Topic: Help with Servo motors and Serial (Read 669 times) previous topic - next topic
conz2512
Jul 11, 2016, 04:02 pm Last Edit: Jul 11, 2016, 05:25 pm by conz2512
I'm using an Arduino Uno board along with a Parallax Inc Servo Motor, 6 → 8.4 V, 180 rpm.
I am trying to use this to move a piece of paper to change an intensity value on a camera or photoresistor.
I am hoping to make it rotate fast at first until it finds the minimum then pause. After this it should check the intensity again and then rotate backwards slowly until it finds it (due to overshooting it before). Then repeating this in the opposite direction slower and stopping once more at the minimum value.
I was wondering how I would do this as I previously was using several if statements and delays.
Code: [Select]
#include<Servo.h>
Servo halfWave; //Servo Motor name
const int servPin1 = 9; //Pin the Servo is attached to (See Below)
 pinMode(servPin1, OUTPUT);
 halfWave.attach(9);
 Serial.println("Ready"); //Signal to LabVIEW
 while(Serial.available() == 0);
 String intensity = Serial.readString();
 int intenVal = intensity.toInt(); //Need the integer value of the Intensity
 do {
   halfWave.write(180);  //If the intensity isn't right then it rotates the servo continuously until it is low
enough
 }while(intenVal != 200);
This is currently what I have to find the minimum the first time, but now I am wondering how it can check it again after this and then do another "do" loop but at a slower speed.
Robin2
Please modify your post and use the code button </>
Code: [Select]
so your code looks like this and is easy to copy to a text editor. See How to use the Forum
I presume you are using a continuous rotation servo - which is just a DC motor in a convenient package.
Don't use the String (capital S) class - it can cause memory problems in the small Arduino memory.
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data. There is also a parse example.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
conz2512
It doesn't seem to work with string rather than String.
And it isn't exactly the Servo I am having trouble with, its more my code.
MorganS
The does doesn't attempt to do what you explained.
When the thing is just spinning, how do you expect it to get exactly 200 intensity without over or under? Use greater-than and less-than comparisons.
"The problem is in the code you didn't post."
Robin2
It will if the code is correct.
Quote
Post the latest version of your code
Make a simpler version of the program that works with a fixed value rather than a value that comes from the serial port.
...R
