bodmer:
Just checked the library and it works fine with a Mini Pro. The only other gotcha I can think of (apart from not using hardware SPI pins and an edit error in User_Setup) is that you are using a really old and outdated version of the IDE. You need to use the latest 1.6.x IDE
managed to get library working, now could use a bit of help "translating" my code which uses the Adafruit Library, to yours
