Topic: mfrc522 power consumption (Read 2869 times) previous topic - next topic
0x776F6F74
Anyone know how to power down mfrc522?.
thx
spycatcher2k
Put a transistor on the ground line and use a digital pin the turn the unit On and Off.  :)
Mrs Drew
UK Based PCB Manufacturing - PM for details
I will design & code for you, but I will also charge you (PM me)
Use Google or search this site BEFORE asking!
0x776F6F74
Yeah but then I would some kind of sensor to fire up interrupt mini pro and init 4x3 keypad and rc522.
Also this sensor would need to have a low power consumption. Any ideas?
spycatcher2k
Not in original question!!!  >:(
Mrs Drew
0x776F6F74
I guess I could have been a bit more specific Im coding a medium security access control system.
Idea was to swap out the pcb in this cheap chinense electonic safe with protype pcb + mini pro + rc522 + keypad powerd by 4xAA battery series 6V. Coding is almost done only power consumption left and interrupt.
project so far done
* eeprom wear level 1.1 millon eeprom write cycles (1 KB version assuming no cell failures) floating structure 5 rfid user 1 programming card config
* 2 anti clone tricks
* Write to free sector any card in transport config and default keys mifare classic
* Buzzer, led feedback on button press and matching password or random number rfid
* 3 times wrong password 8 sec delay
* progamming mode button press wipe eeprom except wear level counter and marker
* auto reset
0x776F6F74
Set and clear powerdown bit
mfrc522.PCD_WriteRegister(0x02, 0x10);
mfrc522.PCD_WriteRegister(0x02, 0x00);
28mA reduction :)
ArakelTheDragon
#6
May 03, 2020, 09:31 pm Last Edit: May 03, 2020, 09:49 pm by ArakelTheDragon
28mA reduction :)
Thanks for this example, its very good, but the register is in char format. Can you please provide the necessary header and register name?
The format is:
mfrc522.PCD_WriteRegister(RegisterName, int byte count, int 0x00);
