Topic: ADC code for getting voltage of AREF pin of arduino pro mini 3.3v (Read 3184 times) previous topic - next topic
mnhpias
Since AREF pin of arduino pro mini 3.3v is connected to 0.1uF capacitor and this pin isn't present at breakout , it's not possible to get voltage of AREF pin by physical test ( through multi-meter ) . I  will use INTERNAL 1.1V as  reference , hence I need to know how much voltage  I will get for  INTERNAL 1.1V reference at AREF pin , hence I need a code to measure voltage of AREF pin .
Pls help me .
PaulS
Quote
I'm going to guess that chose that name because the internal reference voltage is 2.8V.
Quote
The AREF pin is an input pin. You should KNOW how much voltage you are putting in.
johnwasser
On the 32-pin surface mount packages the AREF pin is number 20 counting counter-clockwise from the PIN 1 mark.  On the 28-pin MLF package it's pin 17.  Use a fine point meter probe.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
olf2012
Search the forum for "secret voltmeter". This is a method of reading the value of Vcc assuming that the internal voltage reference has a value of 1.1V. If you have a known value of Vcc, you can then back-calculate how much AREF is.
brice3010
Pls help me .
It IS possible to use A-ref on a Pro Mini: see this page https://www.reddit.com/r/arduino/comments/57dadp/make_an_aref_pin_on_your_arduino_pro_mini_for/
It describes how to wire pin 20 to one of both reset pins after cutting the tiny track to it. I did it and it works perfectly, just use a very precise cutter and magnifying glasses.
