Topic: Librería gameduino 2 modificada para pantallas FT81X  (Read 56778 times) previous topic - next topic
TFTLCDCyg
#195
Jul 04, 2017, 08:41 pm Last Edit: Sep 20, 2017, 09:17 am by TFTLCDCyg
Han sido días explorando esta opción. Espero subir pronto algún ejemplo y por supuesto, a la espera de que otros experimenten con este tipo de MCU, que también se pueden programar con el IDE de arduino.
Saludos
FT81XMania
ft81xmania.com/comunidad/
Donziboy2
Hello everyone, I wanted to thank you guys for all the work you have done.
I recently started playing with some HotMCU FT811 5" screens and was wondering if there would be any easy way to run multiple screens on a Teensy 3.2 or 3.6.  So far the only thought I have had is to use a second MCU to run the second screen and just send data from the Teensy.
TFTLCDCyg
Two screens FT8XX on the same teensy, is not possible with the  library.
Maybe through serial communication between two teensy´s boards, with one TFT in each MCU
For some time I put two screens: FT801 and oled SD1331 on an arduino due
Donziboy2
Hmm, are resources kept on the Teensy?
If not maybe we could just sneak an external CS control to jump between selecting one screen and the next.
Armadafg
HI,
Have you seen the replacements for the FT81x ? THE BT815 / 6
http://www.ftdicommunity.com/index.php?topic=89.new;topicseen#new
http://brtchip.com/bt81x/
surbyte
Este es un foro en Español, y mas allá del interés que tenga una persona de otro idioma debe respetar el idioma del foro.
Asi que no usar inglés para preguntar/responder
Lean las
Normas del foro.
How to use this forum
Armadafg
