A 3-pin IR receiver is designed to ignore ambient (static) light.
It only detects modulated light. 38kHz for the TSSP4038.
An Arduino can generate that frequency, and drive an IR LED with an output pin.
See example sketch.
Leo..const byte IR_LED = 11; // IR transmitter LED with 100ohm (minimum) CL resistor
const byte IR_Receiver = 8; // from receiver output
const byte onboard_LED = 13; // onboard indicator LED
boolean receiverState;
pinMode (onboard_LED, OUTPUT);
pinMode (IR_LED, OUTPUT);
pinMode (IR_Receiver, INPUT);
// from Nick Gammon
TCCR2A = _BV (COM2A0) | _BV(WGM21);
TCCR2B = _BV (CS20);
OCR2A = 209; // ~209 = ~38kHz | ~219 = ~36kHz
receiverState = digitalRead (IR_Receiver);
if (receiverState == HIGH) { // beam interrupted
digitalWrite(onboard_LED, LOW); // green onboard LED off
else { // beam detected
digitalWrite(onboard_LED, HIGH); // green LED on
