Topic: An error occurred while uploading the sketch. (Read 218159 times) previous topic - next topic
pert
plz help I dont know what the problem is
Remove any connections to pins 0 and 1. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don't know which port is your Arduino, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
haygreev
I'm getting the same error while uploading the code to the board.
I'm new to this and I'm just trying to follow what instructables has put up.
the error message is :
Sketch uses 21624 bytes (67%) of program storage space. Maximum is 32256 bytes.
Global variables use 910 bytes (44%) of dynamic memory, leaving 1138 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't set com-state for "\\.\COM4"
SO what does this mean?
What is the second method of uploading the code?  How to do it?
How to resolve this?
Thanks in advance.
pert
Try restarting your computer. Sometimes the COM port will get stuck in a bad state and the restart fixes that.
josearaluce
Arduino:1.8.9 (Windows 10), Tarjeta:"Arduino/Genuino Uno"
El Sketch usa 2296 bytes (7%) del espacio de almacenamiento de programa. El máximo es 32256 bytes.
Las variables Globales usan 212 bytes (10%) de la memoria dinámica, dejando 1836 bytes para las variables locales. El máximo es 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\JOS~1\AppData\Local\Temp\arduino_build_2557/AUTO_GO.ino.hex:i
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf7
avrdude done.  Thank you.
Problema subiendo a la placa. Visita http://www.arduino.cc/en/Guide/Troubleshooting#upload para sugerencias.
Este informe podría contener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
josearaluce
Ok. Arreglado. Hay que quitar el módulo de Bluetooth antes de subir. Si lo has intentado antes de quitarlo tendrás que salir del programa y volver a hacerlo con él módulo de bluetooth quitado.
larawh98
Build options changed, rebuilding all
Sketch uses 2098 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 50 bytes (2%) of dynamic memory, leaving 1998 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\pc\AppData\Local\Temp\arduino_build_112939/servotrial.ino.hex:i
         Using Port                    : COM3
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x84
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
please i need a solution
pert
  • Tools > Port
Msindisi
Hi Guys
I know this thread is pretty old, but I thought I should add what I found since all the above suggestions did not work for me.
What ended up working for me was changing the programmer (Tools > Programmer) from AVRISP mkII to ArduinoISP, then the sketch was able to upload without any errors. Then I changed it back to AVRISP mkII and it still worked. Not sure why or how this happened. Might be worth trying if none of the other solutions worked for you.
Thanks for your time and I hope this helps you out. I really do. I know how frustrating this problem is, first hand.
nirupamapalapalli
<Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 3316 bytes (10%) of program storage space. Maximum is 32256 bytes.
Global variables use 198 bytes (9%) of dynamic memory, leaving 1850 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\HP\AppData\Local\Temp\arduino_build_925352/task3.ino.ino.hex:i
         System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM5
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\HP\AppData\Local\Temp\arduino_build_925352/task3.ino.ino.hex"
avrdude: writing flash (3316 bytes):
Writing | ################################################## | 100% 0.54s
avrdude: 3316 bytes of flash written
avrdude: verifying flash memory against C:\Users\HP\AppData\Local\Temp\arduino_build_925352/task3.ino.ino.hex:
avrdude: load data flash data from input file C:\Users\HP\AppData\Local\Temp\arduino_build_925352/task3.ino.ino.hex:
avrdude: input file C:\Users\HP\AppData\Local\Temp\arduino_build_925352/task3.ino.ino.hex contains 3316 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.42s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0x62 != 0x0c
avrdude: verification error; content mismatch
the selected serial port avrdude done.  Thank you.
 does not exist or your board is not connected
option enabled in File -> Preferences.
nirupamapalapalli
Sketch uses 3164 bytes (9%) of program storage space. Maximum is 32256 bytes.
