Topic: Play multiple audio files? Polyphony? (Read 5792 times) previous topic - next topic
pjrc
Do you really need stereo?  With the other PWM approaches, you get only mono, and rather low quality mono.
The STGL5000 has stereo DAC, stereo ADC, and a headphone amp.  If you only need a mono DAC, it's kinda overkill.
TobiasRipper
#16
Oct 28, 2016, 03:46 pm Last Edit: Oct 28, 2016, 03:54 pm by TobiasRipper
Well actually the STGL5000 sounds perfect for the job for the following reasons.
The project at hand is a handheld game (but not a console or emulator for existing games - this one is for a my specific game). I'm a composer by primary trade, writing the score (soundtrack) for this game, which is in stereo. From the sound and music standpoint, stereo signal allows you to make up a more immersive experience depending on the sound mixing techniques.
Also, as a composer, the work I put into writing the detail and working on the mix of the music such as defining instruments in the stereo space would be lost if I would just play the sound in mono and with a lower resolution to that point.
So the stereo signal is the primary reason why I was excited to see that mp3 module I posted in the original post. It's plays stereo audio and at the common bitrate.
Habeeb!!! Clean up on aisle four!!!
#17
Mar 25, 2018, 04:59 pm Last Edit: Mar 25, 2018, 06:02 pm by Mat13
► the Wav trigger board 50€ is an  high-fidelity polyphonic board
it can play and mix up to 14 stereo tracks simultaneously and independently, with very low latency.
https://www.sparkfun.com/products/13660
or mp3 trigger
or Teensy 20$ + audio Adaptor Board 14$ https://www.pjrc.com/store/teensy3_audio.html
► I'm rather investigating using multiple DFPlayers with their own TF card via several Serial ports
https://fr.aliexpress.com/item/TF-Card-U-Disk-Mini-MP3-Player-Audio-Voice-Module-For-Arduino-DFPlay-Min-Board/32659645208.html 1€15
in addition with a audio mixer circuit like CrossRoads said in message #8
or more sophisticated circuits. Principle described here circuitlib.com how-to-build-an-audio-mixer LM833 op-amp
allaboutcircuits.com build-an-audio-mixer/ with LF347 op-amp + -12/+12V PSU
oscium.com how-build-audio-mixer with 1 Quad Operational Amplifier chip (LM324) + Microprocessor M68HC11E9BCFN2
5V PSU
electroschematics.com 3-channels-audio-mixer/ with LM3900 op-amp
But some circuits require +15V and -15V supply which is not easy to get... or the workaround of virtual ground.
Any circuit suggestion? :)
