Topic: Radio code appears to be interfering with other functions. (Read 4317 times) previous topic - next topic
moose4621
The overview.
The plan is to have a hand held controller (client) with a few buttons to change settings like setpoint, on/off, height, etc, and store them in "radioTxArray". It then transmits this array via nrf24L01 radio to the server which the replies with the actual rpm of the motor. This is then displayed on the lcd.
At the other end, the server receives the array and stores it as "radioRxArray" and the sets the setpoint for the motor and controls its rpm via a PID algorithm. (Big thankyou to zhomeslice for his invaluable input in to the motor control). It then sends the actual rpm to the client in reply. The server will also have a ping sensor, current sensor and relay attached.
I have two nrf24L01 radios that talk to each other and send the arrays as I expect using a modified version of the RadioHead nrf24 reliable datagram example. I replaced the delay with a timer and inserted an array with fixed data.
These two sketches seem to work well.
Client modified example.
Code: [Select]
#include <RHReliableDatagram.h>
#include <RH_NRF24.h>
#include <SPI.h>
#define CLIENT_ADDRESS 1001
#define SERVER_ADDRESS 1002
LiquidCrystal_I2C lcd(0x27, 16, 2); // set the LCD address to 0x27 for a 16 chars and 2 line display
// Singleton instance of the radio driver
RH_NRF24 driver(9, 10);
// RH_NRF24 driver(8, 7);   // For RFM73 on Anarduino Mini
// Class to manage message delivery and receipt, using the driver declared above
RHReliableDatagram manager(driver, CLIENT_ADDRESS);
uint8_t radioTxArray[6];//radioTxArray[6];
uint8_t buf[RH_NRF24_MAX_MESSAGE_LEN];
int rpm;
  lcd.init();                      // initialize the lcd
  lcd.backlight();
  if (!manager.init())
    Serial.println("init failed");
  // Defaults after init are 2.402 GHz (channel 2), 2Mbps, 0dBm
  radioTxArray[0] = 0;
  radioTxArray[1] = 30;
  radioTxArray[2] = 1;
  radioTxArray[3] = 0;
  radioTxArray[4] = 137;
  radioTxArray[5] = 0;
  static unsigned long RadioTimer;
  if ((unsigned long)(millis() - RadioTimer) >= 500) {
    RadioTimer = millis();
    Serial.println("Sending to nrf24_reliable_datagram_server");
    // Send a message to manager_server
    if (manager.sendtoWait(radioTxArray, sizeof(radioTxArray), SERVER_ADDRESS))
      // Now wait for a reply from the server
      uint8_t len = sizeof(buf);
      uint8_t from;
      if (manager.recvfromAckTimeout(buf, &len, 2000, &from))
        lcd.clear();
        lcd.setCursor(0, 0);
        lcd.print("Reply from: 0x");
        lcd.print(from, HEX);
        //Serial.print("rpm= ");
        //Serial.print(rpm);
        //Serial.print(" 1= ");
        //Serial.print(buf[1]);
        rpm = (buf[0]);
        lcd.setCursor(0, 1);
        lcd.print("    RPM = ");
        lcd.print(rpm);
        lcd.clear();
        lcd.print("No reply");
        Serial.println("No reply, is nrf24_reliable_datagram_server running?");
      Serial.println("sendtoWait failed");
    //delay(500);
Server modified example.
Code: [Select]
// nrf24_reliable_datagram_server.pde
// -*- mode: C++ -*-
// Example sketch showing how to create a simple addressed, reliable messaging server
// with the RHReliableDatagram class, using the RH_NRF24 driver to control a NRF24 radio.
