Trying to think of things which could slow down a lot of writes to an LCD, I see that you have quite a few pins in use, but ?no? mention of pullup resistors. Does the screen or adafruit recommend anything ?
Your code looks as though it is going to presume 30k pullup built in, which might require comms to go slower than their best or be less reliable than ideal, especially if you have more than 6 inches of cabling from microcontroller to display. Various opinions abound about adding external pullup resistors from a digital pin to arduino Vcc, but I found 10kOhm or 3.3kOhm more likely to work than none at all and necessary when using a few feet of cables.
