Topic: Tips on Elegoo robot car, only moves 1 side of wheels (Read 4649 times) previous topic - next topic
totalimpact
So I got this Elegoo robot car on amazon, line tracking, ultra sonic...
I run the 3-4 individual code samples for back/forth, and the line tracing works perfect.
But when I run the example for the obstacle avoidance, it only spins the left set of tires. I have looked through it and cant find why it always wants to go left, it has HC-SR04 ultra sonic module on a servo. I have tried re-aligning the head on the servo, no change.
Here is the code I use on it.
Code: [Select]
#include <Servo.h> //servo library
Servo myservo; // create servo object to control servo
int Echo = A4;
int Trig = A5;
int in1 = 6;
int in2 = 7;
int in3 = 8;
int in4 = 9;
int ENA = 5;
int ENB = 10;
int ABS = 110;
int rightDistance = 0,leftDistance = 0,middleDistance = 0 ;
void _mForward()
 analogWrite(ENA,ABS);
 analogWrite(ENB,ABS);
 digitalWrite(in1,LOW);
 digitalWrite(in2,HIGH);
 digitalWrite(in3,LOW);
 digitalWrite(in4,HIGH);
 Serial.println("go forward!");
void _mBack()
 digitalWrite(in1,HIGH);
 digitalWrite(in2,LOW);
 digitalWrite(in3,HIGH);
 digitalWrite(in4,LOW);
 Serial.println("go back!");
void _mleft()
 Serial.println("go left!");
void _mright()
 Serial.println("go right!");
void _mStop()
  digitalWrite(ENA,LOW);
  digitalWrite(ENB,LOW);
  Serial.println("Stop!");
 /*Ultrasonic distance measurement Sub function*/
int Distance_test()
  digitalWrite(Trig, LOW);
  delayMicroseconds(2);
  digitalWrite(Trig, HIGH);
  delayMicroseconds(20);
  float Fdistance = pulseIn(Echo, HIGH);
  Fdistance= Fdistance/58;
  return (int)Fdistance;
  myservo.attach(3);// attach servo on pin 3 to servo object
  pinMode(Echo, INPUT);
  pinMode(Trig, OUTPUT);
  pinMode(in1,OUTPUT);
  pinMode(in2,OUTPUT);
  pinMode(in3,OUTPUT);
  pinMode(in4,OUTPUT);
  pinMode(ENA,OUTPUT);
  pinMode(ENB,OUTPUT);
  _mStop();
    myservo.write(90);//setservo position according to scaled value
    middleDistance = Distance_test();
    #ifdef send
    Serial.print("middleDistance=");
    Serial.println(middleDistance);
    #endif
    if(middleDistance<=20)
      _mStop();
      myservo.write(5);
      rightDistance = Distance_test();
      #ifdef send
      Serial.print("rightDistance=");
      Serial.println(rightDistance);
      #endif
       myservo.write(90);
      myservo.write(180);
      leftDistance = Distance_test();
      #ifdef send
      Serial.print("leftDistance=");
      Serial.println(leftDistance);
      #endif
      myservo.write(90);
      if(rightDistance>leftDistance)
        _mright();
        delay(180);
       else if(rightDistance<leftDistance)
        _mleft();
        delay(180);
       else if((rightDistance<=20)||(leftDistance<=20))
        _mBack();
        delay(180);
        _mForward();
        _mForward();
handy99
hi it looks like the servo library uses pin 9 and 10 i moved pin 10 to 11 and changed it is the program int ENB =11 and now it works fine
detach()
Description
Detach the Servo variable from its pin. If all Servo variables are detached, then pins 9 and 10 can be used for PWM output with analogWrite().
Syntax
servo.detach()
Parameters
servo: a variable of type Servo
See also
attach()
attached()
Reference Home
Corrections, suggestions, and new documentation should be posted to the Forum.
The text of the Arduino reference is licensed under a Creative Commons Attribution-ShareAlike 3.0 License. Code samples in the reference are released into the public domain.
Share
Servo
attach()
Description
Attach the Servo variable to a pin. Note that in Arduino 0016 and earlier, the Servo library supports only servos on only two pins: 9 and 10.
Syntax
servo.attach(pin)
servo.attach(pin, min, max)
Parameters
pin: the number of the pin that the servo is attached to
min (optional): the pulse width, in microseconds, corresponding to the minimum (0-degree) angle on the servo (defaults to 544)
max (optional): the pulse width, in microseconds, corresponding to the maximum (180-degree) angle on the servo (defaults to 2400)
Example
#include <Servo.h>
Servo myservo;
  myservo.attach(9);
void loop() {}
See also
attached()
detach()
Reference Home
Share
rcacacho
could share the code example I am new to Arduino
aishen
I just tried Robot car  version 1
I had to change motors connection (1red/1black, not 2 red/2blacks)
I am wondering if changing pin 10 to 11 is a good idea (as elegoo suggest, but I change tracking module one to pin 10 because it was on eleven ? I haven't tried yet but does someone did it ?
Any suggestion ?
Regards
Henri
duino_nano
Did you tried to display, on the Serial Monitor, the distance that the HC-SR04 read?
My question is because I dont see in your program (section "setup") a small instruction to initiate the SR04 such as:
PWM_Mode_Setup();
Code: [Select]
{ Serial.begin(9600);                   // 9600 bauds pour connexion série
  PWM_Mode_Setup();
void PWM_Mode_Setup()
      { pinMode(URTRIG,OUTPUT);                           // A low pull on pin COMP/TRIG
        digitalWrite(URTRIG,HIGH);                           // Set to HIGH
        pinMode(URPWM, INPUT);                             // Sending Enable PWM mode command
        for(int i=0;i<4;i++)
            { Serial.write(EnPwmCmd[i]);}
