Topic: 3 axis auto stabilized platform (Read 82056 times) previous topic - next topic
axileon
alright. here it is.
Code: [Select]
 if(++Channel > MAX_CHANNELS)
                   Channel = 1;       //reset the channel counter to 1
                   if(Channel == 1)
                   digitalWrite(a,LOW);
                   digitalWrite(b,LOW);
                   digitalWrite(c,LOW);
                   digitalWrite(g,LOW);
                    else if(Channel == 2)
                   digitalWrite(a,HIGH);
                  else if(Channel == 3)
                   digitalWrite(b,HIGH);
                   DataAvailable = true;  // this line is needed to indicate that the channel data is valid!!!!
the debug screen actually prints all 3 channels with the same value(channel 1)....
so, how do i actually configure the code to print all the 3 different channel values then?
axileon
hi i changed my code. i managed to get it working right now... just that there appear to be another problem.
i have connected the receiver in sequence 0,1,2
however the debug screen prints
chn 1 as receiver chn 2
chn 2 as receiver chn 0
chn 3 as receiver chn 1
Code: [Select]
Pulses[Channel] = ICR1 / TICKS_PER_uS;  // store pulse length as microsoeconds
              if(Channel == 1)
also.. i'm using the serial servo program to update the servos.. but the gap in in between pulses is too long... do you  know of a better way to pulse the servos accurately?
mem
#32
Mar 08, 2008, 10:09 am Last Edit: Mar 08, 2008, 10:20 am by mem Reason: 1
I composed the following while you where posting the above. Have a read of this while I read your post:
modify the code as below so that the multiplexer channel selection is outside the  brackets. I have moved it to a separate function of convenience. This code also turns the output of the multiplexer off when selecting.
Code: [Select]
SelectChannel( Channel)
void SelectChannel( int channel){
   digitalWrite(g,HIGH);  // turn the output off while twiddling select bits
   if(Channel == 1)
    digitalWrite(c,LOW);   // c is always low
    digitalWrite(g,LOW);  // turn output on
edit: looks like you made the fix to move the Channel Selection outside the brackts. But you should add the code to gate the multiplexer off when writing the selection pins.
If you post your servo code will see if I can help. But in principle you want to update the servo every 20 milliseconds using whatever data is in the channel array after the DataAvailable flag is set to true
Note that the channel array is updated only every 40 ms or so but the servos should be pulsed every 20ms.
mem
Here is a suggestion that I hope helps:
Code: [Select]
void PulseServo( int channel, int pulsewidth ){
//   your code here to pulse the servo for the given channel with the given pulse width
// you should check that pulsewidth is within the valid range for your servos
void loop()                     // run over and over again
  if(DataAvailable == false)
      Serial.println("The decoder has not detected all channels ");
  else{
      PulseServo(1,GetChannelPulseWidth(1);
      delay(6);
      PulseServo(2,GetChannelPulseWidth(2);
      delay(6);
      PulseServo(3,GetChannelPulseWidth(3);
      delay(6);
axileon
hi... thanks for your help so far.. i managed to get it working already.  :)
Code: [Select]
void PulseServo(int channel,int pulsewidth)
 int pulse = 0;
 int pin_num = 0;
 pin_num = channel + 1;
 pulse = pulsewidth;
 if ((pulse <= 2200) && (pulse >= 600))
   digitalWrite(pin_num, HIGH);
   delayMicroseconds(pulse);
   digitalWrite(pin_num, LOW);
however... the servo is a litter jerky..... i check the pulse on the scope.... when everything is stationary... the PWM seems a bit unstable.. the pulses keeps moving left right right left... though the time between pulses is still ok..
do you have any idea what is causing the pulses to be moving?
mem
#35
Mar 10, 2008, 08:40 am Last Edit: Mar 10, 2008, 08:41 am by mem Reason: 1
You could send the pulse width to the serial port so you can inspect what is being sent to the servo.
Something like this would do the trick
Code: [Select]
 // note that pulse variable is not needed and has been removed
 int pin_num = 0;
 if ((PulseWidth <= 2200) && (PulseWidth >= 600))   // 600 is a little low, try it with 800
   delayMicroseconds(PulseWidth);
 else {
     ; you may want to add code here to blink a LED if Pulse WIdth is out of range
 Serial.print("chan ");
 Serial.print(Channel);
 Serial.print("=");
 Serial.print(PulseWidth);
 Serial.print(", ");
axileon
#36
Mar 10, 2008, 09:39 am Last Edit: Mar 10, 2008, 11:35 am by axileon Reason: 1
hey. thanks.. actually i'm using timer 0 and timer 2 for do a PWM for the servos.... timer 1 will be used for the ICP.....
the code is as follow...
