Topic: Unable to compile/upload Arduino ISP sketch (Read 1 time) previous topic - next topic
dasheynk
I am trying to use the arduino uno as a programmer for avr programming. I have an atmega 168A-pu. I am trying to upload the ArduinoISP sketch but I keep getting errors. Nothing is connected to the Arduino. Below is the error that I am getting. Can someone help me please?
Code: [Select]
Arduino: 1.6.10 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 4,380 bytes (13%) of program storage space. Maximum is 32,256 bytes.
Global variables use 481 bytes (23%) of dynamic memory, leaving 1,567 bytes for local variables. Maximum is 2,048 bytes.
java.io.IOException: Cannot run program "___REMOVE___/bin/avrdude": CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:26)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:130)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:209)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:78)
at processing.app.Sketch.upload(Sketch.java:1187)
at processing.app.Sketch.exportApplet(Sketch.java:1160)
at processing.app.Sketch.exportApplet(Sketch.java:1132)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2409)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.<init>(ProcessImpl.java:386)
at java.lang.ProcessImpl.start(ProcessImpl.java:137)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 9 more
An error occurred while uploading the sketch
option enabled in File -> Preferences.
DrAzzy
#1
Jul 29, 2016, 06:56 pm Last Edit: Jul 29, 2016, 06:58 pm by DrAzzy
Try with 1.6.9 - this sounds like a problem related to the change in the avrdude version in 1.6.10 and the awful behavior that results from it's interaction with board manager. That's my guess at least - it looks like it's missing avrdude for some reason, and obviously without avrdude, it can't upload anything.
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
blissful
I get the identical error (just about word for word)
I uninstalled the ide v1.6.10 and reinstalled V1.6.9
When attempting to upload the blink example, it just displays "uploading..."
all was working well earlier this week.
pert
Try this:
  • Tools > Board > Boards Manager...
  • Wait for the downloads to complete
  • Click the "Close button
  • Try uploading again
That fixed the issue for me. I haven't been able to identify the actual cause of the issue.
blissful
no joy here, but thanks, Pert. what version did it work with?
blissful
here's what i've found.
on another laptop with V1.6.9 installed, i can upload the basic blink sketch.
but on THIS laptop, i cannot. this tells me that when i uninstall the ide, something is remaining to corrupt the new ide when i reload it.  I deleted my librarys folder but still cannot upload the simplest sketch from this computer. is there a way i can purge the entire thing and start over other than uninstalling?
DrAzzy
There's a folder in a non-obvious location that contains all the board manager installations. On windows it's C:/users/(your username)/AppData (hidden folder)/Local/Arduino15 and C:/users/(your username)/AppData (hidden folder)/Roaming/Arduino15 - delete those folders and reinstall 1.6.9 .
pert
Arduino IDE 1.6.10. That's the only version I've encountered this issue but I think I've seen other reports of it with previous versions.
dasheynk
So I downloaded 1.6.9 and everything works now. However, when i try to follow the example in the make avr programming book, i get another problem. I wire everything from the atmega board to the arduino. When i connect the arduino to the ground and power, the arduino shuts off. I also than get this error:
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
DrAzzy
#9
Jul 29, 2016, 11:22 pm Last Edit: Jul 29, 2016, 11:24 pm by DrAzzy
The initial description implies that you wired something incorrectly and power and ground is shorted together on the device you're connecting to, causing the computer to shut off power to the Arduino (USB ports can only supply 500mA typically). Recheck wiring - did you get power/ground backwards or something? Accidentally connected power to ground? Reset shorted to Vcc?
dasheynk
Thank you, everything works now. I accidentally wired the capacitor wrong. Thank you for all the help.
blissful
Deleting those two "hidden" folders solved my issues. thank you, DrAzzy, this is the second time this week you have solved my troubles. you again have my thanks.- Michael
