First of all, PLEASE read the How To Use This Forum thread before you post. I had to do alot of googling, which most people WILL NOT DO, simply because you failed to tell us basic things about your problem, such as:
The library you were using, and
Your code, which would have showed me the library you were using
Anyway, here is what I found in the library I ASSUME you are using...
long cycles = (F_CPU / 2000000) * microseconds; // the counter runs backwards after TOP, interrupt is at BOTTOM so divide microseconds by 2
if(cycles < RESOLUTION) clockSelectBits = _BV(CS10); // no prescale, full xtal
... //removed because irrelevant
else cycles = RESOLUTION - 1, clockSelectBits = _BV(CS12) | _BV(CS10); // request was out of bounds, set as maximum
RESOLUTION is set to 65536 because Timer1 is a 16bit timer.
cycles = (16,000,000 / 2,000,000) * 60,000,000 = 480,000,000
So, cycles is NOT less than RESOLUTION - 1, therefore it was more than maximum
This code sets the prescaler to 1024, as slow as you can get.
A prescaler of 1024 allows for a maximum time of 8388.608mS or ~8.3 seconds
