Topic: An error occurred while uploading the sketch. (Read 211849 times) previous topic - next topic
kelvinheads
I am getting the same problem but the suggested fix does not work. Is there another cause/fix
shadowmaster
Arduino: 1.8.5 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 2278 bytes (7%) of program storage space. Maximum is 32256 bytes.
Global variables use 223 bytes (10%) of dynamic memory, leaving 1825 bytes for local variables. Maximum is 2048 bytes.
C:\Users\dell\Desktop\Amit\Arduino\hardware\tools\avr/bin/avrdude -CC:\Users\dell\Desktop\Amit\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM24 -b115200 -D -Uflash:w:C:\Users\dell\AppData\Local\Temp\arduino_build_601820/bt_car.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\dell\Desktop\Amit\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM24
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't set com-state for "\\.\COM24"
avrdude done.  Thank you.
option enabled in File -> Preferences.
pert
Make sure you have the right port selected in the Arduino IDE's Tools > Port menu. Make sure you don't have anything connected to pins 0 and 1 of your Uno while doing the Upload.
DraperWilliams
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM9 -b115200 -D -Uflash:w:C:\Users\user\AppData\Local\Temp\arduino_build_97673/SIK_Circuit_1A-Blink.ino.hex:i
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM9
avrdude: ser_open(): can't open device "\\.\COM9": The system cannot find the file specified.
skand_tripathi
i have a problem in uploading the sketch
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 940 bytes (2%) of program storage space. Maximum is 32256 bytes.
C:\Users\Dell\Desktop\arduino-1.8.5\hardware\tools\avr/bin/avrdude -CC:\Users\Dell\Desktop\arduino-1.8.5\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b115200 -D -Uflash:w:C:\Users\Dell\AppData\Local\Temp\arduino_build_742949/blinking_led.ino.hex:i
         System wide configuration file is "C:\Users\Dell\Desktop\arduino-1.8.5\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM1
avrdude: ser_open(): can't open device "\\.\COM1": The system cannot find the file specified.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
pert
Select the port of your Arduino from the Tools > Port menu. If that menu is grayed out or the port of your Arduino board is not shown then one of the following may be the cause:
  • You may need to install the driver for the USB-serial chip on your Arduino. Determine which chip is used on your Arduino and install the driver.
  • You may be using a charge-only or defective USB cable. Test your cable on another device to confirm that it works for data.
  • Using a USB 3.0 port on your computer may cause problems. Try a USB 2.0 port or use a USB 2.0 hub plugged into your USB 3.0 port.
a
alamgir
my code do not upload ardunio ch340g  com3  plz tel me about somthing this situation  i can  not  undrestand
pert
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the upload fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
MiguelQuecas
board wemmos d1 r1
the board was working just fine and for no reason
when i try to upload a sketch this error ocures.
Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Placa:"WeMos D1 R1, 80 MHz, 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Archiving built core (caching) in: C:\Users\migue\AppData\Local\Temp\arduino_cache_475616\core\core_esp8266_esp8266_d1_CpuFrequency_80,FlashSize_4M1M,LwIPVariant_v2mss536,Debug_Disabled,DebugLevel_None____,FlashErase_none,UploadSpeed_115200_a2f4ecf09cad4f35b9a1d504fdc62c4d.a
O rascunho usa 246311 bytes (23%) do espaço de armazenamento do programa. O máximo é 1044464 bytes.
Variáveis globais usam 32260 bytes (39%) de memória dinâmica, restando 49660 bytes para variáveis locais. O maximo é 81920 bytes.
warning: espcomm_sync failed
Ocorreu um erro a enviar o rascunho
error: espcomm_open failed
error: espcomm_upload_mem failed
the error appeared after attempting to connect the Arduino to the intellij ide, I already reinstalled the arduino ide already reinstalled the software of the usb controller and nothing need help !!!
pakoy3k
I have the same error, when I was testing it I found that it was the bluetooth module, for some reason if it is to the current to program my Arduino gave me that error, my solution was to program the Arduino UNO without a connected module and it worked.
rascaleye
Arduino: 1.8.6 Hourly Build 2018/06/12 11:33 (Windows 10), Board: "Arduino/Genuino Uno"
Archiving built core (caching) in: C:\Users\User\AppData\Local\Temp\arduino_cache_612582\core\core_arduino_avr_uno_0f0e1c1ce3aab4721bccdf17013314bd.a
Sketch uses 724 bytes (2%) of program storage space. Maximum is 32256 bytes.
D:\softwares\arduino-nightly-windows\arduino-nightly\hardware\tools\avr/bin/avrdude -CD:\softwares\arduino-nightly-windows\arduino-nightly\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\User\AppData\Local\Temp\arduino_build_859312/sketch_jun20a.ino.hex:i
avrdude: Version 6.3-20171130
         System wide configuration file is "D:\softwares\arduino-nightly-windows\arduino-nightly\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xdb
THIS IS MY PROBLEM
PLEASE HELP...
pnkz
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
sir i am getting the error while i tried to upload the empty loops to reset my arduino board.
pert
nghtitus
Please help. I am getting this error when uploading my sketch on Uno.
Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: "Arduino/Genuino Uno"
avrdude: ser_open(): can't set com-state for "\\.\COM3"
mike12345
Sketch uses 938 bytes (2%) of program storage space. Maximum is 32256 bytes.
avrdude: ser_open(): can't open device "\\.\COM4": The system cannot find the file specified.
// this is my error
