Topic: problem with conditional statement (Read 5201 times) previous topic - next topic
lefstin
Might this be a problem with running out of RAM, rather than a problem with your code?  (that seems to be the usual answer when otherwise inoffensive code clobbers your application)
meg
the RAM theory is interesting.  i went back to my original code with the switch case for three buttons.  works fine.  as soon as i wrap the switch case in a conditional statement (perhaps heresy in the c world, i'm used the the squishy reality of javascript) the board chokes again.
at the moment i'm using a lilypad but for my final project i'll be using a mini 328 which has a whopping 2KB of RAM - i'll post back here if it works!
thanks everyone for the help!  i've learnt so much in this thread!  :D
meg
just in case anyone is searching for the solution to a similar problem, this was solved by using a board with more RAM!  :)
