Topic: http button cannot work to turn on or off the led (Read 441 times) previous topic - next topic
HSpaigu
hello, im new of arduino yun, i try to make a web to control the led, ive already finished, but everytime the browser need to refresh, so i want to make a button and use AJAX, i heard use ajax could not need refresh the browser. but the button didnt work i dont know why.
here is my code:
Code: [Select]
#include <Bridge.h>
#include <BridgeServer.h>
#include <BridgeClient.h>
int LEDPIN = 3; // your LED PIN
BridgeServer server;
String http_req = "";
  // Start our connection
  pinMode(LEDPIN,OUTPUT);
  digitalWrite(LEDPIN,HIGH); // turn on Led while connecting
  Bridge.begin();
  // Show a fancy flash pattern once connected
  digitalWrite(LEDPIN,LOW);
  delay(150);
  delay(150);
  delay(150);
  delay(150);
  delay(150);
  // Disable for some connections:
  // Start listening for connections
  //server.listenOnLocalhost();
  server.begin();
  // Listen for clients
  BridgeClient client = server.accept();
  // Client exists?
  if (client) {
    // Lets process the request!
    process(client);
    client.print("***");
    client.print(http_req);
    client.stop();
    http_req = "";
  delay(50);
void process(BridgeClient client) {
  // Collect user commands
    while (client.connected()) {
      if (client.available()) {
        // read request form browser
        char c = client.read();
        http_req += c;
        http_req.trim();
        if (c == '\n') {
          // Serial.println(readString);
          //检查收到的信息中是否有"on",有则开灯
          if(http_req.indexOf("?on") >0) {
            digitalWrite(LEDPIN, HIGH);
            Serial.println("Led On");
          //检查收到的信息中是否有"off",有则关灯
          if(http_req.indexOf("?off") >0) {
            digitalWrite(LEDPIN, LOW);
            Serial.println("Led Off");
          //发送HTML文本
          client.println("Status: 200");
          client.println("Content-type: text/html");
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html><head><script type=\"text/javascript\">");
          client.println("function send2arduino(){var xmlhttp;xmlhttp=new XMLHttpRequest();element=document.getElementById(\"light\");if (element.innerHTML.match(\"Turn on\")){element.innerHTML=\"Turn off\"; xmlhttp.open(\"GET\",\"?on\",true);}else{ element.innerHTML=\"Turn on\";xmlhttp.open(\"GET\",\"?off\",true); }xmlhttp.send();}");
          client.println("</script></head>");
          // Show UI
          client.println("<B><Center>");
          client.println("<h1>Arduino AJAX Button</h1>");
          client.println("<button id=\"light\" type=\"button\" onclick=\"send2arduino()\">Turn on</button><br>");
          client.println("</B></Center></html>");
there are 2 problems:
1. i dont know what is the address, i know it should be like arduinolocal/arduino/?, but whatever i put in the browser, it is ok,(for example: arduinolocal/arduino/on or arduinolocal/arduino/test)
2. the string i get from client.read() is always the same as the address(for example, if address is arduinolocal/arduino/test, the string is 'test'),
i dont if my way is right, hope someone could help me
HSpaigu
i use javascript to set the action function of button, and the button is working, if the button is turn on and when i push it will become turn off, if the button is turn off and when i push it will become turn on
so i think the function is working and the xmlhttp.open(\"GET\",\"?on\",true) and xmlhttp.send() should working, but the client.read() cannot read the message from xmlhttp.open() and xmlhttp.send()
HSpaigu
i may not describe the problem clearly.
purpose: when i run my arduino yun, i can open the browser and there is a button which can turn on and off the led on the board.
2. what i use (now)is #include <Bridge.h>  #include <BridgeServer.h>  #include <BridgeClient.h>
3. when i click the button, the browser should not refresh(heard need use AJAX)
4. i heard i should set up a .html file, but i dont know where to put it, and how to use it in arduino code
