Topic: Twos complement? (Read 11130 times) previous topic - next topic
dmurray14
Hey guys,
I'm still pretty new at this. I'm working on accepting data from a module that sends a number in two bits. I'm told it is positive or negative according to two's complement. While I understand the concept, what do I have to do with the arduino to go from a two-bit two's complement number to an int?
Thanks!
retrolefty
The signed int variables used in Arduino already uses twos complement for negative numbers. To convert a positive number to a negative number in twos complement you invert all the bits and add 1.
I think to convert a 2 bit signed number to a 16 bit signed number you just have to set the extra 14 higher bits to one if the second bit of the smaller number is a one, but not really sure.
http://en.wikipedia.org/wiki/Twos_complement
Lefty
dmurray14
Gotcha, thanks. I'll give it a go...
Grumpy_Mike
Quote
Do you mean two parts or two binary bits? Lefty was talking about the latter.
retrolefty
Quote
Yes, I did take it as posted literally, as 2 bits, which on the surface is kind of silly I would think, the range would be rather restrictive, no  ;)
Lefty
dmurray14
I'm an idiot, that was a typo. Should have been two BYTES. I assume that changes things?
Coding Badly
Quote
what do I have to do with the arduino to go from a two-byte two's complement number to an int?
Nothing.  On the Arduino a two-byte two's-complement number is an int.  Just make certain you get the bytes in the correct order and you're good-to-go.
dmurray14
#7
Nov 04, 2009, 03:23 pm Last Edit: Nov 04, 2009, 03:24 pm by dmurray14 Reason: 1
Cool, so something like this would work?
plMSB = Serial1.read();
plLSB = Serial1.read();
myInt = (int)plMSB<<8;
myInt+= plLSB;
Thanks!
Coding Badly
#8
Nov 04, 2009, 10:44 pm Last Edit: Nov 04, 2009, 10:45 pm by bcook Reason: 1
Quote
Almost...
You should get in the habit of using a bitwise-or instead of addition when combining bytes...
Code: [Select]
myInt |= plLSB;
I don't think it's a problem in this case but there are times when using addition leads to a sign extension and that can cause problems.
dmurray14
Perfect, thanks! Still learning ;)
