Topic: CDI tester project (Read 18477 times) previous topic - next topic
tombauer
Hi, well I am running this on Win XP Pro and wonder if that is wise since there are no updates for Java available and Arduino says "The environment is written in Java and based on Processing and other open-source software." I think it may not be able to install the latest version as well, it installed 1.6.10 and acted like that was the latest but my Win 7 machine says otherwise.
I think I have a issue with the IDE finding the libraries so I am going to work on that. The install said that I could chose my install directory which I did, but they suggest keeping the default one. Maybe that was for a reason.
Any way the code looked good to me and I am sure when I get past the library issues it will be fine. I will let you know how it goes.
Thanks again, Tom
tombauer
Got things sorted and it compiles but nothing. No data, just the headings on LCD, no pulse out.
cattledog
#137
Oct 22, 2016, 09:06 am Last Edit: Oct 22, 2016, 09:10 am by cattledog
I don't understand it, but there was a delay in setup before the timer setup which I dropped. I put it back and the code is as expected. I'm busy tomorrow, but I'll work to figure this out.
Code: [Select]
pinMode(outputPin, OUTPUT);            // declare the outputPin as an OUTPUT
  pinMode(chargePin, OUTPUT);            // declare the chargePin as an OUTPUT
  pinMode (setFallingSwitch, INPUT_PULLUP);//check for a LOW input to indicate switch is closed to ground
  delay(2000);
tombauer
cattledog,
Good morning! I put the "delay(2000);" in and all works as expected. I think now I am ready to add the pulse out on pin 7 to power the inverter for the AC type CDIs.
Best, Tom
tombauer
Hi, I am working on formula to display degrees, don't really need it but I may learn something.
I am attaching the schematic, not finished but enough there to see what I have.
cattledog
Here is the bug in the program which required delay(2000) in setup.
Code: [Select]
int timerTopValue =  0;
When the first TIMER1_COMPA_vector  interrupt was triggered, and OCR1A was set to timerTopValue, it was being set to 0 because this interrupt occurred before the first read of the pot to set the period. Because of this 0 value, the subsequent interrupts were occurring so fast that I think the millis() function was blocked from advancing and the code did not enter the section where the pot was read. I'm not quite sure why the delay in setup fixed this.
There are two solutions, simple one is to initialize the timerTopValue with the 12500 count used in the initial setup. You can also change the line in the timer set up to reflect the non zero initial assignment.
Code: [Select]
//int timerTopValue =  0;
int timerTopValue = 12500; //50 ms with 64 prescaler   // changed from timerTopValue = 0
Code: [Select]
// OCR1A = 12500;  //50 ms to top value
  OCR1A = timerTopValue;
The other would be to call an analogRead() in set up and assign the mapped value to RPM and calculate an intitial timerTopValue at that time. With either of these changes, the sketch does not require the delay in set up.
tombauer
cattledog,
Other issue solved as you said.
I think I have math that will give me the correct degree answer but I do not know how to write it in code.
delayDegrees = copy_delayPeriod / ((pulseValue / 360) / (1000));
This will not compile so is there another way to write it?
Where pulseValue must be divided by 360 first, and then that answer must be divided by 1000.
Then that answer must be divided into copy_delayPeriod
Tom
cattledog
Quote
I don't understand what was the problem with the existing code. What values is it giving you that appear to be incorrect? Can you give some numerical examples?
Code: [Select]
  delayDegrees = 360.0 * (copy_delayPeriod) / (timerTopValue * 4.0);  // for decimal place in deg display
timerTopValue*4 is the pulseValue (i.e. the repeating trigger period ~16-120 ms) expressed in microseconds instead of timer ticks. copy_delayPeriod is also in microseconds.  The ratio of the delay to the total period gets converted to degrees by multiplying by 360.
Suppose the RPM = 500 and therefore the trigger period will be 120 ms = 120000us
If the delay is 3000us then   360*(3000/120000) = 9 degrees.
tombauer
I may be confused, but when delay says 92, degree says 0.3 and when delay says 596, degree says 1.8.
Both taken at 500 rpm. With more delay, degree should be less. Unless we should not call that line Deg Advance, and should call it Degree retarded. I have no problem either way but what it says now, taken literally is not correct even though it may be right.
cattledog
#144
Oct 23, 2016, 10:04 pm Last Edit: Oct 23, 2016, 10:06 pm by cattledog
Quote
Not really.  Think of a one armed clock with the arm sweeping around. If the trigger goes off when the hand is at 12 and the signal comes back when the hand is at 1, then the delay of the response is 1/12 = 30 degrees. If the pulse comes back when the hand is at 2 then the delay of the response is 2/12  = 60 degrees. If the pulse comes back when the hand is at 3 then the delay of the response is 3/12 = 90 degrees.
