Topic: An error occurred while uploading the sketch. (Read 212960 times) previous topic - next topic
ballscrewbob
@mike12345
Are you using USB 2.0 or 3.0 ports and cables as Arduinos can be very hit and miss with USB 3.0 ?
Changing cables and ports is always a first stop in troubleshooting.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
Gaurav2
Arduino: 1.8.6 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 930 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x44
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x44
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x44
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x44
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x44
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x44
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x44
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x44
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x44
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x44
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
need help
Gaurav2
ballscrewbob
DarkZero987
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
Archiving built core (caching) in: C:\Users\Ivan\AppData\Local\Temp\arduino_cache_304496\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
Sketch uses 960 bytes (2%) of program storage space. Maximum is 32256 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Ivan\AppData\Local\Temp\arduino_build_521870/sketch_sep15c.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't set com-state for "\\.\COM3"
avrdude done.  Thank you.
ballscrewbob
@DarkZero987
Is that a comment or a question ?
effy002
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the upload fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
it'll be great if i could get some help too
< Arduino: 1.8.7 (Mac OS X), Board: "Arduino/Genuino Uno"
Sketch uses 4300 bytes (13%) of program storage space. Maximum is 32256 bytes.
Global variables use 239 bytes (11%) of dynamic memory, leaving 1809 bytes for local variables. Maximum is 2048 bytes.
/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem1421 -b115200 -D -Uflash:w:/var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch_dec15a.ino.hex:i
avrdude: Version 6.3-20171130
        System wide configuration file is "/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
        User configuration file is "/Users/ifrahs/.avrduderc"
        User configuration file does not exist or is not a regular file, skipping
        Using Port                    : /dev/cu.usbmodem1421
avrdude: ser_open(): can't open device "/dev/cu.usbmodem1421": No such file or directory
effy002
i'm using a DHT11 humidity sensor, my cable works as i have tried before i just have no idea why its giving me errors
i posted a query earlier with error message from " file>preferences>upload(checked)"
this is with 'compilation (checked)'
/Applications/Arduino 2.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino 2.app/Contents/Java/hardware -tools /Applications/Arduino 2.app/Contents/Java/tools-builder -tools /Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Arduino 2.app/Contents/Java/libraries -libraries /Users/ifrahs/Documents/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10807 -build-path /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303 -warnings=none -build-cache /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_cache_725994 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -verbose /Users/ifrahs/Documents/Arduino/sketch_dec15a/sketch_dec15a.ino
/Applications/Arduino 2.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino 2.app/Contents/Java/hardware -tools /Applications/Arduino 2.app/Contents/Java/tools-builder -tools /Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Arduino 2.app/Contents/Java/libraries -libraries /Users/ifrahs/Documents/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10807 -build-path /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303 -warnings=none -build-cache /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_cache_725994 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr -verbose /Users/ifrahs/Documents/Arduino/sketch_dec15a/sketch_dec15a.ino
Using board 'uno' from platform in folder: /Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr
Using core 'arduino' from platform in folder: /Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr
Detecting libraries used...
"/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr/variants/standard" /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch/sketch_dec15a.ino.cpp -o /dev/null
"/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr/variants/standard" -I/Users/ifrahs/Documents/Arduino/libraries/DHTLib /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch/sketch_dec15a.ino.cpp -o /dev/null
Using cached library dependencies for file: /Users/ifrahs/Documents/Arduino/libraries/DHTLib/dht.cpp
Generating function prototypes...
"/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr/variants/standard" -I/Users/ifrahs/Documents/Arduino/libraries/DHTLib /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch/sketch_dec15a.ino.cpp -o /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/preproc/ctags_target_for_gcc_minus_e.cpp
"/Applications/Arduino 2.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
"/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino 2.app/Contents/Java/hardware/arduino/avr/variants/standard" -I/Users/ifrahs/Documents/Arduino/libraries/DHTLib /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch/sketch_dec15a.ino.cpp -o /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch/sketch_dec15a.ino.cpp.o
Compiling libraries...
Compiling library "DHTLib"
Using previously compiled file: /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/libraries/DHTLib/dht.cpp.o
Compiling core...
Using precompiled core: /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_cache_725994/core/core_arduino_avr_uno_a44201f00637cc7de5d2873b25582122.a
Linking everything together...
"/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch_dec15a.ino.elf /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch/sketch_dec15a.ino.cpp.o /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/libraries/DHTLib/dht.cpp.o /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/../arduino_cache_725994/core/core_arduino_avr_uno_a44201f00637cc7de5d2873b25582122.a -L/var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303 -lm
"/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch_dec15a.ino.elf /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch_dec15a.ino.eep
"/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-objcopy" -O ihex -R .eeprom /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch_dec15a.ino.elf /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch_dec15a.ino.hex
Using library DHTLib in folder: /Users/ifrahs/Documents/Arduino/libraries/DHTLib (legacy)
"/Applications/Arduino 2.app/Contents/Java/hardware/tools/avr/bin/avr-size" -A /var/folders/4j/p2g4zhc94990rcsc7khsbyrh0000gn/T/arduino_build_479303/sketch_dec15a.ino.elf
sparsh13
Arduino: 1.8.5 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 1998 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 189 bytes (9%) of dynamic memory, leaving 1859 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd8
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xd8
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xd8
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xd8
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd8
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xd8
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xd8
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd8
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xd8
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd8
ThePyroManiac
SEND HELP
i'm heckin lost please help
Code: [Select]
Sketch uses 1806 bytes (5%) of program storage space. Maximum is 32256 bytes.
Global variables use 51 bytes (2%) of dynamic memory, leaving 1997 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\Isaac\AppData\Local\Temp\arduino_build_127520/Slots_test.ino.hex:i
         Using Port                    : COM4
avrdude: ser_open(): can't open device "\\.\COM4": The system cannot find the file specified.
DrAzzy
SEND HELP
Code: [Select]
         Using Port                    : COM4
Incorrect port selected. Select a port from tools -> port menu; it's got COM4 selected (which presumably you used previously), but it's saying that there is no COM4. Windows will often assign a different port number depending on which USB port a device is plugged into (and occasionally for no apparent reason), so you just need to select the correct port.
ATTinyCore and megaTinyCore for all ATtiny, DxCore for DA/DB-series! github.com/SpenceKonde
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
carloszoom3000
I had the same problem and i just went to Tools+Port, and then selected the one that showed Arduino Genuino/UNO, in my case (i switched from port 13 to port 20).
It worked.
Regrads,
kmspavan
Sketch uses 896 bytes (2%) of program storage space. Maximum is 32256 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x8f
ballscrewbob
@kmspavan
Just posting the error message is useful but it would be better if you included any other info such as the board being used and any additional components you may have connected.
Might I suggest you read the posts at the top of the forum section too please.
RandomStuff
#44
Apr 14, 2019, 10:50 pm Last Edit: Apr 14, 2019, 10:57 pm by RandomStuff
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 972 bytes (3%) of program storage space. Maximum is 32256 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x6e
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x6e
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x6e
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x6e
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x6e
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x6e
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x6e
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x6e
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x6e
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x6e
plz help I dont know what the problem is
