Topic: CDI tester project (Read 19609 times) previous topic - next topic
cattledog
I've got a 20x4 on order, and should be able to work in your format when it arrives.
tom_bauer
Hi, on lines 61 to 69 and then 102 to 109 there is lcd info that seems to conflict in a way I don't understand.
Tom
cattledog
Because I was working with a 16x2 display, I didn't have the real estate for your current display parameters, so I tried to use a set up screen and then an operating screen.  I will have a 20x4 in a few days and can go back to your original approach with one screen.
Quote
Can you explain more.
These lines are for a setup screen, and the values are filled in with the print statement in the setupSwitchPresets() function
Code: [Select]
//61-69
lcd.begin(16, 2);
lcd.setCursor(0, 0); // lcd display setup of unchanging headings
lcd.print("RPM:"); // print fixed characters
lcd.setCursor(9, 0);
lcd.print("Mode:");
lcd.setCursor(0, 1);
lcd.print("1stPulse:"); //first pulse + or -
lcd.setCursor(11, 1);
These lines are for the operating screen and show the current RPM from the pot setting, and the delay of the return pulse from the module from the point in time when the R or F edge of trigger pulse was sent.
Code: [Select]
/102-109
lcd.setCursor(4, 0);
lcd.print("           "); // print blank spaces to clear old data
lcd.setCursor(5, 0);
lcd.print(RPM);
lcd.setCursor(9, 1);
lcd.print("       ");
lcd.setCursor(10, 1);
lcd.print(delayDegrees, 1);
We should get bact to the 20x4, and display what ever data makes sense to you.
tom_bauer
Hi, OK I think I see. Yes I would like to go to the display I had, it shows everything I want to know. No need for the firstPulse info, I will see if the toggle switch is up for + or down for -. Also I prefer the Degrees Advanced, I had a calculation in the last code that did that quite well.
Tom
tom_bauer
Hi, I have done some testing and here is my revision of the code. Pins 6, 5, 4 do not update, require a reboot, how to have them reset parameters when they are changed?
No charge pulses on pin 7.
LCD would not work until I moved the code from line 248 to 129 and from 259 to 123
Tom
Code: [Select]
//V1.0 set RPM potentiometer/configuration swtiches/hd44780 lcd/revised pin numbers
#include <Wire.h>
#include <hd44780.h>
#include <hd44780ioClass/hd44780_I2Cexp.h> // include i/o class header
hd44780_I2Cexp lcd; // declare lcd object: auto locate & config display for hd44780 chip
//utility definitions
#define positive HIGH
#define negative LOW
#define firstPulse 0
#define secondPulse 1
//You can use pots to set RPM, pulseWidthDegrees, and barWidth
//unsigned int RPM = 1200;//adjusted with potementiometer
unsigned int pulseWidthDegrees = 10;
unsigned int barWidthDegrees = 60;
int pickupPositionOffset = 0; //timing offset from TDC
unsigned long pulseWidthTime;//degrees converted to time
unsigned long timerTopValue;//sets 360 degree cycleTime
unsigned int timerTicksPerDegree;
//output pins
const byte chargePin = 7; //charge pulses
const byte pinB = 8;      //to DAC pin 5
const byte pinA = 9;      //to DAC pin 6 - 12, called 6
//configuration switch setup
const byte polaritySwitch = 4;
boolean firstPulsePos = positive; //first pulse polarity
const byte setFallingSwitch = 5;
