Topic: [Done] Android: Pair (Y), Connect (N) (Read 1 time) previous topic - next topic
runaway_pancake
Jul 31, 2016, 05:47 pm Last Edit: Aug 15, 2016, 02:24 am by Runaway Pancake Reason: title
I've been trying to get an HC05 going with ArduDroid.
They Pair, but I see no way, no means, to Connect.
I power it up, it's blinking at a fast rate ("2pps").
I Pair and it's blinking at a slower rate (1p every other sec). [Not as long, different from the AT?Command mode blink.]
I don't get/find any option to 'Connect'. TechBitar uses the 'action button', but all I get is a list of open "apps".
I found a bluetooth serial monitor for the PC. It has a 'Connect' button to click, and doing so makes the HC05 LED go into that double-blink state (indicating a Connection).
I'm savvy with the wires, it's not that.  For that matter, the Pair and Connect action have no Arduino interaction; all that's really required there is power.
The HC05 is set properly (see pic):
ROLE = 0  [S]
UART = 9600,0,0  [9600, 1 stop, no par]
CMODE = 1  [connect to any]
VERSION = hc01.com.V2.1
Any Masters of ArduDroid-Android-BT out there?
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
runaway_pancake
Updating with my circuit/wiring
(Wow. Nobody can nail this?)
runaway_pancake
I found the HC-06 that I was looking for ("linvor").
No difference with it. According to the Android, it Pairs, but that's it.
Its STATE LED stays in fast blink.
Nothing results a "Connect with?" option.
Must be some setting in the Android (??), but I cannot find it.
runaway_pancake
I'm reading that Les Androids have a problem with these HC devices.
Need to change/modify the CLASS parameter
AT+CLASS=1
Dying to try this out.
runaway_pancake
No joy there.
Got no reply to an enquiry: AT+CLASS? results a nothing, which is better than an 'ERROR', but not by much.
AT+CLASS=1 results an OK, but to no good end.
Sucks.
runaway_pancake
#5
Aug 14, 2016, 11:09 pm Last Edit: Aug 15, 2016, 02:29 am by Runaway Pancake
Had to give up on "ArduDroid".
I found another app, though - Bluetooth Terminal HC-05 by mightyIT - $1.49 to turn off the ads.
It only has 5 buttons, but you can store whatever text you want sent with each or just go on-the-fly.
Eureka - something that works!
► ► My HC-05 double-blinks when it's 'connected' and the HC-05 (has the same ckt_bd w/o pb) goes solid on.