// It is designed to work with the other example nrf24_reliable_datagram_client
// Tested on Uno with Sparkfun WRL-00691 NRF24L01 module
// Tested on Teensy with Sparkfun WRL-00691 NRF24L01 module
// Tested on Anarduino Mini (http://www.anarduino.com/mini/) with RFM73 module
// Tested on Arduino Mega with Sparkfun WRL-00691 NRF25L01 module
#include <SPI.h>
RH_NRF24 driver(7, 8);
RHReliableDatagram manager(driver, SERVER_ADDRESS);
int rpm = 35;
int radioRxArray[6];
//int radioTxArray[2];
uint8_t radioTxArray[2];
  radioTxArray[0] = rpm;
  radioTxArray[1] = 1;
uint8_t data = rpm;
// Dont put this on the stack:
//uint8_t buf[RH_NRF24_MAX_MESSAGE_LEN];
    if (manager.available())
      // Wait for a message addressed to us from the client
      uint8_t from;
      if (manager.recvfromAck(buf, &len, &from))
        radioRxArray[0] = buf[0];
        radioRxArray[1] = buf[1];
        radioRxArray[2] = buf[2];
        radioRxArray[3] = buf[3];
        radioRxArray[4] = buf[4];
        radioRxArray[5] = buf[5];
        Serial.print("got request from : 0x");
        Serial.print(from, HEX);
        Serial.print(": 0= ");
        Serial.print(radioRxArray[0]);
        Serial.print(": 1= ");
        Serial.print(radioRxArray[1]);
        Serial.print(": 2= ");
        Serial.print(radioRxArray[2]);
        Serial.print(": 3= ");
        Serial.print(radioRxArray[3]);
        Serial.print(": 4= ");
        Serial.print(radioRxArray[4]);
        Serial.print(": 5= ");
        Serial.print(radioRxArray[5]);
        Serial.print(" millis ");
        Serial.println(millis());
        // Send a reply back to the originator client
        if (!manager.sendtoWait(radioTxArray, sizeof(radioTxArray), from))
Next post |
MarkT
Presumably its the 2s timeout in recvFromAckTimeout() that's the issue - you are busy-waiting,
not polling using recvFromAck()
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
moose4621
Now the problem. :smiley-confuse:
On the client end, I can run my sketch reading buttons and printing to lcd and saving to radioTxArray and it all works as expected as long as I have the radio section, "exchageData" commented out. When I uncomment the "exchangeData", it transmits the array ok, but the buttons become almost unresponsive. ie, they will work if you persist for long enough.
Client controller.
Code: [Select]
#include <Streaming.h>
#include <EEPROM.h>
#include <SPI.h>
#include <Bounce2.h>
//=======For the radio======
uint8_t radioTxArray[6];//Array with 6 positions.
//0 = On/Off, 1 = SetPoint, 2 = , 3 = Height, 4 = Cal, 5 = Dist
const int radioDelay = 500;
unsigned long previousRadioMillis = 0;
//====For the buttons====
const byte ButtonPins[] = {4, 5, 6, 7, 3};
Bounce buttons[] =
{Bounce(), Bounce(), Bounce(), Bounce(), Bounce()};
//this order should match the order of the buttons. I had no idea...
enum {B_UP, B_DOWN, B_CAL, B_HEIGHT, B_START};
int runTimer = 1;//For Cal timer
int runFor = 60; //Cal run interval
int seconds;
int setpointVariable;
int rpm;
int dist;
int address = 0;
bool isStarted = false;
bool isCal = false;
bool isHeight = false;
bool isDist = false;
unsigned long currentMillis = 0;
  radioTxArray[0] = 0;// sets motor to off at start up.
  for (byte b = 0; b < sizeof(ButtonPins); b++) {
    pinMode (ButtonPins[b], INPUT_PULLUP);
    buttons[b].attach(ButtonPins[b]);
    buttons[b].interval(15); //15ms debounce interval
  lcd.backlight();
  lcd.setCursor(3, 0);
  lcd.print(" Seabrook");
  lcd.setCursor(5, 1);
  lcd.print("Seeders");
  delay(2000);
  lcd.clear();
  lcd.print("Seedr Controller");
  lcd.setCursor(1, 1);
  lcd.print("by Chris Dalby");
  delay(2000);
  lcd.clear();
  lcd.print("Set RPM  ");
  lcd.print(setpointVariable);
  Serial.println("powered up");
  delay(2000);
  Serial.println("wifi Seeder Controller client r6");
  setpointVariable = EEPROM.read(0);
  dist = EEPROM.read(1);
  readButtons();
  checkStartStop();
  adjRequiredRpm();
  calibration();
  heightSensor();
  adjHeight();
  menuSelect();
  displayRpm();
  exchangeData();
  writeToEeprom();
  currentMillis = millis();
  //  sendDatatoServer();//Send RequiredRpm & Start/Stop to Server.