char risefall = 'R'; //default rising mode start timing from rising edge
const byte setChargePulseSwitch = 6;
boolean chargePulse = false ;  //AC CDI default is DC
int pot1 = A3; //input pin for pot which sets rpm
//return pulse interrupt variables
volatile boolean trigger = false;
volatile boolean interruptFlag;
volatile unsigned long delayPeriod;
unsigned long copy_delayPeriod;
volatile unsigned long delayPeriodStart;
float delayDegrees; // changed from int to float for decimal place display
int RPM;
int pickup;
int barWidth;
int pulseWidth;
  //set outputs for 0v
  pinMode(13, OUTPUT); //telltale led
  digitalWrite(13, LOW);
  pinMode(pinA, OUTPUT);
  digitalWrite(pinA, LOW);  //DAC 6 LOW
  pinMode(pinB, OUTPUT);
  digitalWrite(pinB, HIGH); //DAC 5 HIGH
  pinMode(3, INPUT_PULLUP); //interrupt pin, return pulse drives low
  pinMode(chargePin, OUTPUT); // declare the chargePin as an OUTPUT
  // initialize LCD with number of columns and rows:
  lcd.begin(20, 4); // initialize the lcd for 20 chars 4 lines, turn on backlight
  lcd.print("Mode:"); //to display code choice R or F
  lcd.setCursor(1, 1);
  lcd.print("Pos:");
  lcd.print("Width:");
  lcd.setCursor(1, 2);
  lcd.print("Us Delay:");
  lcd.setCursor(1, 3);
  lcd.print("Deg Advance:");
  setupTimer1();
  setupSwitchPresets();
  //15000000 timerTicksperMinute at 4 us per tick with prescaler 64
  //timerTopValue = 12500 at 1200 RPM 50ms per revolution
  timerTopValue = 15000000UL / RPM;
  timerTicksPerDegree = timerTopValue / 360;
  pulseWidthTime = pulseWidthDegrees * timerTicksPerDegree;
  TCNT1 = 0;
  OCR1B = pulseWidthTime;//timer ticks
  attachInterrupt(digitalPinToInterrupt(3), delayPeriodTiming, FALLING);
  delay(5000);//display setup parameters
  //lcd.setCursor(0, 1);
 //lcd.print("DelayDeg:");
  const unsigned long analogReadInterval = 250;//250; //read pots and map
  static unsigned long lastAnalogRead = 0;
  if (millis() - lastAnalogRead >= analogReadInterval)
    //add other potentiometer adjustments here
    lastAnalogRead += analogReadInterval;
    RPM = map(analogRead(pot1), 0, 1023, 500, 4000);
    //adjust timer values for RPM
    lcd.print(RPM);
    lcd.setCursor(14, 0);
    lcd.print("  ");
    lcd.print(risefall); //print R or F at upper right side
    lcd.setCursor(16, 0);
  if (firstPulsePos)
    lcd.print("+");
    lcd.print("-");
    lcd.setCursor(18, 0);
  if (chargePulse)
    lcd.print("AC");
    lcd.print("DC");
    lcd.setCursor(6, 1);
    lcd.print("   ");
    lcd.print(pickup);
    lcd.setCursor(16, 1);
    lcd.print("   ");
    lcd.print(pulseWidth);
    lcd.setCursor(11, 2);
    lcd.print("       ");
    lcd.print(copy_delayPeriod);
    lcd.setCursor(14, 3);
    lcd.print("      ");
    lcd.print(delayDegrees, 1);   //delayDegrees, 1);
  if (trigger == true && interruptFlag == true )
    trigger = false;
    interruptFlag = false;
    noInterrupts();
    copy_delayPeriod = delayPeriod;//microseconds
    interrupts();
    //Serial.print(copy_delayPeriod);
    //Serial.print('\t');
    //divide by 4 to convert microseconds to timer ticks
    delayDegrees = (copy_delayPeriod / 4) / timerTicksPerDegree;
    //Serial.println(delayDegrees);
    //delayDegrees = pickup - (360.0 * (copy_delayPeriod) / (timerTopValue * 4.0)); //for decimal place in deg display.