Global variables use 200 bytes (9%) of dynamic memory, leaving 1848 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\HP\AppData\Local\Temp\arduino_build_313488/usonic1.ino.hex:i
         Using Port                    : COM5
avrdude: ser_open(): can't open device "\\.\COM5": The system cannot find the file specified.
pert
         0x62 != 0x0c
You're just having all sorts of trouble, aren't you?
Since you already created a dedicated thread, let's confine the discussion to over there to avoid wasting time through duplicate effort:
https://forum.arduino.cc/index.php?topic=619514
ballscrewbob
@nirupamapalapalli
One of nirupamapalapalli DUPLICATE threads removed.
DO NOT post duplicates or cross post as it wastes peoples time and effort.
Bob.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
cnar5
I would need some help
Sketch uses 6600 bytes (20%) of program storage space. Maximum is 32256 bytes.
Global variables use 261 bytes (12%) of dynamic memory, leaving 1787 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\arsalan\AppData\Local\Temp\arduino_build_304362/DumpInfo.ino.hex:i
         Using Port                    : COM4
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Firmware Version: 1.16
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: reading input file "C:\Users\arsalan\AppData\Local\Temp\arduino_build_304362/DumpInfo.ino.hex"
avrdude: writing flash (6600 bytes):
Writing | ################################################## | 100% 1.48s
avrdude: 6600 bytes of flash written
avrdude: verifying flash memory against C:\Users\arsalan\AppData\Local\Temp\arduino_build_304362/DumpInfo.ino.hex:
avrdude: load data flash data from input file C:\Users\arsalan\AppData\Local\Temp\arduino_build_304362/DumpInfo.ino.hex:
avrdude: input file C:\Users\arsalan\AppData\Local\Temp\arduino_build_304362/DumpInfo.ino.hex contains 6600 bytes
Reading | ################################################## | 100% 0.95s
avrdude: 6600 bytes of flash verified
pert
The output you posted shows a successful compilation and upload. Everything is working fine. Carry on.
pranayar
Arduino: 1.8.9 (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\user\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10809 -build-path C:\Users\user\AppData\Local\Temp\arduino_build_280739 -warnings=none -build-cache C:\Users\user\AppData\Local\Temp\arduino_cache_684087 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\02.Digital\BlinkWithoutDelay\BlinkWithoutDelay.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\user\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10809 -build-path C:\Users\user\AppData\Local\Temp\arduino_build_280739 -warnings=none -build-cache C:\Users\user\AppData\Local\Temp\arduino_cache_684087 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\02.Digital\BlinkWithoutDelay\BlinkWithoutDelay.ino
Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_280739\\sketch\\BlinkWithoutDelay.ino.cpp" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_280739\\sketch\\BlinkWithoutDelay.ino.cpp" -o "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_280739\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_280739\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_280739\\sketch\\BlinkWithoutDelay.ino.cpp" -o "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_280739\\sketch\\BlinkWithoutDelay.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\user\AppData\Local\Temp\arduino_cache_684087\core\core_arduino_avr_nano_cpu_atmega328_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_280739/BlinkWithoutDelay.ino.elf" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_280739\\sketch\\BlinkWithoutDelay.ino.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_280739/..\\arduino_cache_684087\\core\\core_arduino_avr_nano_cpu_atmega328_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_280739" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_280739/BlinkWithoutDelay.ino.elf" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_280739/BlinkWithoutDelay.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_280739/BlinkWithoutDelay.ino.elf" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_280739/BlinkWithoutDelay.ino.hex"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\user\\AppData\\Local\\Temp\\arduino_build_280739/BlinkWithoutDelay.ino.elf"
Sketch uses 858 bytes (2%) of program storage space. Maximum is 30720 bytes.
Global variables use 15 bytes (0%) of dynamic memory, leaving 2033 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\user\AppData\Local\Temp\arduino_build_280739/BlinkWithoutDelay.ino.hex:i
         Using Port                    : COM4
avrdude: ser_open(): can't open device "\\.\COM4": The system cannot find the file specified.