void readButtons() {
  for (byte i = 0; i < sizeof(ButtonPins); i++) {
    buttons[i].update();
void checkStartStop()
  if (buttons[B_START].fell()) {
    if (isStarted == false) {
      isStarted = true;
      radioTxArray[0] = 1;
    else {
      isStarted = false;
void adjRequiredRpm() {
  if (buttons[B_UP].fell() && isCal == false && isHeight == false) {
    setpointVariable++;
    if (setpointVariable > 60) {
      setpointVariable = 60;
  if (buttons[B_DOWN].fell()) {
    setpointVariable = setpointVariable - 1;
    if (setpointVariable < 10) {
      setpointVariable = 10;
  radioTxArray[1] = setpointVariable;
void calibration() {
  if (buttons[B_CAL].fell() && isStarted == false) {
    if (isCal == false) {
      isCal = true;
      radioTxArray[4] = 1;
    else {
      isCal = false;
      radioTxArray[4] = 0;
void heightSensor() {
  if (buttons[B_HEIGHT].fell()) {
    if (isHeight == false) {
      isHeight = true;
      //isCal = false;
      radioTxArray[3] = 1;
    else {
      isHeight = false;
void adjHeight() {
  if (buttons[B_UP].fell() && isDist == true) {
    dist++;
    if (dist > 150) {
      dist = 150;
  if (buttons[B_DOWN].fell() && isDist == true) {
    dist = dist - 1;
    if (dist < 10) {
      dist = 10;
  radioTxArray[5] = dist;
void menuSelect() {
  if (buttons[B_CAL].fell() && isStarted == false && isCal == true) {
    if (isDist == false) {
      isDist = true;
    else {
      isDist = false;
void displayRpm() {
  if (isCal == true && isStarted == false) {
    lcd.print("Calibration Mode ");
    lcd.print("Press start     ");
  else if (isCal == true && isStarted == true) {
    lcd.print("Motor ");
    lcd.print(F("On   "));
    lcd.print("60");
    lcd.print("sec");
  else if (isDist == true) {
    lcd.print("Adjust height to");
    lcd.print("switch at ");
    lcd.print(dist);
    lcd.print("cm");
  else {
    if (isHeight == true) {
      lcd.print("    H");
    else {
      lcd.print("     ");
    if (isStarted) {
    else {
      lcd.print(F("Off"));
    lcd.print(" RPM ");
    lcd.print(rpm);
  Serial.print(radioTxArray[0]);
  Serial.print(radioTxArray[1]);
  Serial.print(radioTxArray[2]);
  Serial.print(radioTxArray[3]);
  Serial.print(radioTxArray[4]);
  Serial.print(radioTxArray[5]);
  Serial.print("  pin 6 = ");
  Serial.println(digitalRead(6));
void exchangeData()  {
  //   if (currentMillis - previousRadioMillis >= radioDelay){
  //previousRadioMillis += radioDelay;
    uint8_t from;
      Serial.print("got reply from : 0x");
      Serial.print("0= ");
      Serial.print(buf[0]);
      rpm = (buf[0]);
void writeToEeprom()
  EEPROM.update(0, setpointVariable);
  EEPROM.update(1, dist);
Now, I know I am a bit simple, but I really would like to get this going so if anyone can point me in the right direction, I would really appreciate it.
I know Robin2 has suggested to me on more than one occasion to use the tmrh libraries instead of radiohead and I accept your advise. If that may be the cause of the problem I would need a hand to get that running since the example didn't run on first attempt.
Thanks
moose4621
Wow, that was quick. Thanks MarkT. I did assume that if a response was received, there would be no delay? I will read up on this, thanks.
