Topic: Arduino Micro Dmx Receiver (Read 3652 times) previous topic - next topic
rotorStudio
Hello everyone!
I'm looking for some examples of receiving DMX values on Arduino Micro with Max485 or similar. I'm testing different librarys for Arduino Uno and doesn't work for me nothing...Anyone can orienting me a little bit?...
Thanks!
http://www.romantorre.net
http://www.rotor-studio.net
septillion
So you did try things? Then you can also post
- Schematic
- How did you test it? (Which controller etc)
- Where is the code?
- What did happen and what did you expect?
My crystal ball is broken so only saying "does not work" doesn't cut the mustard...
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
rotorStudio
#2
Sep 26, 2016, 01:27 pm Last Edit: Sep 26, 2016, 01:36 pm by rotorStudio
Yehaa! Sorry, thanks for the response...:)
My controller is an Arduino Micro and i have the max485 chip.
I try to ran with the example available here, with the right wiring and working for me on UNO:
http://www.maxpierson.me/2009/03/20/receive-dmx-512-with-an-arduino/
And also with this another one:
http://www.mathertel.de/Arduino/DMXSerial.aspx
I need to receive a DMX signal for to move servos, but i m looking for a working library or examples tested on the Micro board because i have not familiarity with raw coding, USART, and all things that i'm reading for now..
Thanks @septillion ;)
mcnobby
I have used the Mathertel library many times and it always works a treat, I have made my own adaptations of it so it doesnt need to work as a library.
You need to find ways of debugging..
Set an LED on the Micro board when a specific value appears over DMX
Force feed whatever servo library you have with values to move the servo
then somehow combine the two...
http://www.youtube.com/user/Recovered
http://www.smartshow.lighting
AWOL
Do not cross-post, cross-posting wastes time.
Duplicate deleted.
rotorStudio
#5
Sep 26, 2016, 10:15 pm Last Edit: Sep 26, 2016, 10:29 pm by rotorStudio
Thanks! @mcnobby, is good that i have feedback from a user. There are not examples on the internet working clear with the Micro. I gonna try a little and them i tell you which is the trouble..
I know how debug this, thanks, now i have working all the stuffs of my code/device, only i have problems with the DMX receiving.
Duplicate deleted.
Ok i know...my apologies. I was trying to delete the first post when I saw it was not the right place but...thanks!
Riva
I had posted a long reply to the other thread that got deleted and cannot be bothered to type it all again so the short answer is. Look for a DMX receive library that works with the Leonardo as this is basically what the Micro is.
Don't PM me for help as I will ignore it.
rotorStudio
Thanks Riva! Do you have a direct link of this library?
rotorStudio
Hey!
Good news, now is working on my Arduino Micro. Finaly i'm using the Mathertel library only in receive mode.
Thanks!
