Topic: Arduino DUE + SD Card (Read 2895 times) previous topic - next topic
rafo
Hello everyone!
Can anyone explain me how I can connect sd card to arduino due and work with it?
spycatcher2k
Yes
You connect it with wires and write code.
Have you tried GOOGLE? I did and found hundreds of tutorials.
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
rafo
http://forum.arduino.cc/index.php/topic,135439.msg1018776.html#msg1018776
I used SDFat but nothing I don't thing that code is wrong I connected SD with wires to arduino due
Here is arduino connections
http://prntscr.com/bqbym0
http://prntscr.com/bqbysy
Palliser
Hello rafo.
My Due works OK using this library:
https://github.com/adafruit/SD
You can try the following example:
Code: [Select]
#include <SPI.h>
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
const int chipSelect = 4;
  Serial.println("\nInitializing SD card...");
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed.");}
  volume.init(card);
  root.openRoot(volume);
  root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
-p
sticmer
Yes
Yeah I did ZERO WORKED.....
