Topic: Programming and connections help (Read 425 times) previous topic - next topic
shashi9819
Hello,
i am trying to build A 3 axis small CNC miling machine. i have selected following motor, driver and power supply.
1)motor : http://robokits.co.in/motors/dc-servo-motor-24v-100w-with-2000-ppr-encoder?cPath=2_71&
2) driver : http://robokits.co.in/motors/encoder-dc-servo/dc-servo-motor-driver-40v-20a-w-t-step-direction-input
3) power supply : http://robokits.co.in/power-supply
i am using arduino as a controller.
as  i am new to arduino. i need code for testing this motor for continuous rotation. and stop there until further signal
thnaks
shashi9819
Robin2
If it just takes step and direction inputs like a stepper motor then this Simple Stepper Code should be suitable for testing.
If not I have nothing else to suggest.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
shashi9819
ok i will try the code.. thnks for help :) (Y)
shashi9819
...R
can u provide the link to circuit diagram ?
thnks
Robin2
The code I wrote assumes the wiring arrangements on the Pololu A4988 web page.
It should be easy to adapt that to any driver that takes step and direction signals.
You should check your documentation to see if your driver requires the enable pin to be connected and whether it should be HIGH or LOW to make the motor work. It can be left unconnected on the A4988 board.
...R
Robin2
@akshayhd, your question has nothing to do with @shashi9819's problem. I have suggested to the Moderator to move it to its own Thread.
...R
