Topic: using irRemote from other library (Read 886 times) previous topic - next topic
_butch_
Hi all,
Background of the project:
I want to control some lego power function devices by arduino via infrared, but I want to replace both, sender and receiver, with arduino and custom protocol to allow more accurate steering and to have more   outputs available.
For better re-usability I thought of creating a receiver library which is doing the protocol handling, etc. but is implementing  the library irRemote for doing the IR part.
But here comes my problem, which I do not understand: If i call irRemote from another library, i get only garbage as result from irRemote. If I call the same code from the ino the results are fine.
So, hopefully somebody can explain me where my problem is:
code which is working (using irRemote directly from ino)
ino file
Code: [Select]
#include "Arduino.h"
#include <IRremote.h>
const int RECV_PIN = A5;
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn(); // Start the receiver
  irrecv.blink13(true);
  Serial.println ("starting direct sketch");
  if (irrecv.decode(&results)) {
    if (results.decode_type == NEC) {
      Serial.print("NEC: ");
    } else if (results.decode_type == SONY) {
      Serial.print("SONY: ");
    } else if (results.decode_type == RC5) {
      Serial.print("RC5: ");
    } else if (results.decode_type == RC6) {
      Serial.print("RC6: ");
    } else if (results.decode_type == UNKNOWN) {
      Serial.print("UNKNOWN: ");
    Serial.println(results.value, HEX);
    irrecv.resume(); // Receive the next value
Here I always get the following output if I press
NEC: FFA25D
Now comes my problem:
code which is faulty using irRemote from other library
ino file
Code: [Select]
#include "ReceiverLibTest.h"
//The setup function is called once at startup of the sketch
ReceiverLibTest irReceiver;
// Add your initialization code here
Serial.println("Starting lib sketch");
// The loop function is called in an endless loop
irReceiver.processData();
library cpp
Code: [Select]
// Do not remove the include below
#include "IRremote.h"
#define IR_RECEIVE_PIN A5
IRrecv irrecv(IR_RECEIVE_PIN);
ReceiverLibTest::ReceiverLibTest()
// instanciate the infrared library on given pin
// start the IR Receiver
void ReceiverLibTest::processData()
Here, if i press the standby button on my remote again, i allways get random values:
UNKNOWN: E9E70E8D
UNKNOWN: CF51C16E
UNKNOWN: E1886D7F
UNKNOWN: 4BCF0C40
So, what is the problem here? Can anyone explain this behavior?
Thanks, butch
larryd
Maybe there is a device mismatch.
This may not help but might be interesting:
NEC library
http://forum.arduino.cc/index.php?topic=317625.0
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
_butch_
I am still using the same remote and the same button. Somehow it cannot detect the protocol correctly if I am using it from another lib.
larryd
Make sure your remote battery is new.
No technical PMs.
_butch_
It has something to do with the programming.
Because the remote stays constant. I can switch / upload the two sketches as often as I want. It works on version 1 and reads garbage on version 2 (called within another lib).
So it is definetly code related.
gpsdrew
I am having a similar problem. Did anyone figure this out?
larryd
If you have a problem start your 'own' thread and describe your situation.
No technical PMs.
