Topic: Control led with relay  (Read 900 times) previous topic - next topic
dimitrird
Jul 08, 2016, 05:48 am Last Edit: Jul 08, 2016, 02:49 pm by dimitrird
Hello I have an arduino uno, a shield 4 relays for controlling a motor in 2 directions by voice command, so I first wanted to try to run the relay without voice control with LED or a 12v fan pc, nothing works, I have the 12 volt external power required, one for the fan but nothing, I'm the click of the 4 relays with this code:
Code: [Select]
// Define constants and variables
const int out1 = 5; // define Arduino pin connected to relay 1
const int out2 = 6; // define Arduino pin connected to relay 2
const int out3 = 7; // define Arduino pin connected to relay 3
const int out4 = 8; // define Arduino pin connected to relay 4
// Initialization
pinMode(out1, OUTPUT); // initialize the digital pin as an output
pinMode(out2, OUTPUT); // initialize the digital pin as an output
pinMode(out3, OUTPUT); // initialize the digital pin as an output
pinMode(out4, OUTPUT); // initialize the digital pin as an output
Serial.begin(9600);    // Serial Port initialization
// enable or disable a relay (1 to 4)
void setRelay(int relay, int value)
if(relay > 0 && relay < 5) digitalWrite((relay + 4), value);
// main loop
setRelay(1, 1);                        // enable relay 1
Serial.print("Relay 1: Enabled ... ");
delay(1000);                           // wait for a second
setRelay(1, 0);
Serial.println("Disabled");            // disable relay 1
setRelay(2, 1);                        // enable relay 2
Serial.print("Relay 2: Enabled ... ");
setRelay(2, 0);                        // disable relay 2
setRelay(3, 1);                        // enable relay 3
Serial.print("Relay 3: Enabled ... ");
setRelay(3, 0);                        // disable relay 3
setRelay(4, 1);                        // enable relay 4
Serial.print("Relay 4: Enabled ... ");
setRelay(4, 0);                        // disable relay 4
I also tried this:
Code: [Select]
pinMode(5, OUTPUT);
digitalWrite(5, HIGH); delay(1000);
digitalWrite(5, LOW); delay(1000);
But nothing, what should I do? Thank you for answering me .
Best regards .
Grumpy_Mike
#1
Jul 08, 2016, 06:10 am Last Edit: Jul 08, 2016, 06:14 am by Grumpy_Mike
Quote
what should I do?
Read the how to use this forum sticky post. Then edit that first post to put the code in code tags.
Then post a schematic, not a Fritzing layout abortion, of your circuit. Pen and paper to draw it is fine.
dimitrird
Thank you for the answer, I tried to do what I could for the schematic ,for  information to the shield 4 relay is mounted directly on Arduino and has a power supply unit 12 dc. Best regards
Grumpy_Mike
Quote
So where is it?
Quote
Sorry but that doesn't describe anything precise enough to be useful.
dimitrird
So where is it?
the schematic is attached with the message
The shield is MR007-002.
Best regards
Grumpy_Mike
What is missing is the labelling on the relay output. The wires you should be using will be called common and N/O for normally open.
If the fan still will not go on when the relay clicks then it is not wired as your diagram.
dimitrird
How do I do please?
Best Regards.
Grumpy_Mike
Are you asking me how to connect wires to a thing that you have already connected wires to?
I am telling you what connections to attach the wires to. I am not sure there is any more information to give.
dimitrird
Good evening, the shield 4 relay has 2 pins on each trip, I just program the relay 3 to 4 seconds of contact, and 2 seconds of opening, I mean well over except that the 2-pin OUT-3 I n 'have anything that comes out the multimeter, what to do?
Best regards.
runaway_pancake
The attached drawing shows an example using Relay_4 of a 4-relay board.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
dlloyd
Link to the MR007-002 shield.
Note there's a "Run/Prog" switch ... did you put it back in "Run" mode after programming?
Looks like there's only 2 terminals per relay ... probably NO and COM.
Just connect 12V to one terminal and the fan +12V wire to the other.
The relay board needs power, the Arduino needs power and the fan needs switched power ... show us a diagram/sketch of your connections.
