Topic: Trigger L trigger can not be repeated / H repeated trigger (Read 421 times) previous topic - next topic
dgkindy
Can someone please help me understand the PIR trigger.
My understanding is that H once it detects a person, it will stay on until the person leaves the view.  How does does the L trigger work?
Grumpy_Mike
Quote
Close. It means that the the output will stay high as long as movement is constantly being detected. It then goes low and stays low for a preset period when the sensor is disabled. Then it looks for movement again and goes high when it sees it.
Quote
Once movement is detected the output goes high and stays high only as long as the timer setting dictates, even if there is continuous movement. It then goes low and stays low for a preset period when the sensor is disabled. Then it looks for movement again and goes high when it sees it.