If you understand degrees retarded better than degrees delayed it seems like an ok term to use.
tombauer
Hi, Yes you are right, but in the beginning I was, and still do think of it as advance. That is because I come from the world of engines and mechanical things as well as electronics. It has to do with the way "advance" is arrived at, using delay from a predetermined spot which is the most advanced that the spark will ever occur at high rpm. So I will think of it as degrees retarded, no problem, it makes it simple and then there is not the issue of calibrating for each different cdi.
With the test board, the degrees seem to make sense now, being approx what I expect, I need to install the switch for mode. I still don't really understand why with a cdi of no delay, the measurement of delay is from 96 to 136.
With test board set to 0 main shows 16 in the F mode, and with test set to 5100 main shows 5116.
With cdi of no delay, main shows 96 to 136, ideally this would be 0. Ideas? It is not important unless it is an easy fix, it may be that for some reason it really does take that long from pulse in to spark out.
Tom
cattledog
Here is some code for the CDI modules which require the charge pulse. It's pretty will commented but here's a summary.
There is mode switch(pin6) for the charge pulses similar to the switch for trigger edge, but unlike the switch for the trigger edge, it is active in set up only and is not dynamic. Default is to not use the charge pulses. Let me know if that needs changing. I thought you would know which module you were testing.
The 5 charging pulses are turned on and off by an overflow interrupt from Timer2. I use Timer2 to time out the charge pulses, because when I used a micros() software timer (like the the one which controls the display frequency) I saw problems at the higher rpm due to blocking aspects of the code. The charge pulses from Timer 2 are gated by the trigger pulse from Timer1. One issue which came up is that because of the 8 bit limit of Timer2 I could not cover the complete range of charge pulse intervals from 500 to 3800 rpm with one prescaler setting. I chose to limit the lowest rpm in the charging mode to 615 instead of 500. If that is a major problem, let me know and I will try to work out a switch between two prescaler settings for Timer2.
I don't have a scope, and tested as best I could with Serial output, but you will need to check on both the long term timing (synchronization)  of the of the charge pulses with the trigger, and the transient behavior on start up with the very first trigger pulses.  Beyond the control of timer2 by timer1, I added some additional safety by always writing the charge pulse pin low at the spark trigger, independent of the timer 2 period control.
Take a look at this and get back to me with any questions.
Code: [Select]
// revision 9 10/24/2016 adds charging pulse with Timer 2
// lowest RPM = 615 with charge pulse to keep OCR2A <= 255
// CDI Tester Pulse Generator Serial Output Arduino Code
int pot1 = A3;            // select the input pin for the pot (changed for this version because of lcd)
int potValue = 0;         // variable to store the value coming from the sensor
int pulseValue = 0;       // 2 variables from one pot
int timerTopValue = 12500;// changed from timerTopValue = 0
int outputPin = 8;        // select the pin for the output for trigger pulse
int chargePin = 7;        // select the pin for the output for charge pulses
volatile boolean trigger = false;
volatile unsigned long delayPeriod;
unsigned long copy_delayPeriod;
volatile unsigned long delayPeriodStart;
float delayDegrees;       // changed from int for decimal place display
int RPM;
volatile boolean interruptFlag;
unsigned long analogReadInterval = 1000; //read pots and map
unsigned long lastAnalogRead;
const byte setFallingSwitch = 5;
char risefall = 'R';   //default rising mode
const byte setChargePulseSwitch = 6;
boolean chargePulse = false ;  //default powered mode
volatile byte timeSliceCount = 0;  //TDC 0 degrees
#include <Wire.h>
// set the LCD address to 0x3f for a 20 chars 4 line display
// Set the pins on the I2C chip used for LCD connections:
//                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
LiquidCrystal_I2C lcd(0x3f, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
  //Serial.begin(115200);
  //Serial.println("starting...");
  lcd.begin(20, 4);         // initialize the lcd for 20 chars 4 lines, turn on backlight
  lcd.setCursor(1, 0);      // lcd display setup of unchanging headings
  lcd.print("RPM:");        // print fixed characters
  lcd.setCursor(11, 0);
  lcd.print("Mode:");       //to display code choice R or F
