Topic: Multiple MuxShield II (Read 411 times) previous topic - next topic
TBlack3
So I am trying to automate some calibration verification procedures.  I need close to 40 analog inputs and 4 analog outputs.  I am not using the Arduino to make the analog measurements, it is nowhere near accurate enough.  I already know how to control an Agilent 34410A to use as my measurement device.  But I have 20 different signal paths that combine in different ways to make up 19 channels.  And then I need 16 more paths to make up 16 channels, in order to do 4 wire resistance measurements.
I think I have worked out that I can do this by tying my Arduino analog/in pins to the DMM, use the "read analog" command to route the path I need (I basically don't care what the Arduino reads, I just want it to route the path).  But here are the problems:
1. There are only three outputs on one Muxshield board, so I need two boards in order to get the four outputs for the 4 wire resistance measurement (And I need to use a diff amp for other measurements, so I need to route a combination of paths to the Diff Amp and then back through to the DMM).  Will I be able to route four paths at once, on two separate Muxboards?
2. I cant remember what I was going to write here..... I will save it for later I guess.
PaulRB
Hi I think you should draw a schematic or some kind of block diagram to help explain what you are trying to do. At the moment it sounds very confusing!
Paul
