What is the correct sequence of calls to delete a file when using SdFat?
I see the warning on the file.remove() about 8.3, are you saying to use the lfn if it exists?
SdFat.remove() wants a 8.3 file name?
Is this a proper sequence?
SdFile file;
file.open(name,O_READ);
file.remove(name);
? file.close();
// or just
SdFile file;
file.remove(name);
// or
SdFat sd; // open it also
SdFile file;
char buff[64];
file.getSFN(buf);
file.close();
sd.remove(buf);
Sorry, I'm missing something.
Edit, Added another Question:
How do I release an SdFat object correctly? I can see how to initialize an SdFat object:
SdFat *sd;
sd = new SdFat;
sd->begin(cs,SPI_FULL_SPEED);
But, when I am finished with it what is the correct method to shut it down? I have already closed all files using it.
PaulS:
You can't remove a file that is open, so that is not the correct sequence.
Yes. But, why are you creating an(other) instance using new?
SdFat sd;
sd.begin(cs,SPI_FULL_SPEED);
Then, you don't need to worry about deleting anything.
I have built a FAT file system for EEPROM and FLASH that is being used for a html Server. (MEGA+Ethernet). It supports multiple 'domains' basically each EEPROM (24LCxx) is a 'domain' or I guess a 'drive'. The system is designed to allow mounting and dismounting of the domains in real time.
I am in the process of adding SdFat as another data source. My server code can server pages from the MEGA's FLASH, external EEPROM, SPIRAM, SPIFLASH. I want mounting and dismounting ability so that SDcards act the same as my other storage devices. I want all of the data devices to be equivalent for the Server.
Here is what navigating to server/eeprom/56/ cause the Mega to display:
my webserver code supports Server Side Includes (SSI), GET, PUT, POST. I had fun including EXEC functions that allow direct access to Arduino funtions and routines. This little server allows me a simple system to play with HTML client side code. But standard EEPROMs are only 64KB, and my SPIFLASH is only 8MB, I want the gigabytes of a SDcard.
I have read through many of the Doxygen html reference pages, but I have not found any pages that are overview or theoretical or best practice guides. Are there any guides for SdFat?
My question on the correct Creation/Destruction procedure came from the realization that SdFat supports multiple cards at the same time and that a 'current drive' can be selected by sd.chvol(). This presupposes a global instance or static indicator of a 'current' SdFat Object. My concern is that I have not identified the correct method to 'close' a SDcard. I want to support insertion and removal of the SDcard such that a simple inuse LED can be displayed for safe insertion and removal.
All of the examples do not have an explicate shutdown sequence. They just run off the end, and leave the sd() object active until reset or power down?
If the file is open for write use remove like this. You don't need to close the file after the remove call since the file no longer exists.
// open file
if (!file.open("My file.txt", O_RDWR)) {
// handle open error
// done with file.
if (!file.remove()) {
// handle error.
If the file is not open use remove like this.
SdFat sd;
// initialize.
if (!sd.begin(CS_PIN)) {
// later
if (!sd.remove("My File.txt")) {
// handle error
The caution about 8.3 names only applies if the file was created with a long name and you know the short name and use it to open the file. The directory entries for the long name will not be deleted.
So if the long name is "This is a lfn.txt" don't use THISIS~1.TXT to remove the file.
// open file
// done with file.
// handle error.
SdFat sd;
// initialize.
// later
// handle error
Thanks,
That explains my confusion about deleting files.
Do I need to do anything special to close down the file system before I eject the SDcard? Or just Close all open files and pop the card?
DaveEvans: @chucktodd, did you ever find an answer you believe/trust to your question...
Never gained an Authoritative answer.
I have not encountered any problems, (memory leak, resets, etc..) by following these steps:
SdFat* sd;
sd = new SdFat;
if(!sd->begin(CSPin,SPI_FULL_SPEED)){
// failed, heartache and Die!
delete sd;
else { //use sd, remembering to close all SdFile object that reference sd
// before every Open, Delete, access to sd
sd->chvol(); // set this SdFat as the 'current drive'
SdFile* file; // create pointer for 'file'
file = new SdFile; // allocate memory, initialize SdFile Object
file->open(fileNamecString,O_READ); // open file in 'current drive'
// access file
file->close();
delete file; // run destructor for SdFile Object, free Heap variable;
delete sd; // all done with SdCard, run Object Destructor, Free Heap Variable
There is no end() call, you only need to close all files before removing the card.
On a related note (not sure if it is of use to you), in that same thread, fat16lib said that the SdFat library can handle multiple "begins," so you can eject a card, insert a new one, and "begin" with the new card. Apparently the SD library has a bug that prevents doing that.