  lcd.setCursor(1, 1);
  lcd.print("Ms:");
  lcd.setCursor(1, 2);
  lcd.print("Us Delay:");
  lcd.setCursor(1, 3);
  lcd.print("Deg Advance:");
  pinMode(setChargePulseSwitch, INPUT_PULLUP);
  if (digitalRead(setChargePulseSwitch) == LOW)
    chargePulse = true; //AC CDI
  //Timer1 default set up .5ms trigger pulse every 50 ms
  TCCR1A = 0;
  TCCR1B = (1 << WGM12);//CTC mode to OCR1A
  TIMSK1 |= (1 << OCIE1A);//interrupt enable compareA
  TIMSK1 |= (1 << OCIE1B);//interrupt enable compareB
  OCR1B = 125; // .5ms trigger pulse width  //sets pulse out width, 500 = 2Ms, 250 = 1Ms, 125 = .5Ms
  TCCR1B |= (1 << CS11) | (1 << CS10); //prescaler 64 4us/tick
  //Timer2 default setup charge pulse 12 periods 30 degrees each; only 5 get turned on
  //charge pulse timing interval = Timer1 trigger period/12 = timerTopValue/96
  TCCR2A = 0;
  TCCR2B = 0;
  TCCR2A = 1 << WGM20; //lsb of mode 7 pwm to OCR2A
  TCCR2B = 1 << WGM22; //msb of mode 7 pwm to OCR2A;
  OCR2A = timerTopValue / 96; //96 = 12*4*2 (#periods, prescaler difference, up/down timer mode )
  TIMSK2 = 0;
  TIMSK2 = 1 << TOIE2; //enable overflow interrupt
  // actually start timer in ISR(TIMER1_COMPA_vect
  //prevent out of sync charge pulse, no prescaler set here
  attachInterrupt(digitalPinToInterrupt(3), delayPeriodTiming, RISING);
  if (millis() - lastAnalogRead >= analogReadInterval)
    lastAnalogRead += analogReadInterval;
    potValue = analogRead(pot1);
    pulseValue = analogRead(pot1);
    //Timer2 OCR2A requires max value 255 => 615 lowest RPM
    if (chargePulse)
      RPM = map(potValue, 0, 1023, 615, 3800);
      pulseValue = map(pulseValue, 0, 1023, 97, 16);// to show ms between pulse out on lcd
      //RPM = 615;//for my serial test purposes 615-3800
      RPM = map(potValue, 0, 1023, 500, 3800);
      pulseValue = map(pulseValue, 0, 1023, 120, 16);// to show ms between pulse out on lcd
     // RPM = 500;//for my serial test purposes 500-3800
    timerTopValue = 15000000UL / RPM;
    if (digitalRead(setFallingSwitch) == LOW) //set Falling
      risefall = 'F';
      risefall = 'R';
    lcd.setCursor(6, 0);
    lcd.print("    ");    // print blank spaces to clear old data
    lcd.print(RPM);
    lcd.setCursor(17, 0);
    lcd.print("  ");
    lcd.print(risefall);    //print R or F at upper right side
    lcd.setCursor(5, 1);
    lcd.print("    ");
    lcd.print(pulseValue);
    lcd.setCursor(11, 2);
    lcd.print("       ");
    lcd.print(copy_delayPeriod);
    lcd.setCursor(14, 3);
    lcd.print("      ");
    lcd.print(delayDegrees, 1);
  if (trigger == true && interruptFlag == true )
    trigger = false;
    interruptFlag = false;
    noInterrupts();
    copy_delayPeriod = delayPeriod;
    interrupts();
    delayDegrees = 360.0 * (copy_delayPeriod) / (timerTopValue * 4.0);  // for decimal place in degree display                         //value for display to 3 places in us
ISR(TIMER1_COMPA_vect) {
  OCR1A = (timerTopValue);// value to set delay between pulses to trigger cdi
  digitalWrite(chargePin, LOW); //guarantee off charge pin at trigger
  digitalWrite(outputPin, HIGH); //turn on pin 8 trigger
  if (risefall == 'R') //switch not set; default Rising trigger
    delayPeriodStart = micros();                                          //start looking for response as pulse rises
    trigger = true;
  //start Timer 2 for charge pulses
  if (chargePulse)
    timeSliceCount = 0;
    TCNT2 = 0;
    OCR2A = timerTopValue/96; //set 12 periods
    TCCR2B |=  1 << CS22 | 1 << CS21; //prescaleer 256 16us/tick
ISR(TIMER1_COMPB_vect) {
  digitalWrite(outputPin, LOW);      //turn off pin 8
  if (risefall == 'F') //switch set for Falling trigger
    delayPeriodStart = micros();                                          //start looking for response as pulse falls
    trigger = true;
void delayPeriodTiming()
  delayPeriod = micros() - delayPeriodStart;
  interruptFlag = true;
ISR(TIMER2_OVF_vect)
//5 pulses of 30 degrees starting at 60 degrees
//ON at 60,120,180,240,300 = 2,4,6,8,10
//OFF at 90,150,210,270,330 = 3,5,7,9,11
  if (timeSliceCount != 0 && timeSliceCount % 2 == 0)
    digitalWrite (chargePin, HIGH);
  else //if (timeSliceCount == 0 || timeSliceCount % 2 == 1)
  timeSliceCount++;
  if (timeSliceCount == 12)
    timeSliceCount = 0;
    //stop Timer2 by clearing prescaler bits
    TCCR2B &= ~1<< CS22;
    TCCR2B &= ~1<< CS21;
tombauer
cattledog,
Hi, I looked it over, will try it soon. One question came up yesterday when I tested a CDI that fires from falling edge. It gave long Us delay times like I had before when it was measuring from leading edge. So many CDIs do the same thing in function but with slightly different characteristics!
