Topic: A library to control a rgb lamp without using delay (Read 365 times) previous topic - next topic
Stilren
Hi! I wrote a library for controlling a RGB lamp that does not use delay functionality.
https://github.com/stilren/RGBLamp
Example for having a led blink (or rather pulse) continuously:
Code: [Select]
#include "RGBLamp.h"
RGBLamp myLamp;
int redPin = 3;
int greenPin = 5;
int bluePin = 6;
int mode = COMMON_ANODE;
  myLamp.begin(mode, redPin, greenPin, bluePin); //Make sure pins are PWM-pins if you want to use fadeTo or blink fucntions.
  myLamp.blink(Color::Cyan);
  myLamp.update(); //Run continuously
I needed it for a project im working on and couldnt find a library that suited me. After finishing it up i decided to put some final touches on it and upload it to github under MIT license. I was using it together with a Timer library to ensure the correct update rate but I also included a update-function in this lib. Besides just telling you guys that its out there I am also looking for feedback regarding the code!
