Topic: Assistance with Code to Control 4 Relays with Wireless Remote Quote (Read 456 times) previous topic - next topic
AIRA3
Ok here is the "base" code I started with. I need help modifying this code to allow my 4 channel wireless device (Gikfun IC2262/2272 4 Channel Wireless Remote Control Kit) to control the on/off of each relay. I will be inputting the pins from the wireless board onto the Arduino on A2, A3, A4, and A5 to correspond with each relay, unless someone suggests using digital pins instead;
Code: [Select]
/*-----( Declare Constants )-----*/
#define RELAY_ON 0
#define RELAY_OFF 1
/*-----( Declare objects )-----*/
/*-----( Declare Variables )-----*/
#define Relay_1  2  // Arduino Digital I/O pin number
#define Relay_2  3
#define Relay_3  4
#define Relay_4  5
void setup()   /****** SETUP: RUNS ONCE ******/
//-------( Initialize Pins so relays are inactive at reset)----
  digitalWrite(Relay_1, RELAY_OFF);
  digitalWrite(Relay_2, RELAY_OFF);
  digitalWrite(Relay_3, RELAY_OFF);
  digitalWrite(Relay_4, RELAY_OFF);
//---( THEN set pins as outputs )----
  pinMode(Relay_1, OUTPUT);
  pinMode(Relay_2, OUTPUT);
  pinMode(Relay_3, OUTPUT);
  pinMode(Relay_4, OUTPUT);
  delay(4000); //Check that all relays are inactive at Reset
}//--(end setup )---
void loop()   /****** LOOP: RUNS CONSTANTLY ******/
//---( Turn all 4 relays ON in sequence)---
  digitalWrite(Relay_1, RELAY_ON);// set the Relay ON
  delay(1000);              // wait for a second
  digitalWrite(Relay_2, RELAY_ON);// set the Relay ON
  digitalWrite(Relay_3, RELAY_ON);// set the Relay ON
  digitalWrite(Relay_4, RELAY_ON);// set the Relay ON
  delay(4000);              // wait see all relays ON
//---( Turn all 4 relays OFF in sequence)---
  digitalWrite(Relay_1, RELAY_OFF);// set the Relay OFF
  digitalWrite(Relay_2, RELAY_OFF);// set the Relay OFF
  digitalWrite(Relay_3, RELAY_OFF);// set the Relay OFF
  digitalWrite(Relay_4, RELAY_OFF);// set the Relay OFF
  delay(4000);              // wait see all relays OFF
}//--(end main loop )---
Please advise with a quote to fix this sketch to work for my application. Thank you.
patduino
There are 10 types of people in the world, those who understand binary, and those that don't.
