Topic: [IDE] request: indentation for the if-else directives #if, #ifdef, #ifndef, ... (Read 2138 times) previous topic - next topic
compsystems
Hello
Please adhere to the indentation AutoFormat for the if-else directives #if, #ifdef, #ifndef, #else, #elif and #endif
Before  :(
Code: [Select]
#define STEPPER NEMA17
#if STEPPER == NEMA17
#define DEFTFULLSTEPS 200 // MM
#else
#endif
#define BELT GT2
#if BELT == GT2
#define BELTPITCH 2 // MM
#define PULLEYNUMBERTEET 20
#else
#endif
#define SCREW S5MM //
#if SCREW == S8MM
#define THREADPITCH 1.25 // MM,
#else
#if SCREW == S8MM
#define THREADPITCH 1 //1 MM
#else
#endif
#endif
Aafter  :o
Code: [Select]
#else
#endif
#define BELT GT2
#if BELT == GT2
#else
#endif
#if SCREW == S8MM
#else
  #if SCREW == S8MM
    #else
    #endif
#endif
Good idea?
pert
Just add indent-preproc-block to {Arduino IDE installation folder}/lib/formatter.conf.
compsystems
Thanks for your reply
I want the solution is for all people, of course that is configurable menu (File menu/Preferences),
How you can add this to the source code and that future versions of arduinoIDE
Thanks
Another example
Code: [Select]
#ifdef SDCC
    #if DEBUGGING == 1
        #if defined (uctrl)
            #define FLASH_MEMORY_END 0x3DC0
        #elif defined (uctrl)
            #define FLASH_MEMORY_END 0x7DC0
        #else
            #error "Can't set  up flash memory end!"
        #endif
    #else
        #if defined (uctrl0)
            #define FLASH_MEMORY_END 0x4000
        #elif defined (uctrl1)
            #define FLASH_MEMORY_END 0x8000
        #else
        #endif
    #endif
#else
    #if DEBUGGING == 1
    #else
    #endif
#endif
kewakl
Thanks