void setupTimer1()
  TCCR1A = 0;
  TCCR1B = 0;
  TCNT1 = 0;
  //set Timer1 mode Fast PWM to ICR1
  TCCR1B |= (1 << WGM13) | (1 << WGM12);
  TCCR1A |= (1 << WGM11);
  //start Timer apply prescaler
  // TCCR1B |= (1 << CS12) | (1 << CS10); //1024 for led test 8us tick
  TCCR1B |= (1 << CS11) | (1 << CS10); //64 for .5 us tick
  //enable B OutputCompare and Overflow interrupts
  TIMSK1 |= (1 << OCIE1B) | (1 << TOIE1);
ISR(TIMER1_OVF_vect)
  //alternate ICR1 values to generate two outputs over 360 degrees
  //360 degree cycle time broken into two pieces
  //timerTopValue adjusted with RPM pot
  //timerTicksPerDegree = timerTopValue / 360; //gets new value to update ICR1
  static byte pulse = firstPulse;
  if (pulse == firstPulse)
    ICR1 = timerTicksPerDegree * (pulseWidthDegrees + barWidthDegrees); //first pulse and bar width
    digitalWrite(13, HIGH);
    if (firstPulsePos == true)
      setPulse(positive);
      setPulse(negative);
    //set timing start at lead edge of first pulse
    if (risefall == 'R')
      delayPeriodStart = micros();                                          //start looking for response as pulse rises
      trigger = true;
    else //risefall == 'F' set timing at trailing edge of first pulse
      //convert pulseWidthTime in timer ticks to microseconds
      //prescaler 8 = 4us/timer tick
      delayPeriodStart = micros() + pulseWidthTime * 4;                    //start looking for response as pulse rises
      trigger = true;
    pulse = secondPulse; //next pulse
  else //second pulse
    ICR1 = timerTicksPerDegree * (360 - (pulseWidthDegrees + barWidthDegrees)); //second pulse and dead band
    if (firstPulsePos)
      setPulse(negative);
      setPulse(positive);
    pulse = firstPulse; //next pulse
ISR(TIMER1_COMPB_vect) {
  digitalWrite(13, LOW);    //turn off pulse for 0 volt
void setPulse(byte state)    //state negative = LOW state positive = HIGH
  digitalWrite(pinA, state );  //DAC 6 state
  digitalWrite(pinB, state);  //DAC 5 state
void setupSwitchPresets()
  pinMode(setChargePulseSwitch, INPUT_PULLUP);
  if (digitalRead(setChargePulseSwitch) == LOW)
    chargePulse = true; //AC CDI
    chargePulse = false;
  //lcd.setCursor(19, 0);   //moved to line 129
  //if (chargePulse)
    //lcd.print("Y");
  //else
    //lcd.print("N");
  pinMode(polaritySwitch, INPUT_PULLUP);
  if (digitalRead(polaritySwitch) == HIGH)
    firstPulsePos = true; //first pulse positive
    firstPulsePos = false; //first pulse negative
  //lcd.setCursor(17, 0);   // moved to line 123
  //if (firstPulsePos)
    //lcd.print("+");
  //else
    //lcd.print("-");
  pinMode (setFallingSwitch, INPUT_PULLUP); //check for a LOW input to indicate switch is closed to ground
  if (digitalRead(setFallingSwitch) == LOW) //set Falling
    risefall = 'F';
    risefall = 'R';
  //lcd.setCursor(14, 0);
  //lcd.print(risefall);
void delayPeriodTiming()
  delayPeriod = micros() - delayPeriodStart;
  interruptFlag = true;
cattledog
#200
Feb 02, 2019, 12:30 am Last Edit: Feb 02, 2019, 12:57 am by cattledog
Nice progress getting the code back to the 20x4 display.
Quote
Add the function setupSwitchPresets() into this section of loop(). The pinMode() calls in the function should  be moved into setup().
Code: [Select]
      //all the pot/switch reading to change settings and display them code
Quote
Correct. I am working on the timer2 and charge pulse code now. With the dual pulses I think there may be some changes about how the charge pulses are coordinated and synced to the trigger pulse.
Quote
This does not make sense to me, but when I get the 20x4 on line I can revisit this. It does not make any difference it you are going to change the toggle switch settings while the code is running.
Quote
First, declare a new global variable called degreesAdvance and call it when/where you want to display it on the lcd.
Then add a new line to the code after the line of code which calculates the delayDegrees from the interrupt timing of the delayPeriod.
Code: [Select]
degreesAdvance = pickup - delayDegrees;
This will be the degrees before TDC of  the return pulse.
When do you think you will have the hardware set up to test the dual pulses? Can you do that without the charge pulses?
tom_bauer
'Add the function setupSwitchPresets() into this section of loop(). The pinMode() calls in the function should  be moved into setup().
Code: [Select]
This I do not really understand..??
OK re the charge pulses, actually now it may be good to have twice as many pulses for the charge output to drive the transformer that makes the AC.
'This does not make sense to me, but when I get the 20x4 on line I can revisit this. It does not make any difference it you are going to change the toggle switch settings while the code is running.'
The way it was the Arduino would not even start until I commented out those lines.
'First, declare a new global variable called degreesAdvance and call it when/where you want to display it on the lcd.
Code: [Select]
This will be the degrees before TDC of  the return pulse.'
OK I will work on this after I get the hardware set up.
'When do you think you will have the hardware set up to test the dual pulses? Can you do that without the charge pulses?'
