Topic: Powering Portable Led Strips (Read 2509 times) previous topic - next topic
snoche
Those are the specs
Product Description
Input Voltage Range AC 230V ±10% 50Hz
Rated Output Voltage KPS6005DA: 0-60 V (Adjustable)
Rated Output Current KPS6005DA: 0-5 A (Adjustable)
Rated Output Power 300W
Display Precision (Voltage) 0.1V ± 2 digit
Display Precision (Current) 0.01A ± 3 digit
Work Method Cooling Wind Cooling
Working Environment 0-40 ℃; Relative Humidity <80%
Size (H x B x T) 130 x 160 x 250 mm
Grumpy_Mike
Quote
This is the step down I will be using .....
You said the the step down would cope with 15A. There is no way the power supply in that link can handle 15A.
snoche
I use the step down to go from 7.4v to 5v.
I know the power supply can not go 15A as it only handle 5A max The problem as I said before is that with 5v doesn't increase over 1.2A, from my test with 3 amperes I will have enough to make my leds white.
Grumpy_Mike
Quote
Yes but voltage is only part of the story. What current do you think you can get out of this step down circuit?
