Topic: Compile array larger than 65k (Read 1 time) previous topic - next topic
Lucario448
Hello there. Lemme explain what's the deal.
I'm trying to store into the program's memory (PROGMEM), a really large array of bytes (actually a 2 seconds and 1 sec of 22 KHz 8-bit stereo samples); but this won't let me compile due to the following reason:
Code: [Select]
too many initializers for 'const unsigned char [798]'
And this is the part of the code that doesn't let me compile:
Code: [Select]
#include <avr/pgmspace.h>
const unsigned long far_len = 132554UL;
const unsigned char far[far_len] PROGMEM = {/* lots of bytes */}
I guess the compiler only can handle 16-bit pointers (thus below 65k is fine). Is it true?
So, is there a way can I compile it? Or should I appeal for a workaround in the code?
Best regards.
PD: to program such large array, I'm obviously using an Arduino Mega.
septillion
#1
Sep 20, 2016, 10:36 pm Last Edit: Sep 20, 2016, 10:37 pm by septillion
Tried it here and it compiles just fine. But the error message isn't complaining about the size of the array...
The problem is here:
Code: [Select]
The compiler is complaining that "lots of bytes" is more then the 798 bytes you told it it is... So maybe do a recount ;)
And again, it shows the forum rules are there for a reason... Don't post snippets!
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
Lucario448
Oh should I post the whole thing? Well, there it is in the attachment, because the arrays wouldn't let me post.
It's in a zip file; it contains the sketch itself, and the header files containing the large arrays.
It still might not compile but for other reasons I will later solve.
The sketch uses this library.
Thanks! :)
Lucario448
Update: if the previously provided library's link appears to not let compile the sketch, then try to download it here.
I totally forgot where I got it... :smiley-confuse:
Thanks again.
el_supremo
Unless there's some sort of FAR pointer on the MEGA (which I doubt), pointers on the Arduino are 16 bits so it can't address more than 65536 bytes of memory.
Looks like you'll need to invest in a 32-bit beast.
Pete
Don't send me technical questions via Private Message.
pYro_65
Pete
Only PROGMEM pointers on the mega have a far variant (24bit). But these are only used to reach data in flash that is located over the 65k boundary. The data types stored there are still limited to 16 bit widths.
Forum Mod anyone?
https://arduino.land/Moduino/
Lucario448
Code: [Select]
#define ADDR(var)({uint_32t a; asm("ldi %A0, lo8(%l)\n ldi %B0, hi8(%l)\n ldi %C0, hlo8(%l)\n ldi %D0, hhi8(%l)": "=d"(a): "p"(&(var))); a;})
I found somewhere that this macro generates a 32-bit pointer; but I have no idea at all about how to use it.
Yeah, it will be funny if the 2560 microcontroller couldn't address all its program memory. :o
I think I have an idea: I could workaround the data type limitation by splitting up the arrays, but I'm afraid about if that makes a non-contiguous array writing (one followed by the other).
Also I guess I can use the pgm_read_byte_far function to deal with 24/32-bit pointers; however, how can I retrieve (or even create) a pointer of that size? (not a long* pointer)
Lucario448
Update: now I splitted up the arrays into ones of a length, at most, of 65535 (aka unsigned 16-bit maximum value).
However, compiler is still complaining; now it says that the "size of array 'nameOfArray' is too large".
What's the maximum length then? 32k? (32767)
I'll appreciate any answer...
AWOL
Feel free to share any details you may deem necessary.
pYro_65
Forum Mod anyone?
Lucario448
#10
Sep 22, 2016, 02:16 am Last Edit: Sep 22, 2016, 07:46 am by Lucario448
All right thank you very much!
I also had to remove the macro usage, in order to finally compile my sketch, but... I can't listen anything
My idea is to output some audio by using a 8-bit-timer-driven PWM signal, changing the duty cycle by using the OCRxA and OCRxB registers.
I have the idea that 2560's timer0 is an 8-bit one; and it maps to the Arduino pins 4 and 13. Am I correct?
