Topic: 3D scanner (Read 1 time) previous topic - next topic
janvenken
Is there any way to send a bluetooth signal from arduino to a smartphone camera?
We're building a 3D scanner using a smartphone. The arduino controls a rotating disc that's driven by a servo. Every 24 ° the servo stops and a signal should be send from the arduino bluetooth module JY-MCU to the smartphone so it takes a picture.
The programming of the servo is easy but I can't seem to find how to get the bluetooth module to operate the smartphone's camera.
spycatcher2k
Not an Arduino Question, Its an Android programming question, you would get a better responce on one of their forums  :)
Mrs Drew
UK Based PCB Manufacturing - PM for details
I will design & code for you, but I will also charge you (PM me)
Use Google or search this site BEFORE asking!
janvenken
I was hoping to find someone here that has already done this so it saves me the programming :)
One more thing, and this is an arduino question, are there any libraries need for sending bluetooth signals and what kind of signals can a bluetooth send and how do you determine what the bluetooth module sends?
janvenken
If i send something with the bluetooth module, should I use HEX code? I found that all I need to do is to send CR (enter) so the smartphone will take a picture. In order to do so, the module should send a CR code to the smartphone. But I'm not sure what code to use, binairy, hex or...?
janvenken
Ok, managed to solve this problem . Anyone who's interested how, PM me