Robin2
That sounds like a situation in which using the ackPayload facility would be very appropriate. It means that the response is received without any need for either the Handheld or the "server" to swap states. It is one of those magic things that "just works"
Have a look at the pair of programs in this link
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
moose4621
...R
Thanks Robin2, You have finally convinced me to persevere with the tmrh version using your examples.
I have modified the client and it seems to be working well. I will change the master after work and let you know.
Thanks again.
Code: [Select]
#include <EEPROM.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <SPI.h>
#define CE_PIN 9
#define CSN_PIN 10
// NOTE: the "LL" at the end of the constant is "LongLong" type
const uint64_t   deviceID = 0xE8E8F0F0E1LL; // Define the ID for this slave
RF24 radio(CE_PIN, CSN_PIN);
int radioTxArray[6];//Array with 6 positions.
int radioRxArray[2];
Bounce buttons[] =
int seconds;
int rpm;
int dist;
int address = 0;
bool isCal = false;
  lcd.backlight();
  delay(2000);
  lcd.clear();
  delay(2000);
  lcd.clear();
  delay(2000);
  radio.begin();
  radio.setDataRate( RF24_250KBPS );
  radio.openReadingPipe(1, deviceID);
  radio.enableAckPayload();
  radio.writeAckPayload(1, radioTxArray, sizeof(radioTxArray));
  radio.startListening();
  readButtons();
  checkStartStop();
  adjRequiredRpm();
  calibration();
  heightSensor();
  adjHeight();
  menuSelect();
  displayRpm();
  exchangeData();
  writeToEeprom();
      isStarted = true;
    else {
      isStarted = false;
    setpointVariable++;
      isCal = true;
    else {
      isCal = false;
      isHeight = true;
      //isCal = false;
    else {
      isHeight = false;
void adjHeight() {
    dist++;
    if (dist > 150) {
      dist = 150;
    dist = dist - 1;
    if (dist < 10) {
      dist = 10;
void menuSelect() {
      isDist = true;
    else {
      isDist = false;
void displayRpm() {
    lcd.print("60");
    lcd.print("sec");
    lcd.print(dist);
    lcd.print("cm");
  else {
      lcd.print("    H");
    else {
      lcd.print("     ");
    if (isStarted) {
    else {
    lcd.print(" RPM ");
    lcd.print(rpm);
  if ( radio.available() ) {
    radio.read( radioRxArray, sizeof(radioRxArray) );
    Serial.print("Data received Number0 ");
    Serial.print(" Number1 ");
    Serial.println(radioRxArray[1]);
moose4621
I did manage to get a test with the master done before work and the two are communicating but the data from the client is not being updated. It keeps resending the data it had at the start. I'll be able to supply more info when I get home but if you can see anything that may cause this in the meantime???
Master sketch
Code: [Select]
//*********Height Sensor Stuff*********
#include <NewPing.h>
#define TRIGGER_PIN  3  // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN     4  // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 400 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
int dist;
//*****Motor Controller Stuff******
#include <PID_v2.h>
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint, 0.8, 5.2, .01, DIRECT);
#define PWMpin  6
volatile unsigned long timeX = 1;
int PulsesPerRevolution = 36;
int MaxRPM = 400;
volatile int Counts = 1;
double PulsesPerMinute;
volatile unsigned long LastTime;
volatile int PulseCtr;
unsigned long Counter;
int startRamp;
unsigned long Time;
int rpm;
//********Radio Stuff*******
#include <RF24.h>
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   7
#define CSN_PIN 8
// These are the IDs of each of the slaves
const uint64_t slaveID[2] = {0xE8E8F0F0E1LL, 0xE8E8F0F0E2LL} ;
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000;
int txVal = 0;
//0 = motor on/off, 1 = setPoint, 2 = , 3 = Height, 4 = Cal, 5 = Dist
byte radioRxArrayLen = 10; // NB this 4 is the number of bytes in the 2 ints that will be recieved
bool isCal = false;
bool go = false;
   // note that 1666666.67 = (60 seonds * 1000000 microseconds)microseconds in a minute / (36 / 9) pulses in 1 revolution
  PulsesPerMinute = (60 * 1000000) / (PulsesPerRevolution / Counts);
  pinMode(2, INPUT_PULLUP);
  Serial.println("PID controlled Seeder Master R0");
  //Digital Pin 2 Set As An Interrupt for tacho.