Furthermore, I tried to use a function that changes the prescaler of timer0, taken from the Arduino Playground (see code below); yet don't know if it's actually valid for the 2560's timer0.
Ladies and gentlemen, here's the code:
Code: [Select]
#include "close0.h"
#include "close1.h"
#include "close2.h"
#include "far0.h"
#include "far1.h"
#include "far2.h"
#include "far3.h"
#include "far4.h"
#include <TimerOne.h>
// Files and library required on this sketch
volatile unsigned long count = 0;
  //pinMode(2, INPUT_PULLUP);
  pinMode(4, OUTPUT); // Left
  pinMode(13, OUTPUT); // Right
  // setting up the pin.
  setPwmFrequency(5, 1); // I use 5 because this function is made for ATmega328P, but it should still set timer0's prescaler
  // Adjust the PWM frequency to the highest possible. Thus, the second argument must ALWAYS be 1.
  // Do not use the Timer0 (pins 5, & 6), otherwise "delay" and "millis" functions may not work properly.
  analogWrite(4, 1); // Initialize PWM mode on that pin (timer)
  analogWrite(13, 1);
  Timer1.initialize();
  cli();
  Timer1.attachInterrupt(writeSamples, 45); // 45 microseconds should yield an interrupt rate of 22 KHz,
// which is the intended sampling rate.
  sei();
  pgm_read_byte(&close0[0]);
  pgm_read_byte(&close1[0]);
  pgm_read_byte(&close2[0]);
  pgm_read_byte(&far0[0]);
  pgm_read_byte(&far1[0]);
  pgm_read_byte(&far2[0]);
  pgm_read_byte(&far3[0]);
  // Forces compiler to write these arrays, even if we apparently aren't using them.
void loop() {}
void writeSamples() { // Thankfully TimerOne library allows me to declare a timer-based ISR more friendly
  if (count == 253952UL) // 253952 bytes is the 2560 total program memory, right?
  count = 0;
  OCR0B = pgm_read_byte_far(count); // I think the "far" function is for 24 or 32-bit pointers.
  count++;
  OCR0A = pgm_read_byte_far(count);
  count++;
  // Scan throughout the program memory to figure out where the heck are the samples (arrays) written.
  // Not by showing up, but by listening. I will later figure it out by dumping on a SD card.
void setPwmFrequency(int pin, int divisor) {
  // A function that modifies the PWM frequency of the specified pin.
  // Taken from http://playground.arduino.cc/Code/PwmFrequency
  byte mode;
  if (pin == 5 || pin == 6 || pin == 9 || pin == 10) {
    switch (divisor) {
      case 1: mode = 0x01; break;
      case 8: mode = 0x02; break;
      case 64: mode = 0x03; break;
      case 256: mode = 0x04; break;
      case 1024: mode = 0x05; break;
      default: return;
    if (pin == 5 || pin == 6) {
      TCCR0B = TCCR0B & 0b11111000 | mode;
      TCCR1B = TCCR1B & 0b11111000 | mode;
  } else if (pin == 3 || pin == 11) {
    switch (divisor) {
      case 32: mode = 0x03; break;
      case 64: mode = 0x04; break;
      case 128: mode = 0x05; break;
      case 256: mode = 0x06; break;
      case 1024: mode = 0x7; break;
      default: return;
    TCCR2B = TCCR2B & 0b11111000 | mode;
If you are going to attempt to compile it, then ask me for the necessary files; or just delete all includes except TimerOne, and the pgm_read_byte lines on the setup.
Thank you one more time! :)
PD: hope that the timer0 has been set to "fast PWM" mode by default, and not to "phase-correct" mode.
Lucario448
Hello again, I'm back right now.
Finally I solved the problem of the 32-bit pointers, and arrays sizes.
