Topic: another cnc mill questionaire (Read 70494 times) previous topic - next topic
theMPloc
hi there, i know there is a lot stuff out there and i did a lot of research in google and and several forums.
i want to build a cnc mill using an arduino (uno or duemilanove) with three axes. i already connected three easydrivers and stepper motors to the arduino and have them running.
the building of the cnc mill is in progress.
what i am looking is the right firmware for the arduino that will make it possible to use either replicatorG as host oder mach3. at the moment i am confused by the amount of different firmwares (gcode interpreter, mendel,....).
would anybody be so nice an tell me exactly which firmware i will have to use and where i can find it for my project?
thank you so much in advance!!!
mmcp42
don't know if it helps
I'm going down the same route! (<- you see what i did there!)
I have written a gcode interpreter for exactly that setup, 3 EasyDrivers connected to a Uno
I have also written a piece of software that sits on the PC and feeds gcode to it
Stir in Eagle and pcbgcode and I have a complete "design" to "cut" solution
If you like I can post the software
there are only 10 types of people
them that understands binary
and them that doesn't
theMPloc
#2
Jan 01, 2011, 12:45 pm Last Edit: Jan 01, 2011, 01:08 pm by theMPloc Reason: 1
thats supergreat! i would be very happy if you would send me your software.
does this mean that if i design something in a 3d package, export this and create gcode from it then i can feed the mill with your software?
oh i´m excited....
mmcp42
yup the PC software takes a gcode file and sends it line by line to the Arduino which interprets it and controls the 3 steppers
I'll put it all together inamo
theMPloc
#4
Jan 01, 2011, 02:16 pm Last Edit: Jan 01, 2011, 02:17 pm by theMPloc Reason: 1
oh this sounds sooo good! as you tell me that gcode is beeing send from your software to the arduino - am i right, that it is possible to use other software that sends gcode like replicatorG? i mean actually i do not need replicatorG as i have the gcode already but i simply like the user interface :)
mmcp42
#5
Jan 01, 2011, 03:15 pm Last Edit: Jan 01, 2011, 04:14 pm by mmcp42 Reason: 1
I can't speak for ReplicatorG as I don't know it
but, the gcode interpreter "talks" to the PC software
I'll upload them both in a bit
I just tried to make it idiot-proof
trouble is the idiots outnumber us!
mmcp42
#6
Jan 01, 2011, 03:22 pm Last Edit: Jan 01, 2011, 03:22 pm by mmcp42 Reason: 1
ok here are the two parts...
first the software that opens and transmits a gcode file
http://www.mmcpix.com/CNC/CNCdriver.zip
you will need to click File :: Options to chose your COM port (and any other settings you fancy)
As well as sending the gcode it shows a picture of what it's up to
It's aimed at PCB milling btw
second the gcode interpreter that runs on the Uno
http://www.mmcpix.com/CNC/GCode_Interpreter.zip
DO look at _init.pde as you will need to configure it to suit your machine
It supports 3 axes each with limit switches
like I said I think it's idiot-proof, but...
feel free to ask questions, but I take no responsibility for you destroying your Arduino, drivers, motors, house, wife, children, sundry other loved ones or any other part of your immediate environment!
oh and if you make any changes - please let me know what you did
Do you have any info on the machanics of your build, btw?
theMPloc
i am just downloading your codes. thank you sooo much by now. i will try to figure it out and let you know how i am doing. thank you for your offer to ask you questions.
regarding to my construction: i will build it next week. basically its a similar design to the makebot-router which you can find on www.makebot.com. the difference will be that i will use linear ball bearings. if you like i will keep you informed about how i am doing.
thank you so much again and have a nice day!
theMPloc
#8
Jan 04, 2011, 08:59 pm Last Edit: Jan 04, 2011, 10:32 pm by theMPloc Reason: 1
hi,
(1) i am just trying the cnc driver. i setup port 8 (where my arduino is connected) but the software is telling me "unable to open port (win error code: 2)".
(2) i wired my arduino the way it says in _init.pde what is strange is that the stepper motors all go on "wake up" and get hot after a while. maybe i am an idiot but in the _init.pde it says pins 14-19 correspond to analog 0-5 so i connected pin 18 to A4 ( where it says analog in). i guess this is bullshit - can you tell me where the pins 14-19 are? i am sorry for asking stupid questions but i maybe an idiot :)
please help!
mmcp42
hello
that happens when it - er - can't open the port!
can you talk to your arduino using the IDE?
which port does that use?
have you told the cnc driver (setup) which port to use?
cheers
Mike
theMPloc
#10
Jan 04, 2011, 10:34 pm Last Edit: Jan 04, 2011, 10:42 pm by theMPloc Reason: 1
i can talk to arduino using port 8 and i told cncdriver to use this port (in the tools menu). thats how i connected arduino and uploaded the qgcode interpreter. i also tried it using serproxy on that port and running a flash application which drives a stepper motor.
theMPloc
i tried the same on an arduino duemilanove which connects to port 7. so i did upload gcode interpreter and then started cncdriver. then "tools menu", "options" set port to 7.
i get the same error "unable to open com port"
what do i do wrong  :'(
mmcp42
Not quite sure - I will glare at the code when I wake up!  :)
theMPloc
mmcp42
meant to ask
what OS are you using?
I've tried on Win7 and XP