Code: [Select]
#include <avr/io.h>
#include <avr/interrupt.h>
int servoRoll = 6;
int servoPitch = 5;
int servoYaw = 11;
 pinMode(servoRoll, OUTPUT);
 pinMode(servoPitch, OUTPUT);
 pinMode(servoYaw, OUTPUT);
/* setup for timer 0 */
 TCCR0A = _BV(COM0A1) |  _BV(COM0B1) | _BV(WGM01) | _BV(WGM00);  // clear both A n B on compare match, set fast PWM mode.
 TCCR0B = _BV(CS02) | _BV(CS00); // set prescaler of 1024 for 8 bit timer - 0 to 255.
 TIMSK0 = _BV(OCIE0B) | _BV(OCIE0A) | _BV(TOIE0) ; // enables the interrupt for the
 OCR0A = OCR0B = 0x18; // 0x18 = 24 = 1.5 ms
/* end of setup for timer 0 */
/* setup for timer 2 */
 TCCR2A = _BV(COM2A1) | _BV(WGM21) | _BV(WGM20);  // clear both A on compare match, set fast PWM mode.
 TCCR2B = _BV(CS22) | _BV(CS21) | _BV(CS20); // set prescaler of 1024 for 8 bit timer - 0 to 255.
 TIMSK2 = _BV(OCIE2A) | _BV(TOIE2) ; // enables the interrupt for the
 OCR2A = 0x18; // 0x18 = 24 = 1.5 ms
/* end of setup for timer 2 */
 sei();
 cli();
 OCR2A= 16;
 sei();
 delay(17);
   cli();
 OCR2A = 32;
 sei();
 delay(17);
i discovered that i can only use 1 of the timers for this purpose.. not two. if i use two and one of them is correct, the other has something wrong with the pulse.
actually we cant keep changing the OCRXX values right? but my counter will overflow after 16 ms right? that means I should be able to vary the pulse for the motor right?
mem
The resolution is pretty low using the 8 bit counters and that may explain why the servos are not smooth.
Any reason you can't use a simple delay instead of the timers for driving the servos similar to reply #33 above? You have at least 14 milliseconds to do any calculations between pulsing the servos and because your data is changing every two frames you can spread this over 28 milliseconds if you need to.
axileon
the waveform of the servo is too inconsistent if i use other methods rather than interrupt to generate them...
but i thought timers are supposed to be more accurate than if we use digitalwrite hi's and low's?
mem
If an 8 bit timer count of 24 is 1.5ms then each step is over 60 microseconds. It should be within a microsecond if you use delayMicrosecond. Have you tried it using the delay instead of the timer?
axileon
i am aware of the low resolution if i use an 8 bit counter.. but my professor advises me to use interrupt for the timing of the servos....
i will try the delay thing again tomo... i tried it lasttime... the gap between pulses is too long... and its also quite jerky... maybe its the cycling of the timer..
if i throw in the code for the gyros.. then most probably everything will be haywire again...
mem
#41
Mar 10, 2008, 03:28 pm Last Edit: Mar 10, 2008, 03:51 pm by mem Reason: 1
If this is for a school project then keeping your professor happy is an important requirement  ;)
My suggestion is that this is a good time to try and determine how much processing time you need per frame. If this time is more than around 15 milliseconds but less than around 30ms then consider if it is acceptable to use two frames for your calculations (the channel inputs are only updated every other frame because of the way we have implemented the multiplexer). If you need a lot more than 15 milliseconds and the data does need to be refreshed every frame (20 ms),  or you need more than 30ms to do your calculations  using two frames,  then you are getting close to exceeding the Arduino's processing capability even if you could run the servos and input capture all on interrupts.
for example, the following pulses the servos every 20ms and give around 30ms of calculation time every 50ms (two frames):
start of frame n
 pulse three servos in sequence (4-6 ms)
 start calculating new pulse width (15ms)
end of frame n
start of frame n+1
 pulse three servos in sequence using previous frame data (4-6 ms)
 finish calculating new pulse width (15ms)
end of frame n+1
repeat...
bloke
Hi, Sorry to join this thread so late in the piece. I am slowly making progress on a similar project but to stabilise a quad copter. I have gathered snippets of code and ideas from all sorts of places, most notably a UAVP project in Europe. It is worth a google of UAVP and a look at their site if you have not already done so. They make a lot of their code available and there are lots of clues there on how to decode the stream and in fact to deal with sensors you mentioned above. I am now at the stage where I have the raw RC 'stick' values captured and have mastered comms with the sensors. When you get to the point of dealing with PID code etc, would love to compare notes.
axileon
hi.. i tried the usual way of digitally writing the servos... i found that the problem is when the program is looping... sometimes there's a gap which has no pulses
i think that's the reason why its resulting in the servos reacting this way...
i'm thinking whether is it because of the IF loop?
axileon
Quote
hi.. thanks for replying.. i took a look at hte opensource thing... actually i'm quite rushing for time to finish the project.. i look at the source code of the quadcopter.. but its too complicated for me. haha..