Everything looked good to go... but, there's another problem: I got no sound
This is the code I'm currently using:
Code: [Select]
#include "close0.h"
#include "close1.h"
#include "close2.h"
#include "far0.h"
#include "far1.h"
#include "far2.h"
#include "far3.h"
#include "far4.h"
// 8-bit LPCM stereo samples
#define GET_FAR_ADDRESS(var)                          \
    uint_farptr_t tmp;                                \
    __asm__ __volatile__(                             \
        "ldi    %A0, lo8(%1)"           "\n\t"    \
        "ldi    %B0, hi8(%1)"           "\n\t"    \
        "ldi    %C0, hh8(%1)"           "\n\t"    \
        "clr    %D0"                    "\n\t"    \
        "=d" (tmp)                                \
        "p"  (&(var))                             \
    tmp;                                              \
// Here's how I get 32-bit (or 24-bit) pointers
volatile unsigned int sampleCount = 0;
volatile byte pointerIdx = 0;
volatile boolean selector = HIGH;
uint_farptr_t cp[3];
uint_farptr_t fp[5];
const unsigned int cl[] = {close0_len, close1_len, close2_len};
const unsigned int fl[] = {far0_len, far1_len, far2_len, far3_len, far4_len};
// Covinient way to address the audio data
  pinMode(4, OUTPUT); // Left (OCR0B)
  pinMode(13, OUTPUT); // Right (OCR0A)
  cp[0] = GET_FAR_ADDRESS(close0);
  cp[1] = GET_FAR_ADDRESS(close1);
  cp[2] = GET_FAR_ADDRESS(close2);
  fp[0] = GET_FAR_ADDRESS(far0);
  fp[1] = GET_FAR_ADDRESS(far1);
  fp[2] = GET_FAR_ADDRESS(far2);
  fp[3] = GET_FAR_ADDRESS(far3);
  fp[4] = GET_FAR_ADDRESS(far4);
  // I tested it out, and it actually give me the pointers I need; because some of them point out of the 64 KB range
  TCCR0B = TCCR0B & 0b11111000 | 0x01; // Timer0, prescaler 1. Right?
  analogWrite(4, 1); // Initialize PWM mode on that pin (timer)... I guess
  analogWrite(13, 1);
  cli();
  Timer1.attachInterrupt(writeSamples, 45); // attachInterrupt(ISR, 22050 Hz)
  sei();
  // Nothing yet...
  if (selector) {
    OCR0B = pgm_read_byte_far(fp[pointerIdx] + sampleCount); // Even indices for left channel
    sampleCount++;
    OCR0A = pgm_read_byte_far(fp[pointerIdx] + sampleCount); // Odd indices for right channel
    sampleCount++;
    if (sampleCount == fl[pointerIdx]) { // End of the fragment?
      sampleCount = 0;
      pointerIdx++; // Next one
      if (pointerIdx == 5) { // No more fragments?
        pointerIdx = 0; // Reset all counters back to zero, in order to create an endless loop
        selector = PINE & 0x10; // Fast digitalRead(2)
        // Or change the sound depending of the pin state
  } else { // Ditto (except for the fact that points to another sound)
    OCR0B = pgm_read_byte_far(cp[pointerIdx] + sampleCount);
    sampleCount++;
    OCR0A = pgm_read_byte_far(cp[pointerIdx] + sampleCount);
    sampleCount++;
    if (sampleCount == cl[pointerIdx]) {
      sampleCount = 0;
      pointerIdx++;
      if (pointerIdx == 3) {
        pointerIdx = 0;
     Fragmentation occurs due to this couple of reasons:
     1. Annoying 32767 bytes array's length limit on AVR
     2. Arrays are written contiguously, but not in the right order. By playing it all continuously, you would listen a messed up sound.
But no clue what's going on.
Is not a hardware problem, because timer0 also maps to pin 13 (and so to the built-in LED); and I'm not getting any light out of there.
In a nutshell: pins 4 and 13 are not giving me any output, and the question is: why? :smiley-confuse:
wizz777
I find error in your code
This work for me
Code: [Select]
#define ADDR(var)({uint32_t a; asm("ldi %A0, lo8(%1)\n ldi %B0, hi8(%1)\n ldi %C0, hlo8(%1)\n ldi %D0, hhi8(%1)": "=d"(a): "p"(&(var))); a;})
