Topic: Arduino does not activate the digital port (Read 892 times) previous topic - next topic
Rubensg4
Hi , I'm trying to make a stand with arduino . But the digital door does not distribute energy or sometimes program is wrong.
 This is sometimes program :
  //definindo os pinos digitais  7 e 9
  //como pinos de saída.
  pinMode(8,OUTPUT);
  pinMode(9,OUTPUT);
  digitalWrite(8,LOW);
  digitalWrite(9,LOW );
//OBS:o método loop é executado repetidamente enquanto o
//arduino estiver ligado.
  digitalWrite(8,HIGH);  //liga a roda esquerda
  delay(4000);          //espera 4 segundos
  digitalWrite(9,HIGH); //liga a roda direita
  digitalWrite(8, HIGH); //liga a roda esquerda
  digitalWrite(9,HIGH); //liga a roda direita, fazendo o carrinho ir para frente
  digitalWrite(8,LOW); //desliga a roda esquerda
  digitalWrite(9,LOW); //desliga a roda direita, fazendo o carrinho ir para frente
sarouje
what is a digital door here? Are you trying to on/off led here? Please give us more details.
Sony Arouje
http://sonyarouje.com
[Please don't send Personal Messages for any Technical question, use forum instead.]
Rubensg4
The digital door is 8 and 9.
I tryign to active a mini motor using this door.
sterretje
Double check your wiring, next check it again. Please provide a schematic (scan / photo of hand-drawn one is fine) so we can see how you have (or intent to have) everything connected.
Do you have a link for the mini motor? Motors are usually not connected directly to an Arduino. Normal DC motors always need a flyback diode.
Your code will do the following (in an endless loop)
set pin 8 high
wait 4 seconds
set pin 9 high
wait 4 seconds
keep both pins high
wait 4 seconds
set both pins low
wait 4 seconds
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
UKHeliBob
How is the motor connected to pins 8 and 9 ?
Rubensg4
The + is conected with a jumper on 8 and 9. And the - is conected with a jumper on GND.
sarouje
I really not getting the connectivity, +ve is going to 8 and 9. Please share a schematic.
Sony Arouje
Rubensg4
When the + 5V is connected to the engine catches . But do not catch the entrances 8 and 9.
vaj4088
Connecting two output pins to each other is a bad idea, ESPECIALLY when one will be high and one will be low as in this sketch.
sterretje
You're connecting motors directly to the Arduino. I doubt that that is a good idea. What is the specification of those motors?
aarg
You can not safely drive this motor directly from the Arduino.
  ... with a transistor and a large sum of money to spend ...
Please don't PM me with technical questions. Post them in the forum.
6v6gt
You would be better off looking at something like these instructions for getting started.
https://learn.adafruit.com/adafruit-arduino-lesson-13-dc-motors/overview
As has been clearly  pointed out to you, your motor https://www.sparkfun.com/products/13302 cannot be driven directly from an Arduino pin which has a maximum current rating of about 25mA
