Topic: Opamp setup doubt (Read 11961 times) previous topic - next topic
polymorph
Again - you can't drive a speaker with that unless all you are trying to do is get a "buzz" output. In which case, you could skip all that fuss and just use the 2N2222.
That circuit will only source current, it cannot sink current.
Also, the way it is wired in your schematic puts nearly 9V across the speaker. I have no idea what your description of moving the 5k resistor means.
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
Southpark
#76
Jul 20, 2016, 12:21 am Last Edit: Jul 20, 2016, 12:24 am by Southpark
Yes, the circuit point is ground.  I just got the 100kΩ resistors and Ill try out the circuit.  FTR, Im trying my original circuit which is this one:
With a single transistor output..... it can put a lot of current into your speaker in one direction. (eg...when the input to the transistor goes high. But when the input to the transistor goes low .... to around 0V or so, it will turn off. So....while the 1 transistor circuit can generate a nice large positive voltage, it can't generate the negative voltage. For a pure signal (pure sinusoid), the voltage rises from zero to a maximum voltage, then it drops back to zero and keeps dropping down to a negative (absolute minimum voltage, or could say negative max). The single transistor circuit can't generate the negative voltage part of the cycle.
Well...... I guess it could do it..... if the DC voltages are designed in a particular way, but then you would need to use an output coupling capacitor and maybe run into RC charge/discharge issues at low frequencies ....leading to signal distortion.
So ... to get around this, they use a 'push-pull' configuration.... one transistor turns on to handle the positive voltage cycle, and then the other one takes over to handle the negative voltage cycle. No output capacitor needed........ so output is directly coupled to the transistor amplifier.
In your simulator....could rig up something like this to look at ....
[/quote]
Marciokoko
So like polymorph said in post #58?
I ask because I dont have a 2N2907A, but I do have a 2N3906.
I do have 10 & 100uF caps but they are electrolytic.
Southpark
Hi there marciokoko. Apologies..... yeah.... the transistors and cap values in my simulation were kind of just examples.... I just chose cap values that were large enoiugh to ensure that the capacitor impedances are very small for the AC signals.
If you have 2N3906, yeah....could certainly try that.
Marciokoko
#79
Jul 23, 2016, 02:25 am Last Edit: Jul 23, 2016, 02:26 am by Marciokoko Reason: image
Ok so Ive wired it up!  Its quite a feat just wiring it up.
Id like anyone to point out any mistakes in the wiring.  The only thing Im missing is the 1Ω-1Ω bridge between Emitter and Emitter of the 2N2222 and the PNP-3906.  The reason I dont have the 1Ω-1Ω bridge is that I dont have any 1Ω resistors...
Marciokoko
Can I skip the 1 ohm resistors?
ChrisTenone
Skip as in leave them out, or short. Use a very long wire.
What, I need to say something else too?
Marciokoko
Ok thanks.  Ill try that.
BTW, I just found this while looking for something else:
https://www.arduino.cc/en/Tutorial/SimpleAudioPlayer
This works because the mic is not producing the voltage signal, the arduino is reading it from the SD card, therefore the signal is stronger?
polymorph
It works because they are using an LM386, which is a purpose built audio amplifier, something that someone mentioned very early in this thread.
Marciokoko
#84
Aug 09, 2016, 01:32 am Last Edit: Aug 09, 2016, 01:49 am by Marciokoko
Ok I just got an LM324.  I had already ordered it before I posted, because if you recall, this post was originally taken from a tutorial that did use a LM324.  I still havent gotten the LM386 so Im wondering,
1) Should I really bother trying the circuit Southpark#76 using the LM324,
2) Or even my original circuit marciokoko#1 (which got translated to marciokoko#73)
BTW, I just noticed the LM324N is like this:
which doesnt have Vcc+ and Vcc-, but rather Vcc & GND.  Would I connect the -9V to GND pin on LN324 if I did try it?
pjrc
Well, for starters, the 2N2222 has 3 leads but you've only connected wires to 2 of them.  Likewise the 2 large capacitors are only connected one 1 of their 2 leads.
Maybe you should spends more time and effort to carefully compare your wiring to the schematic?  One useful approach is to print the schematic and use a colored pen.  For each physical wire, look at the 2 places it actually connects and draw over the wire on your schematic.  If you do this, because those parts have not connection at all on some of their leads, you'll end up with parts of the schematic that aren't colored in.
Marciokoko
Yes the 2 transistors are missing their connection because I was waiting for the 1Ω resistors, but ill use the long wire instead.
The caps I haven't wired them up because I was re-wiring everything when I realized the LM324N was different in the sense that it doesnt have a Vcc- and Vcc+.  How should I wire that part up, Vcc- to GND-LM324 and Vcc+ to Vcc-LM324?
Thanks
ChrisTenone
Thanks
Either a negative voltage, or a ground will work. Ground is V- when it's numeric value is zero volts. Using ground will make it a "single supply" amplifier, meaning that it's range will be cut off on the bottom.  Note that some data sheets call it GND, and some call it V-. Like this:
pjrc
From the length of this thread, it probably seems like you can request an unlimited amount of time & effort from the community to provide design assistance.  Why bother getting things right, or even mentioning the things you know are wrong, or even go to the trouble to get a set of good photos which shows the whole build and gives multiple angles to view all parts?
Quote
Bad idea.  Maybe someone will write a lengthy explanation.
Thanks
[/quote]
Marciokoko
Ok I connected some jumpers and got their ohms to be 1Ω.  The issue Im dealing with is that because I had a split power supply set up and Im connecting the opamp's GND to vcc- on the split supply, I have some things connected to ground and others connected to vcc-.
Connected to Ground (midway between vcc- and vcc+):
mic
speaker
10uF cap on the way to v+ opamp
opamp negative feedback loop
Connected to Vcc- from split supply
GND opamp
100uF (Vo) thru 10k R
2n3906 collector
ChrisTenone, I read your reply #87 but i want to make sure I understand it right before firing this up.  According to what I have, GND on opamp would be connected to -9V as well as the 100uF (Vo) thru 10k R and the 2n3906.  Should I move these to real ground which will actually be 0V because it is in the middle of the 2 9V batteries?
Thanks