So I put this 100Us delay in and it fixed it, but any less than 100 did not correct it and more than 100 had no more effect. Just wanted to understand. With the 100Us delay, the Us Delay reads 8 or 12, mostly 12.
Code: [Select]
  digitalWrite(chargePin, LOW);                                          //turn off pin 7
  if (risefall == 'F')                                                   //switch set for Falling edge of pulse for trigger
    delayMicroseconds(100);                                             // delay for 4518 cdi
    trigger = true;
cattledog
Quote
When we code for the trigger on the falling edge but the actual trigger is on the leading edge, we get long delay times equal to the fundamental repeating trigger period plus the actual delay. The code did not start looking for the return pulse until after it had arrived and we were catching the next one.
When we code for the trigger on the leading edge, but the actual trigger is on the falling edge, we get delay times equal to the trigger pulse length plus the actual delay. Trigger pulse length was last set at 125 Timer1 counts (each equal to 4 microseconds by prescaler 64) which is 500 microseconds.
When we code for the trigger edge which actually matches the device, we were reading the correct delay.
You are now reporting a new issue in that the code with the falling edge delay measurement start time and the module delay being falling edge triggered you see "large" numbers unless there is a 100 microsecond delay.
First, are you absolutely certain the CDI unit delay is falling edge triggered? How do you know?
If indeed this strangely behaving module were actually rising edge triggered, but measured with falling edge code, the added 100 microsecond delay could push the time at which the delayed pulse was sensed to back after the falling edge and it would measure a small delay.
I can't see any other way that added delay would turn a large measured delay into a small one unless it pushed the arrival of the delayed pulse echo to after the end of the trigger pulse.
What are the actual delay numbers you see, and at what RPM? That data last time was the key to figuring out what was going on.
Have you ever seen issues with the Rising edge triggered code? Have you ever seen issues with Falling edge triggered code and the two Arduino test setup?
Do you know how the modules sense the RPM? We have coded everything based on the premise that the module figures RPM by the time between similar edges and the delayed spark pulse is fired from that edge. But it's conceivable that there are other methods in use.
The delayMicroseconds(100) in the code can only affect the Arudino and its measurement as the trigger pulse was ended before the delay and the real delay is controlled by the module hardware. What does the scope tell us about the relationship between the trigger pulse and when the spark pulse is really being fired?
Adding the delayMicroseconds(100) into the ISR is not good practice and could have unintended consequences for other timing, so its best to figure this out.
tombauer
cattledog,
Ok, I had time today to look into this and was very surprised by what I found. This was on a CDI that is DC powered meaning it has its own DC to high voltage AC inverter inside. When I looked at it on the scope (like I should have done at first) The signal from the coil primary had an incredible amount of ringing or oscillation after the pulse firing the coil. This was playing havoc with the optocoupler. I put a diode across the coil and completely eliminated this problem. I will have to keep remaining myself that we have fairly established that the software is working very well and problems that arise are outside that scope!!
I really do need to thank you for the help you have provided, I do car audio repair daily so if you ever have a need perhaps I can repay you.
I had a thought about what to use for a 'box' for this all to live in and thought of a dvd duplicator or external cd drive case since they usually have small power supplies with 3.3, 5.0, and 12 volt outputs, and have the available room of 2 or 3 5.25" drives. Is there something else I might consider?
Best, Tom
