Topic: [SOLVED]1.6.9 in Windows 10 Conflict with AntiVirus (Read 2212 times) previous topic - next topic
cattledog
Jun 04, 2016, 07:35 pm Last Edit: Jun 05, 2016, 01:38 am by cattledog
I recently began running the IDE(1.6.6 and 1.6.9) in Windows 10. I have McAfee antivirus with real time scanning installed on the computer. When I try to compile any example or sketch I get the following error
Quote
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar: unable to rename 'C:\Users\RICHAR~1\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a'; reason: Permission denied
I do not have these problems in Win 7 with the same anti virus program.
Using Google and forum search for core\core.a errors I came across the following post pointing at permissions and anti virus issues.
https://forum.arduino.cc/index.php?topic=378097.0
I tried run as administrator, and several permissions and read only > full permission  file changes, but the only thing I can make work is to disable the real time scanning in McAfee when compiling/downloading.
Does anyone have another solution?
EDIT
There were two tag on PUPs as part of the new OS, ByteFence anti-malware, and some sort of "Cleaner"
performance optimizer and malware fixer. When I removed both those programs, the IDE compiles the examples and sketches without error with McAfee running as normal with real time scanning enabled.
octaviaink
#1
Mar 17, 2017, 08:47 am Last Edit: Mar 17, 2017, 09:00 am by octaviaink
Bytefence itself is apparently a legit program, but which (the free version) can sometimes be bundled along with another program. This is not to say that your 'offer' is legit or possibly a scam.
Is it just a message window, or also anything like here ? >
https://www.bytefence.com/
I'd first check in Programs and Features for it & uninstall. I'd use Uninstaller to also remove any remnants.
I'd also then run removal tool even if not in Programs and Features as it might be on your PC as a PUP.
ballscrewbob
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