Grumpy_Mike
Quote
Just connect .......
Just like you showed on your origional diagram you posted. Make sure the connection are for the relay you are switching. Test this with the continuity setting of your meter.
dlloyd
Yeah, Just like you showed on your original diagram you posted.
dimitrird
#13
Jul 12, 2016, 02:12 am Last Edit: Jul 12, 2016, 02:18 am by dimitrird
HELLO in fact, it was the tension that was not 12v , now here is the code that works but I would put a timer to turn off the relay , thank you to answer me . Best regards
#include "Arduino.h"
#if !defined(SERIAL_PORT_MONITOR)
  #error "Arduino version not supported. Please update your IDE to the latest version."
#endif
#if defined(SERIAL_PORT_USBVIRTUAL)
  // Shield Jumper on HW (for Leonardo and Due)
  #define port SERIAL_PORT_HARDWARE
  #define pcSerial SERIAL_PORT_USBVIRTUAL
#else
  // Shield Jumper on SW (using pins 12/13 or 8/9 as RX/TX)
  #include "SoftwareSerial.h"
  SoftwareSerial port(12, 13);
  #define pcSerial SERIAL_PORT_MONITOR
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
//Groups and Commands
enum Groups
  GROUP_1  = 1,
enum Group1
  G1_OUVRIR = 0,
  G1_FERMER = 1,
int8_t group, idx;
  // setup PC serial port
  pcSerial.begin(9600);
  // bridge mode?
  int mode = easyvr.bridgeRequested(pcSerial);
  switch (mode)
  case EasyVR::BRIDGE_NONE:
    // setup EasyVR serial port
    port.begin(9600);
    // run normally
    pcSerial.println(F("---"));
    pcSerial.println(F("Bridge not started!"));
  case EasyVR::BRIDGE_NORMAL:
    // setup EasyVR serial port (low speed)
    port.begin(9600);
    // soft-connect the two serial ports (PC and EasyVR)
    easyvr.bridgeLoop(pcSerial);
    // resume normally if aborted
    pcSerial.println(F("Bridge connection aborted!"));
  case EasyVR::BRIDGE_BOOT:
    // setup EasyVR serial port (high speed)
    port.begin(115200);
  while (!easyvr.detect())
    Serial.println("EasyVR not detected!");
  easyvr.setPinOutput(EasyVR::IO1, LOW);
  Serial.println("EasyVR detected!");
  easyvr.setTimeout(5);
  easyvr.setLanguage(5);
  group = GROUP_1; //lancement du groupe (customisé)
  pinMode(7, OUTPUT); // NE PAS METTRE PIN 12 OU 13 DEJA UTILISES PAR LE SERIAL
void action();
  if (easyvr.getID() < EasyVR::EASYVR3)
    easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
  Serial.print("Say a command in Group ");
  Serial.println(group);
  easyvr.recognizeCommand(group);
  do
    // can do some processing while waiting for a spoken command
  while (!easyvr.hasFinished());
    easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
  idx = easyvr.getWord();
  if (idx >= 0)
    // built-in trigger (ROBOT)
    // group = GROUP_X; <-- jump to another group X
    return;
  idx = easyvr.getCommand();
  if (idx >= 0)
    // print debug message
    uint8_t train = 0;
    char name[32];
    Serial.print("Command: ");
    Serial.print(idx);
    if (easyvr.dumpCommand(group, idx, name, train))
      Serial.print(" = ");
      Serial.println(name);
   // beep
    easyvr.playSound(0, EasyVR::VOL_FULL);
    // perform some action
    action();
  else // errors or timeout
    if (easyvr.isTimeout())
      Serial.println("Timed out, try again...");
    int16_t err = easyvr.getError();
    if (err >= 0)
      Serial.print("Error ");
      Serial.println(err, HEX);
void action()// la LED s'allume quand on dit OUVRIR et s'éteint avec FERMER
 switch (group)
   case GROUP_1:
     switch (idx)
     case G1_OUVRIR:
          digitalWrite(7, HIGH);
          group = GROUP_1;
       case G1_FERMER:
         digitalWrite(7, LOW);
         group = GROUP_1;
Dimitri .