Yes I can, but the pulses look correct on the scope so I have little doubt it will work correctly when wired up. Bread board should be here tomorrow.
Tom
[/quote]
cattledog
Quote
Quote
Code: [Select]
#include <Wire.h>
//output pins
int RPM;
int pickup;
int barWidth;
int pulseWidth;
  //add toggle switch pinMode
  pinMode(setFallingSwitch, INPUT_PULLUP);
  lcd.print("Pos:");
  setupTimer1();
  TCNT1 = 0;
    lcd.print(RPM);
    lcd.print("  ");
    if (firstPulsePos)
      lcd.print("+");
      lcd.print("-");
    if (chargePulse)
      lcd.print("AC");
      lcd.print("DC");
    lcd.print("   ");
    lcd.print(pickup);
    lcd.print("   ");
    lcd.print("       ");
    lcd.print("      ");
    trigger = false;
    noInterrupts();
    interrupts();
void setupTimer1()
  TCCR1A = 0;
  TCCR1B = 0;
  TCNT1 = 0;
      setPulse(positive);
      setPulse(negative);
      trigger = true;
      trigger = true;
  else //second pulse
    if (firstPulsePos)
      setPulse(negative);
      setPulse(positive);
  //pinMode(setChargePulseSwitch, INPUT_PULLUP);
  //if (chargePulse)
  //lcd.print("Y");
  //else
  //lcd.print("N");
  //pinMode(polaritySwitch, INPUT_PULLUP);
  //lcd.print("+");
  //else
  //lcd.print("-");
  //pinMode (setFallingSwitch, INPUT_PULLUP); //check for a LOW input to indicate switch is closed to ground
    risefall = 'F';
    risefall = 'R';
cattledog
Quote
In the existing program, there are 5 pulses of 30 degrees starting at 60 degrees
ON at 60,120,180,240,300 = 2,4,6,8,10
OFF at 90,150,210,270,330 = 3,5,7,9,11[/quote]
Do you want say 10 pulses of 15 degrees over the same 240 degrees? Do you want something different than equal duty cycle on/off to cover more of the 360 with pulses. Can we be closer to TDC with the pulses. Now, there is 120 degrees around 0 with no pulses?
tom_bauer
Hi, No, never mind me, I was thinking wrong. Pulses are fine as is.
Tom
tom_bauer
Hi, OK, all tested, all working. Later today I may get to do final test of pulses for DAC just to confirm that they match rpm but I assume they do/will.
Tom
cattledog
Here is the code attached with the charge pulses back in. I have cleaned up some variables and nomenclature. The current code only displays one "width" and I wasn't sure if it was barWidthDegrees or pulseWidthDegrees. You may want to change the display to show both.
tom_bauer
Hi, I was adding the pots and changed a couple variable names and now it won't compile!! I must have done something dumb!
Tom
cattledog
Ok, Here's your version which now compiles. Tere was a misplaced bracket and an undefined variable.
I now have my 20x4 online so I can follow your work more closely,
I see a couple of problems with the code as provided.
You are mapping two values from the same pot. Is that correct?
Code: [Select]
pickupValue = map(analogRead(pot2), 0, 1023, 10, 90);
    barWidth = map(analogRead(pot2), 0, 1023, 20, 80);
I think this should be pickupValue if you want the pot controlled variable and not the fixed one I had.
Code: [Select]
lcd.print(pickup);
I leave you to make these changes to the code if I'm correct.
Have you had the charge pulses on the scope? If so, do they look correct in relationship to the trigger pulse?
cattledog
#209
Feb 08, 2019, 07:45 pm Last Edit: Feb 08, 2019, 08:50 pm by cattledog
I just noted another error in the analogRead() pot mapping section. The placement of the new readings had broken the if/else construction of the rpm mapping with and without the charge pulses. That section should look like this.
Code: [Select]
    if (chargePulse)//lowest rpm with charge pulse is 615
      RPM = map(analogRead(pot1), 0, 1023, 615, 4000);
    pickupValue = map(analogRead(pot2), 0, 1023, 10, 90);//two variables on same pot
    barWidth = map(analogRead(pot2), 0, 1023, 20, 80);//two variables on same pot
EDIT:
With the new adjustable variable pickupValue the code for degreesAdvance should change.
Code: [Select]
//degreesAdvance = pickup - delayDegrees;
    degreesAdvance = pickupValue - delayDegrees;