  attachInterrupt(0, sensorInterrupt, FALLING);
   startRamp = 10;//map(PulsesPerRevolution , 1, MaxRPM, MaxRPM, 2);
  myPID.SetSampleTime(1);
  myPID.SetOutputLimits(40, (int) 255);
  PulseCtr = 0;
  myPID.SetMode(AUTOMATIC);
  analogWrite(PWMpin, 40);
  myPID.Compute();
  delay(11);
  myPID.Compute();
  radio.begin();
    radio.setRetries(3,5); // delay, count
  exchangeData();
  getSetPoint();
  getStartStop();
  getHeight();
  readMotorCurrent();
  switchOnOff();
  readRpm();
  debug();
static unsigned long SpamTimer;
void exchangeData()
    if (currentMillis - prevMillis >= txIntervalMillis) {
    radio.openWritingPipe(slaveID[0]); // calls the first slave
                                        // there could be a FOR loop to call several slaves in turn
    bool rslt;
    rslt = radio.write( radioTxArray, sizeof(radioTxArray) );
    Serial.print("\nRSLT (1 = success) ");
    Serial.println(rslt);
    Serial.print("Data Sent ");
    Serial.print("  ");
    Serial.println(radioTxArray[1]);
    if ( radio.isAckPayloadAvailable() ) {
        radio.read(radioRxArray,radioRxArrayLen);
        Serial.print("Acknowledge received: ");
        Serial.print(radioRxArray[0]);Serial.print("  ");
        Serial.print(radioRxArray[1]);Serial.print("  ");
        Serial.print(radioRxArray[2]);Serial.print("  ");
        Serial.print(radioRxArray[3]);Serial.print("  ");
        Serial.print(radioRxArray[4]);Serial.print("  ");
        Serial.println(radioRxArray[5]);
    prevMillis = millis();
void getSetPoint()
    Setpoint = 45;
  Setpoint = radioRxArray[1];
void getStartStop()
  if(radioRxArray[0]==1)
    isStarted = true;
    isStarted = false;
void getHeight()
  unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
  dist = (uS / US_ROUNDTRIP_CM); //raw distance in cm.
  if (dist >=50)
    digitalWrite(1, HIGH);
    digitalWrite(1, LOW);
void readMotorCurrent()
void switchOnOff()
void sensorInterrupt()
   static int Ctr;
  unsigned long Time;
  Ctr++;
  if (Ctr >= Counts) { // 36 / 4 = 9 so we are taking an average of 9 readings to use in our calculations
    Time = micros();
    timeX += (Time - LastTime); // this time is accumulative ovrer those 9 readings
    LastTime = Time;
    PulseCtr ++;
    Ctr = 0;
void readRpm()
  radioTxArray[0] = Input;
  cli ();         // clear interrupts flag
  Time = timeX;   // Make a copy so if an interrupt occurs timeX can be altered and not affect the results.
  timeX = 0;
  sei ();         // set interrupts flag
  if (PulseCtr > 0) {
    Input =  (double) (PulsesPerMinute /  (double)(( (unsigned long)Time ) *  (unsigned long)PulseCtr)); // double has more percision
    //   PulseCtr = 0; // set pulse Ctr to zero
    debug();
    if(!myPID.Compute()) Serial.println();
    analogWrite(PWMpin, Output);
    Time = 0; // set time to zero to wait for the next rpm trigger.
