Topic: Combining VirtualWire and IRLib fails (Read 789 times) previous topic - next topic
FloStar3000
Hello everyone,
i am building on a "universal remote" that is supposed to use an Arduino to send IR signals to the individual devices (Projector, HiFi/BluRay, SAT Receiver) in our Home Cinema while it receives the input from another Arduino (the actual Remote) with those RF Links, because you cannot use 2 IR Receivers/Transmitters in the same room and the IRLib does not support sending and receiving at the same time either.
Now i have no problem using the RF Link/VirtualWire or the IR system individually, but combining them doesn't seem to work as intended. What am I doing wrong?
Much thanks for any advice
Code: [Select]
//TRANSMITTER (UNO)
#include <VirtualWire.h>
const int ledPin = 13;
const int txPin = 7;
const int button1Pin = 6;
const int button2Pin = 5;
boolean button1State = false;
boolean button2State = false;
  vw_set_tx_pin(txPin);
  vw_setup(2000);
  pinMode(ledPin, OUTPUT);
  pinMode(button1Pin, INPUT);
  pinMode(button2Pin, INPUT);
  button1State = digitalRead(button1Pin);
  button2State = digitalRead(button2Pin);
  if(button1State == HIGH){
    digitalWrite(ledPin, HIGH);
    vw_send((uint8_t *)"]", 1);
  else if(button2State == HIGH){
    vw_send((uint8_t *)"2", 1);
      digitalWrite(ledPin, LOW);
Code: [Select]
//RECEIVER (MEGA)
#include <IRLib.h>
const int RxPin = 11;
IRsend MySender;
  vw_set_rx_pin(RxPin);
  vw_setup(2000);
  vw_rx_start();
  uint8_t buflen = VW_MAX_MESSAGE_LEN;
  uint8_t buf[buflen];
  if(vw_get_message (buf, &buflen)){
    for(int i = 0; i < buflen; i++){
      Serial.print(buf[i]);
    delay(200);
    MySender.send(NEC, 0x8b7fa05, 32);
jremington
Check the documentation for timer usage. There may be a conflict with Timer1.
INTP
Pause- "because you cannot use 2 IR Receivers/Transmitters in the same room "
If your project is based on this false premise and becomes needlessly more convoluted, I'd recommend resolving this misunderstanding and reconsider the setup.
FloStar3000
Sorry that was a false statement. It's just that the IRLib didn't allow me to send and receive in the same sketch and my assumption that RF works better in my case why i chose to use the RF links. It's also me wanting to get involved more with the use of the RF links and VW library.
I already tried the the timers 2 (default) and 3 but it didn't work as well.
DrAzzy
When you say "it doesn't work as intended" what does that mean?
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
FloStar3000
I thought i could easily combine the 2 sketches i made earlier to test either the IRLib and VW functionality but it didn't work out or what do you mean?
jremington
Quote
it didn't work out
This phrase means nothing to us, and we can't help.
INTP
Pins 5 and 6: controlled by Timer0
Pins 9 and 10: controlled by Timer1
Pins 11 and 3: controlled by Timer2
*Not sure if Mega is the same.
I had also found Pin 11 to be no bueno for RF usage with the VirtualWire because of its interrupt usage of Timer2
Changing pins around is probably worth a shot.
jremington
Quote
By default, VirtualWire uses Timer1.
FloStar3000
Sorry for any comprehensibility issues. I'm from germany. What I did before to test the code is incidental.
It's just the code i posted which i thought would work but doesn't. And i'm asking you why.
INTP
Is your IR LED on pin 13?
That's a problem. It needs to be on a PWM pin.
FloStar3000
from the IRLibTimer.h:
Code: [Select]
/* Arduino Mega */
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
 //#define IR_SEND_TIMER1 11
 #define IR_SEND_TIMER2 9
 //#define IR_SEND_TIMER3 5
 //#define IR_SEND_TIMER4 6
 //#define IR_SEND_TIMER5 46
Now the compiler shows an error with my code even though i wrote the code again entirely. The universe hates me. I'll try it again tomorrow. Thanks guys.
PS:
On Mega pins 2-13 are PWM. But I don't use pin 13 anyway
INTP
Oh, okay. I don't have a Mega and haven't used that IR library you're using. I used IRremote.
Can you give any useful information about where it is failing? Is the IR LED transmitting anything? Look at the LED through your phone cam and see if it lights up.
FloStar3000
I know that the RF message is received and the IR Led lights up. The IR Code sent is correct as well, because the demo sketch works with it.
INTP
So you're saying it works as intended but your devices aren't responding to the IR output?
