first //character in the first row).
sketch_may30a:73: error: 'lcd' does not name a type
 lcd.print("Allarme attivo");  // Write the text "www.funduino.de"
sketch_may30a:74: error: expected constructor, destructor, or type conversion before '(' token
 delay (2000);
sketch_may30a:75: error: expected declaration before '}' token
exit status 1
Questo report potrebbe essere più ricco di informazioni con l'opzione
"Mostra un output dettagliato durante la compilazione"
abilitata in File -> Impostazioni
questo è il codice che volevo usare, ma alla riga dove dice "movementstatus=digitalRead(movement);" mi da errore...
AIUTO
Ricky0178
gpb01
...e tu pensi che noi abbiamo una sfera di cristallo dove possiamo vedere il tuo codice e capire l'errore ?  :smiley-eek:
Metti tutto il codice (... mi raccomando, racchiuso tra i tag CODE che, in fase di edit, ti inserisce il bottone </> ... primo a sinistra) e vediamo di capire ...
Guglielmo
Search is Your friend ... or I am Your enemy !
ricky0178
#2
May 30, 2016, 08:23 pm Last Edit: May 30, 2016, 08:52 pm by ricky0178
ok scusa  :D
Code: [Select]
#include <LiquidCrystal.h>   //Load the LCD library
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);  //In this line we define which pins on //the microcontroller get connected to the LCD (Better don't change yet).
//TMP36 Pin Variables
int movement=7;   //The word "movement" stands for the value 7.
int movementstatus=0;
int pinButton = 13;
int piezo=8;
int stateButton;
int previous = LOW;
long time = 0;
long debounce = 200;
int sensorPin = 0; //the analog pin the TMP36's Vout (sense) pin is connected to
//the resolution is 10 mV / degree centigrade with a
//500 mV offset to allow for negative temperatures
  pinMode(pinButton, INPUT);
  pinMode(piezo, OUTPUT);  //The pin connected to the piezo speaker (pin 5) is //defined as an output.
  pinMode(movement, INPUT);  //The pin connected to the moition detector (pin 7)is //defined as an input.
lcd.begin(16, 2);   //In the setup we indicate how many signs and how many rows //we are using. In this case: 16 signs in two rows.
  stateButton = digitalRead(pinButton);
  if(stateButton == HIGH && previous == LOW && millis() - time > debounce) {
    lcd.print("allarme disattivo");  // Write the text "www.funduino.de"
    if(movementstatus == HIGH){
      movementstatus = LOW;
       movementstatus = HIGH;
    lcd.print("allarme attivo");  // Write the text "www.funduino.de"
    time = millis();
  digitalWrite(movement, movementstatus);
  previous == stateButton;
    digitalWrite(piezo,HIGH);  //..the piezo should beep
    lcd.print("                ");  // Write the text "www.funduino.de"
    lcd.print("MOVIMENTO RILEVA");  // Write the text "www.funduino.de"
    delay (1200);
    lcd.print("OVIMENTO RILEVAT");  // Write the text "www.funduino.de"
        delay (1200);
    lcd.print("VIMENTO RILEVATO");  // Write the text "www.funduino.de"
    delay (2100);
 digitalWrite(piezo,LOW);  //..the piezo should beep
int reading = analogRead(sensorPin);
float voltage = reading * 5.0 / 1024;
float temperatureC = (voltage - 0.5) * 100 ;
delay (2000);
Guglielmo
Come non la avete?? ;D
Ricky0178
gpb01
#3
May 30, 2016, 08:31 pm Last Edit: May 30, 2016, 08:32 pm by gpb01
Se tu usassi quella comoda funzione dell'IDE che sistema le righe del codice (Tools -> Auto Format) ti accorgeresti che dalla riga indicata in poi ... sei FUORI dal loop(), ovvero, hai già chiuso la graffa del loop().
Code: [Select]
} // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< questa chiude il loop()
movementstatus = digitalRead(movement);
if (movementstatus == HIGH)
Riguarda il tuo codice e vedi cosa vuoi fare esattamente !
Guglielmo
uwefed
#4
May 30, 2016, 10:00 pm Last Edit: May 30, 2016, 10:01 pm by uwefed
Controlla il numero e e posizioni delle parentesi graffe.
In riga 42 chiudi la funzione loop() e il codice dopo é fuori da una funzione.
Ciao Uwe
ricky0178
ok, capito l'errore e risolto! Che sciocco che sono stato :o
Ricky0178
