Topic: An error occurred while uploading the sketch. (Read 189455 times) previous topic - next topic
pert
Too bad that the only suggested solution is to select the right port. Obviously my problem is very different with my config :
avrdude: usbdev_open(): did not find any USB device "usb" (0x03eb:0x2104)
Maybe a faulty board ?  Strange, since I get the informations from the board through the USB connection.
Your problem is caused by holding the Shift key while you click the Upload button. That causes the Arduino IDE to do an "Upload Using Programmer" instead of a standard Upload. Since you don't have an ISP programmer connected, that won't work, thus the error.
jptrol
Thank you for your help Pert. Though I can't remember hitting the shift key or clicking the programmer option , the fact is that when I carefully select upload or CTRL U I now succeed every time I try. May it go on !
Thank you again.
pert
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
SIVAJEEVA
Arduino: 1.8.10 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 936 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM16 -b115200 -D An error occurred while uploading the sketch-Uflash:w:C:\Users\dharani\AppData\Local\Temp\arduino_build_889315/sketch_oct08a.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM16
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
option enabled in File -> Preferences.
pert
         Using Port                    : COM16
This one is really tricky because the output is not providing us with any useful information about the error. Please try restarting your computer. Maybe by some miracle that will fix the problem, or at least cause the output to show some more info.
huzaima
Arduino: 1.8.4 (Windows 7), Board: "Arduino/Genuino Uno"
GetFileAttributesEx C:\Users\sstsmrsm\Desktop\sketch_oct29c\sketch_oct29c.ino: The system cannot find the file specified.
Error compiling for board Arduino/Genuino Uno.
ballscrewbob
@huzaima
Some common causes:-
Over aggressive anti virus or similar
Lack of user permissions.
Actual virus or similar.
Incorrect sketch location or changed during IDE use.
Please rule those out first and use THIS POST as a guide to any extra information you can provide.
Bob.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
Tahsin_Raeed
To upload any code , it shows: An error occurred while uploading the sketch ,meanwhile the orange(L) and Green (On) Lights blinks on always.
Arduino: 1.8.10 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 2040 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 224 bytes (10%) of dynamic memory, leaving 1824 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\Raeed\AppData\Local\Temp\arduino_build_375716/Blink.ino.hex:i
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM5
luxutiouscoder
<Arduino: 1.8.10 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 2072 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 189 bytes (9%) of dynamic memory, leaving 1859 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\Home-PC\AppData\Local\Temp\arduino_build_859710/code_for_arduino_blootooth_controlled_rc_car.ino.hex:i
         Using Port                    : COM4
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x6f
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
pert
Remove any connections to pins 0 and 1. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don't know which port is your Arduino, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
guil61
Code: [Select]
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 2814 bytes (8%) of program storage space. Maximum is 32256 bytes.
Global variables use 220 bytes (10%) of dynamic memory, leaving 1828 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM9 -b115200 -D -Uflash:w:C:\Users\ASHLEY~1\AppData\Local\Temp\arduino_build_912296/sketch_dec11a.ino.hex:i
avrdude: Version 6.3-20171130
         System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM9
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
pert
Code: [Select]
  • Tools > Port
blue_moon
Sketch uses 882 bytes (2%) of program storage space. Maximum is 32256 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\user\AppData\Local\Temp\arduino_build_331621/sketch_jan17a.ino.hex:i
         Using Port                    : COM5
avrdude: ser_open(): can't open device "\\.\COM5": The semaphore timeout period has expired.
Daniel0903
hello,
im trying to upload to my arduino uno for the 1st time but im getting the following error:
Sketch uses 930 bytes (2%) of program storage space. Maximum is 32256 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\daniel.be\AppData\Local\Temp\arduino_build_888969/Blink.ino.hex:i
         Using Port                    : COM6
can you help me please?
thank you.
pert
  • Tools > Port
