Topic: 24v dc servo motor (Read 3255 times) previous topic - next topic
shashi9819
can i control 6 wire dc servo motor ( link shown below ) directly with arduino ? i will be using power supply shown in second link.. plz help me with CODE and Wire connection diagram ?
Link1) motor : http://robokits.co.in/motors/dc-servo-motor-24v-100w-with-2000-ppr-encoder?cPath=2_71&
link 2 ) power supply : http://robokits.co.in/power-supply/industrial-power-supply/24v-10a-industrial-power-supply
thanks
MarkT
shashi9819
thanks mark as instructed i bought driver but still m confused as this servo has 6 wires. how to give input to motor and at what rate is not mentioned in datasheet. i tried one form arduino tutorial ( one with 180 degree ). motor runs continuously. need help on code. plz help
Isaac96
That is not a hobby servo. Hobby servos have 3 wires. The servo motor that you have has an encoder, while hobby servos have a potentiometer checking the position.
Do not PM me for help. I will delete immediately.
CONNECT THE GROUNDS!
After Tuesday, even the calendar goes W T F
MarkT
#4
Jul 24, 2016, 02:34 am Last Edit: Jul 24, 2016, 02:36 am by MarkT
Its a DC motor (2 wires) and a quadrature encoder (4 wires).  The correct driver will have connections for
power to the motor (2 wires) and an encoder (4 wires?).   It should also have step/direction inputs (probably
opto-isolated), which connect to the Arduino - use the AccelStepper library or similar.
Yes, don't confuse a servomotor (a position and/or speed controlled industrial motor) with
a hobby servo (aka servo-mechanism or actuator)
shashi9819
can u plz suggest any link where I Will find the connection diagrams for above accelstepper lib ?
meanwhile i tried  a code shown in NYC-CNC video. ( from same accelstepper lib )
motor starts running but after half revolution it gives error on driver but rotates further and same error pop up during whole program
m posting code over here
#include <AccelStepper.h>
AccelStepper stepper(1,9,8);
int pos = 3600;
stepper.setMaxSpeed(500);
stepper.setAcceleration(300);
  if ( stepper.distanceToGo() == 0)
    pos=-pos;
    stepper.moveTo(pos);
  stepper.run();
shashi9819
int pos = 3600;
    pos=-pos;
  stepper.run();
MarkT
Can you provide any information about the error.  A video of the test might be useful.
shashi9819
alright i have video but how to upload it?? maximum size allowed ?
thanks Mark
MarkT
What's wrong with youtube?
shashi9819
alright here u go I am sending a link to the video
https://youtu.be/ySaoxK_6YGk
hope it works.
MarkT
So the LED lights up - I can't see what that LED is - is there writing next to it or what?
It's not stopping it working though from what I can tell, nice smooth acceleration and deceleration.
Is the movement of the shaft what you'd expect?
shashi9819
m attaching a datasheet of driver which do specifies some error on page 6 ... the red light is error light ... and whenever it blinks u can feel a jerk whereas I need a smooth operation... datasheet shows some gain settings error or pulses might be too high but which exactly one of it that I don't know really. thanks for ur time and help Mark.
shashi9819
hey Mark,
thanks for help. i think my problem is solved i reduced the acceleration in code and changed servo loop gain and input multiplier on driver to 8x and 4x. no error on driver now and also motor runs smoothly.
now i will move on to next step on my project. thanks for help may need it in future.
MarkT
Good, I'm glad its working - how well is the combination of motor and driver performing under load?
