Topic: Driving a car toy with L293D  (Read 519 times) previous topic - next topic
SimpleThings
Jul 30, 2016, 03:24 pm Last Edit: Jul 30, 2016, 03:29 pm by SimpleThings
Okay guys I am trying to drive a toy car I found with L293D and this is the simple code I made
Code: [Select]
const int in1Pin = 5;
const int in2Pin = 4;
const int in3Pin = 3; r
const int in4Pin = 2;
void stopMotors(void);
void rearWheelsForwards(void);
void rearWheelsBackswards(void);
void frontWheelsRight(void);
void frontWheelsLeft(void);
  pinMode(in1Pin, OUTPUT);
  pinMode(in2Pin, OUTPUT);
  pinMode(in3Pin, OUTPUT);
  pinMode(in4Pin, OUTPUT);
  pinMode(ledPin,OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(trigPin, OUTPUT);
  Serial.println("1 - forwards , 2 - backwards, 3 - left , 4 - right");
  if ( Serial.available()) {
    char ch = Serial.read();
    if (ch == '1')
      Serial.println("CW");
      rearWheelsForwards();
    else if (ch == '2' )
      Serial.println("CCW");
      rearWheelsBackwards();
    else if( ch == '3')
      Serial.println("Left");
      frontWheelsLeft();
    else if( ch == '4'){
      Serial.println("Right");
      frontWheelsRight();
    else if( ch == '0'){
      stopMotors();
void stopMotors(void){
    digitalWrite(in1Pin,LOW);
    digitalWrite(in2Pin,LOW);
    digitalWrite(in3Pin,LOW);
    digitalWrite(in4Pin,LOW);
    Serial.println("Motors stopped!");
void rearWheelsForwards(void){
   digitalWrite(in2Pin,HIGH);
void rearWheelsBackwards(void){
   digitalWrite(in1Pin,HIGH);
void frontWheelsRight(void){
   digitalWrite(in4Pin,HIGH);
void frontWheelsLeft(void){
   digitalWrite(in3Pin,HIGH);
I tried calling functions without Serial input and it worked just fine , but with this piece of code it just doesnt work, not quite sure why is this happening.
AWOL
Code: [Select]
Your code doesn't compile, so I don't know how you can say whether it "works" or not.
MarkT
Your code as posted has syntax errors and undeclared variables.
Please post the actual code that is failing together with a careful explanation of what
it should do and in what way it isn't working.
SimpleThings
Code: [Select]
I added this accidentally when posting a code here
Those variables that are not declared were part of HC - SR04 detecting if a car is going to some object and making car to stop so it doesnt hit any object, forgot to delete it.
Code: [Select]
  pinMode(in1Pin, OUTPUT); // first motor pin
  pinMode(in2Pin, OUTPUT);  // first motor pin
  pinMode(in3Pin, OUTPUT);  // second motor pin
  pinMode(in4Pin, OUTPUT); // second motor pin
    if (ch == '1')
      rearWheelsForwards(); // makes rear DC motor go CW ,so car moves forward
      rearWheelsBackwards(); // makes rear DC motor go CCW ,so car moves backwards
    else if( ch == '3')
      frontWheelsLeft();  // makes front DC motor go left, so car turns left side
      frontWheelsRight(); // makes front DC motor go right, so car turns left side
      stopMotors(); // if '0' is pressed car just shuts down all the motors
SimpleThings
Okay restarted the IDE and reuploaded code and it works, really strange.
Thank you anyways.