    Counter += PulseCtr;
    // we are automatically adjusting the diviser to preserve processor time after calculating last rpm
    // starting at 0 RPM ~ 400+RPM we adjust the division of the pulses per revolution
   // Counts = 100; constrain(map((int)Input, startRamp, MaxRPM, 1, PulsesPerRevolution), 1, PulsesPerRevolution);
    PulsesPerMinute = (60.0 * 1000000.0) / (double)((double)PulsesPerRevolution / (double)Counts);
void debug()
  char S[20];
  if ((unsigned long)(millis() - SpamTimer) >= 100) {
    SpamTimer = millis();
    Serial.print(" rpm: "); Serial.print(Input );
    Serial.print(" motor: "); Serial.print(radioRxArray[0]);
    Serial.print(" setpoint: "); Serial.print(radioRxArray[1]);
    Serial.print(" height "); Serial.print(radioRxArray[3]);
    Serial.print(" cal: "); Serial.print(radioRxArray[4]);
    Serial.print(" dist: "); Serial.print(radioRxArray[5]);
    Serial.print(" ping sensor "); Serial.println(dist);
Robin2
I think what you have should work - unless there is a small glitch somewhere. I am not good at spotting them.
You might move the line
Code: [Select]
above the IF in the function.
Note that the ackPayload that will be sent is the value that was in place prior to the Tx from the Master - in other words it is always one step behind - but that should not matter.
Did you try my code unchanged and did that work for you?
...R
moose4621
Code: [Select]
Thanks Robin2. I tried moving that line in the client to above the if function but made no difference. The client, or hand controller is receiving valid data from the master but the master appears to not be receiving updated data from the client. What ever the client sends on the first transmission after rebooting the master is what the master continues to report receiving via radioRxArray. I still don't know if the master is not updating radioRxArray, or the slave is not sending the newest version of radioTxArray.
I am a bit unsure about what to do with the
Code: [Select]
byte radioRxArrayLen = 9; // NB this 4 is the number of bytes in the 2 ints that will be recieved
since the length will change will it not as some arrays go over 100?
I tried
Code: [Select]
byte radioRxArrayLen = radioRxArray;
but got invalid conversion from int to byte.
Quote
...R
I did, thank you. Your a genius!
They worked as expected.
I must admit I only tried your code AFTER I tried my cobbled together merged mess first.
My esc on the master end just stopped functioning altogether so I will have to order a replacement but the should not stop me getting these radio's and a few other things sorted out.
Thank you for your great help Robin2, I really appreciate it.
Robin2
I'm not sure I understand. AFAIK an ackPayload cannot be more than 32 bytes.
Why not use a fixed size for all transmissions?
...R
moose4621
...R
It is more than likely ME who does not understand :-(
So a byte is a numerical value between 0 - 255, each index in the array radioTxArray will not exceed these values.
Therefore:
Code: [Select]
radioRxArrayLen = 6;//number of index's in the array?
If this is the case, why did you have
Code: [Select]
int ackMessg[6];
byte ackMessgLen = 4; // NB this 4 is the number of bytes in the 2 ints that will be recieved
in your example?
Robin2
Code: [Select]
int ackMessg[6];
in your example?
The first line creates space for an array with 6 ints - that requires 12 bytes.
The second line define how many bytes are being received (and sent) - 4 bytes is required for 2 ints and that will easily fit in the space for 12 bytes.
I have created a bigger array than is needed - I like to be sure that there is plenty of space for the data to avoid memory corruption. It would probably be sufficient to define int ackMessg[2]
...R
moose4621
...R
This simple explanation got the radio issues sorted thanks Paul.
I had too few bytes for radioRxArrayLen.
Both radios now updating data and Tx/Rx as expected.
If only I had listened to you weeks ago ;-)
Ummmm, I do have a couple of threads going at the moment, regarding different and unrelated, (I hope), problems. Since my other problem with a countdown timer did not really relate to this thread, I started another. Did I break protocol here?
Many thanks Robin2
moose4621
Unfortunately, while I have great radio comms now, it has interferred with the PID control on the master.
The txIntervalMillis creates a pulse in the motor control circuit by interrupting the PID updates.
I tried different txIntervalMillis, including 0 but no success.
Robin2
You have not really provided any information about the txIntervalMillis interrupting the PID updates.
Obviously when it is time to do the wireless stuff the Arduino will take a little longer to complete a loop().
If that causes a problem for the PID system either the PID system is poorly designed or the Arduino does not have the capacity for the job.
Due to lack of information I have no idea if there might be other considerations.
...R
