Topic: Can-Bus (Read 10176 times) previous topic - next topic
coryjfowler
OBD has two modes when used over CAN, 11bit and 29bit and while I am not familiar with the Arduino OBD library, I am familiar with the fact my vehicle will not work with 11bit mode and required 29bit mode on the scan tool I was using.  You would need to determine what modes the library supports and if only one mode is supported, that is likely why you are not getting any values returned and the library would need updated.
"Taking the time to make a proper, punctuated, post is a mark of courtesy and respect."  http://forum.arduino.cc/index.php?topic=149022.0
Nobel_Tanmay
Hi Guys,
Its a little urgent. Please help.
I have a arduino mkr can bus shield mounted on arduino mkrzero board. I have a can bus device that connects to the can bus shield. I can to read the data received from that CAN device on the arduino IDE serial monitor. How can I read the data recieved. Should I use SPI from mkr zero or some others pins to monitor this data?
Can some one please share the code to read this data somehow?
I have the picture of the assemble attached.
Thanks,
Nobel_Tanmay
#17
Feb 08, 2019, 10:08 pm Last Edit: Feb 08, 2019, 10:10 pm by Nobel_Tanmay
Picture of the assembly
Nobel_Tanmay
I was trying to use this code but the can bus shield always fails to initialize.
// demo: CAN-BUS Shield, receive data with check mode
// send data coming to fast, such as less than 10ms, you can use this way
// loovee, 2014-6-13
#include <SPI.h>
#include "mcp_can.h"
// the cs pin of the version after v1.1 is default to D9
// v0.9b and v1.0 is default D10
const int SPI_CS_PIN = 3;
MCP_CAN CAN(SPI_CS_PIN);                                    // Set CS pin
    while (CAN_OK != CAN.begin(CAN_500KBPS))              // init can bus : baudrate = 500k
        Serial.println("CAN BUS Shield init fail");
        Serial.println(" Init CAN BUS Shield again");
        Serial.println("check");
        delay(100);
    Serial.println("CAN BUS Shield init ok!");
    unsigned char len = 0;
    unsigned char buf[8];
    if(CAN_MSGAVAIL == CAN.checkReceive())            // check if data coming
        CAN.readMsgBuf(&len, buf);    // read data,  len: data length, buf: data buf
        unsigned int canId = CAN.getCanId();
        Serial.println("-----------------------------");
        Serial.print("Get data from ID: ");
        Serial.println(canId, HEX);
        for(int i = 0; i<len; i++)    // print the data
            Serial.print(buf, HEX);
            Serial.print("\t");
  END FILE
Les_Collier
Hi the code you have looks very similar to mine, so I don't think it's code.  I found that I got the failed to initialise if there was no power on the board, although I have to say this is clutching at straws as your picture shows what looks like good connections.
amondays
hello how to connect the car? I'm using an OBD2 connector with CAN H and CAN L connectors. DB9 connector with arduino canbus shield. Is that right? Thank you! The codes displayed here do not yield results..
