Código do Sketch
#include <SPI.h>
#include <String.h>
#include <Ethernet.h>
#include <SD.h>
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x9B, 0x36 }; //physical mac address
byte ip[] = { 192, 168, 1, 100 }; // ip in lan
byte gateway[] = { 192, 168, 1, 2 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
int led1 = 5;
//int led2 = 6;
//int led3 = 7;
String readString = String(30);
String statusLed;
File webFile;
Ethernet.begin(mac, ip, gateway, subnet); // initialize Ethernet device
server.begin(); // start to listen for clients
Serial.begin(9600); // for debugging
pinMode(led1, OUTPUT);
// pinMode(led2, OUTPUT);
// pinMode(led3, OUTPUT);
// initialize SD card
Serial.println("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
Serial.println("SUCCESS - SD card initialized.");
// check for index.htm file
if (!SD.exists("index.htm")) {
Serial.println("ERROR - Can't find index.htm file!");
return; // can't find index file
Serial.println("SUCCESS - Found index.htm file.");
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
// last line of client request is blank and ends with \n
// respond to client only after last line received
if(readString.length() < 30){
readString += (c);
if (c == '\n' && currentLineIsBlank) {
// FAZ A VERIFICAÇÃO PRA ACENDER OU APAGAR O LED
if (readString.indexOf("1") >=0) {
digitalWrite(led1, !digitalRead(led1));
// if (readString.indexOf("2")>=0)
// digitalWrite(led2, !digitalRead(led2));
// if (readString.indexOf("3") >=0)
// digitalWrite(led3, !digitalRead(led3));
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
// send web page
webFile = SD.open("index.htm"); // open web page file
if (webFile) {
while(webFile.available()) {
client.write(webFile.read()); // send web page to client
webFile.close();
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
readString = "";
client.stop(); // close the connection
Código da Pagina HTML
<!doctype html>
<html>
<head>
<title>TESTE WEB SERVER SD CARD</title>
<meta name="viewport" content="width=320">
<meta name="viewport" content="width=device-width">
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1.0, user-scalable=no">
</head>
<body>
<center>
<font size="5" face="verdana" color="green">WEB SERVER ARDUINO</font>
<font size="3" face="verdana" color="red"> & </font>
<font size="5" face="verdana" color="blue">SD CARD</font><br />
<form action="1" method="get">
<button type=submit style="width:200px;">Led 1</button>
</form> <br />
<form action="2" method="get">
<button type=submit style="width:200px;">Led 2</button>
</form> <br />
</center>
</body>
</html>
